Question about Kenmore Elite Oasis ST 6807 Dryer
Dryer was not pulling air out of machine,
After taking front off to clean lint vent I found a belt and a small pulley like object unattached to anything. The drum belt is attached what could this go to
  • 44 Answers
This belt and pulley are what spins the fan.Which explains why it is not pumping air.What you will need to do is take the whole front off flip up the top and remove the drum.at that point you will see a fan housing on the bottom directly under where the drum was.you need to screw that pulley you found back on to the fan shaft and run the belt that you found from the fan pulley to the front of the drive motor.Then reinstall the drum and drum belt and it's good as new.a good thing to do would be to use some loctite when screwing the fan pulley back on so it will not fall apart again.another little tip is that pulley has a reverse thread so you will need to screw it on counter clockwise.Also on most models with this type of fan you need to get to the drum belt from the back of the dryer to remove and install the drum belt
Posted on Apr 17, 2014
SOURCE: Kenmore series 70 electric dryer idler pulley
I figured this one out...there are two pairs slots...the tab of the idler pulley goes in the right slot near the motor and the idler pulley goes off to the left.
Posted on Jun 12, 2008
  • 4 Answers
SOURCE: Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Posted on Dec 26, 2008
  • 188 Answers
SOURCE: dryer belt broke on my kenmore series 80
With the front cabinet panel off, place the drum against the back and on the rear rollers. The roller on the right will sometimes move toward the rear so reach from underneath and pull it forward. The rollers should sit in the groove. The drum will tilt forward but shouldn't fall off. Route the belt around drum, pulley and motor. Tilt the drum back and support it while placing the front panel back onto it's hooks. With the front panel on (don't screw it on yet), rotate the drum by hand to make sure the seal is not kinked and the belt won't slide off the pulley or motor. If all is well screw in the front panel and re-assemble the rest.
Posted on Feb 19, 2009
  • 1122 Answers
SOURCE: Someone Help! I've got something stuck in my lint filter vent!!
remove the 2 lint filter screws on the top,remove the back,you will see 4 screws on the blower box to the left(the tall box) remove the box and get that ever is stuck in it,let me know how you do-mike
Posted on Mar 20, 2009
tony2155
  • 64 Answers
SOURCE: Dryer runs fine but no heat
change the fuse in back of the dryer
Posted on Jun 23, 2009
Smell rubber
i have found that when people start smelling things in the dryer it's from chemicals from like paint or varnish,all the dryer does is move air when it gets hot you start smelling it.you can pull it apart and check the belt and rollers but your dryer has the lint filter on top and there isn't anything in there that could really make it smell,on some of these dryers the belt pulley doesn't have a wheel on it,the pulley is just a piece of metal with no moving parts and the belt rubs on the pulley but i've never smelt anything from that,like i say usually it's from having your floors done over the smell from the polyurethane coating or from paint can make the dryer smell.go here to take dryer apart
http://www.youtube.com/watch?v=xGIG8Wo5-N4
hope this helps
Jan 19, 2014 | Dryers
Notice a "rubber"smell this winter. The lint vent is clean after each use, outside vent is clear of any debris. can the wind blow smell back into house or is it a belt? Installed new by dealer 1/9/13.
I have found that when people start smelling things in the dryer it's from chemicals from like paint or varnish,all the dryer does is move air when it gets hot you start smelling it.you can pull it apart and check the belt and rollers but your dryer has the lint filter on top and there isn't anything in there that could really make it smell,on some of these dryers the belt pulley doesn't have a wheel on it,the pulley is just a piece of metal with no moving parts and the belt rubs on the pulley but i've never smelt anything from that,like i say usually it's from having your floors done over the smell from the polyurethane coating or from paint can make the dryer smell.go here to take dryer apart
hope this helps
Jan 19, 2014 | Whirlpool Dryers
Ler7620lw0
your lint filter is on top so unplug it,remove the lint filter and the two screws on top in front of the filter,get a screw driver,stick in into the space where the top and front meet around two iches from each corner and lift up,pop the top up,on the right side you'll see the door switch harness,get a small screw driver,stick into the harness to separate it,pull it apart and then look at the right and left side a few inches down and you'll see a 5/16 inch screw one on each side,remove them and pull up on the front panel,,pull up first on right side then left side.now reach in on the right side,stick your head inside the drum and lift the drum with right shoulder,pull up on the belt pulley and remove the belt,first look at how the belt connects to the motor so when you reinstall it you know how it goes.now lift the top and pull the drum.there's a kit that comes with the belt rollers and new pulley,change out these parts and your noise should be gone,also while you're in there vac up all the lint,put the dryer back together but don't reinstall the two screws on top,pull out the dryer and remove the vent line and back wall,on the left side remove the four screws that hold the metal duct in place,clean out the duct and vac up any lint,put that back together and the two screws on top,if the vent line is long,i use a leaf blower to blow out the vent line,if you clean out the dryer once a year and the vent line you'll hardly have any problems with this dryer,.watch this video and good luck,if you need any other help with any appliance let me know and hopefully we can get it done.
Oct 20, 2013 | Dryers
Belt Change?
take the lint screen out take out the two screws were the lint screen is. take a flat screw driver and there is two clips on front panel to release the the top. just push and pry up on the clips. disconnect the door switch wire harness. there is two screws holding the front panel on. once out lift up on front panel to remove. look by motor and you will see a idler pulley. loop belt under left side of pulley and pull the pulley to right side of cabinet (when looking at the machine) and loop onto motor pulley
Nov 28, 2009 | Whirlpool Dryers
Electic Dryer taking a long time to dry clothes.
unplug dryer there is a panel on the back of dryer bottom 2 screws to remove pull panel out reach inside take belt off motor(note how it comes off) about half way up the back of dryer is a cover (about 3x5) take that cover off you will see a E clip...remove it with a flat screw driver next open door look up and see screws and remove them lift up on lid and from inside remove screws that hold front panel note the way the wires are on door switch lift panel up and out... pull drum out watch for round bushing and washers take lint filter out clean ...lint passage and fan all pipes and element... remove all lint ..if you can get an air tank,it is best to blow the motor out with air ...on the belt puly center should be grease if not put some in...try not to move the element too much( and break it
ve6gar
Aug 20, 2009 | Maytag Dryers
Bosch Nexxt 800 series dryer E01 error
My wife has a Bosch Premium dryer that had drying problems. The lint filter would get cleaned but the machine still did not operate correctly, as you explained above. Her machine was made in 2005 and the lint screen, the plastic slotted unit in front of the lint filter was the problem. It gets clogged up with hair/lint that never makes it to the filter. I tried a shop vac to vacuum it but the problem was still there. Get a pistol cleaning kit for a 22 cal gun. Pull the lint filter out & then take the pistol rod and insert it from the drum side into each slot and pull out the tons of lint. Pull the lint off the rod when done and take a flame to burn the rest off as the rod is a brass brush with small wires on it.
Jun 14, 2009 | Bosch Nexxt 500 Plus Dryer
How to fit a belt on a tumble dryer
unplug the dryer,
220v is not fun
dryers are generic inside, regardless of maker
while you got it apart to replace the belt is a good time to clean out exhaust vent pipes and the squirrel cage fan, no lint, better air flow, less $$ to run
3cd9043.jpg the tensioner may push Up on the lower run.
  • open case, most front panels are removed including door, remember to disconnect door switch wires, set panel aside
  • pull drum out
  • check drum support rollers
  • check drum felts, bushes guides
  • locate tensioner pulley, belts have been known to pull them out of the mounting when it breaks, check , reinstall if out
  • pick up broken belt off floor of case
  • take belt to parts store and match it, despite the huge number of dryer models there are very few belts.
  • If any felts or rollers are worn,stuck,damaged take them too to the parts store, and replace in pairs, despite the huge number of dryer models there are very few rollers or felts
  • after ensuring rollers anf felts and bearings are serviceable, loop new belt around drum at the wear mark from prior installation, reinsert drum
  • loop new belt around motor pulley.
  • pull tensioner pulley against spring to end of motion
  • loop belt around tensioner pulley
  • allow tensioner to slowly move back by spring tension till the belt is taut
put front panel back on, plugging in door switch
plug in mains
dry clothes
takes longer to type than to do
Aug 29, 2008 | Dryers
Whirlpool dryer wed5700sw
you need a dryer vent brush first,bought at home depot cheap,and clean the entire vent to the house,then clean where the vent hooks up to the machine,if your filter is where your door is pull out the filter and stick the brush in there and pull out lint,also use your vacume,remember you let some lint out when you let the hose blow out but theres a lot more there to clean,and also unplug your machine as you do this,if this helps please give me a fix ya vote
Jul 14, 2008 | Whirlpool Dryers
Kenmore Elite Oasis Dryer with Airflow problem
same problem removed back cover cleaned lint found pulley had unscrewed and belt was off.installed pulley rev threded and put belt back on.
Mar 02, 2008 | Kenmore Elite HE4 Electric Dryer
Error code AF Whirlpool cabrio dryer. Anyone have a clue what this error code means?
I found the answer to the code AF also and it means the air flow is blocked. I checked my dryer vent on the outside and it was clear. However when I removed the dryer duct it was clogged just inside the machine. I had washed and dried a blanket that shed alot!
Dec 05, 2007 | Dryers
Kenmore Elite Oasis ST 6807 Dryer Logo
69 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
