Question about Crayola Crayon Maker
04-9020-0-600 we need a replacement for the mold
    Problem Solver:
  • 19 Answers
If you look at the back there is a sheet where you can order new molds
Posted on Apr 17, 2014
Removing/replacing right rear molding on 1999 Mercury Grand Marquis
  1. The molding on the right rear of a 1999 grand marqui is simple to remove & does not take any special tools.
  2. The molding has a sticky back on it but can be pulled off by hand.
  3. The ends that stick through the holes in the finder are held in place by a soft epoxy & have to be cut with a knife or razor.
  4. After you cut it, pull it out of the hole & pull the molding out of the grove.
  5. After market molding can be purchased at most auto parts stores.
  6. Make sure to clean all epoxy from the ends & the glue that was on the back of the molding.
  7. Save the old molding so you can cut the new molding in the same way. It comes in a role & not cut individually for you.
  8. hope this helps.
  • Malcolm Sanford
Sep 13, 2016 | 1999 Mercury Grand Marquis
2006 Tahoe. Where is the auxiliary blower motor located?
It is located behind the right rear quarter panel , In the back right of the interior !
Remove the right rear quarter trim panel. Refer to Rear Quarter Trim Panel Replacement - Right Side in Interior Trim.
Removal Procedure
  1. Remove the rear seat. Refer to Rear Number 2 Seat Replacement or Rear Number 2 50-50 Seat Replacement in Seats.
  2. Remove the Third Pillar trim panel. Refer to Third Pillar Trim Replacement .
  3. Remove the garnish molding. Refer to Body Rear Corner Garnish Molding Replacement .
  4. Remove the door sill plate. Refer to Liftgate Door Sill Plate Replacement .
  5. Remove the quarter panel trim screws.
A lot involved in this but not to difficult !
  1. Remove the rear door sill trim plate. Refer to Front Side Door Sill Plate Replacement or to Rear Side Door Sill Plate Replacement .
  2. Remove the lower rear seat belt cover and bolt.
  3. Remove the trim panel from the vehicle.
Remove the sill plate. Firmly pull the sill plate up and out from the retainers.
Remove the sill plate from the vehicle. Start from the front of the door sill. Use a flat-bladed tool in order to pry the door sill plate.
Rear Side Door Sill Trim Plate Replacement
Use a flat-bladed tool in order to pry the door sill plate. Remove the sill plate from the vehicle.
Remove the rear upper garnish molding. Refer to Rear Upper Garnish Molding Replacement .
Pull down on the upper corners of the garnish molding in order to disengage the retaining clips. Pull in order to disengage the remaining retaining clips. Remove the rear corner garnish molding from the vehicle. Inspect the rear corner garnish molding for broken or missing retaining clips. Replace the retaining clips as needed.
Good Luck ! Fun job !!!!!
Jun 07, 2015 | 2006 Chevrolet Tahoe
Major mold around the rubber "drum"...tried everything to remove it but nothing has worked. How easy would it be to replace it? Help please!!!
You would need to pull it out of the track that is around the door panel itself and replace it with the new gasket. You may have up to 4 screws or clamps to help keep something like this in place. Make sure to keep the door cracked to help let water evaporate and not grow mold. Also, as in most Owner's Manuals, you are to clean it with bleach or vinegar to help prevent mold. Once mold grows, you can kill the bacteria from spreading, but mold stains and will always look like it is dirty.
Sep 23, 2012 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool Gold side by sideGC3PHEXNS00 not making ice but the water works. Already replaced the filter.
put your finger in the ice mold and see if there is ICE in the mold. if no ice then use a turkey baster and put approx 1/4 cup of water into the ice mold, slowly. in about 2 hrs you should hear ice drop and then refill with water. if there is ice in the mold, you most likely need a new ice maker.
Jan 02, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Benchmark fiberglass front door molding around oval leaded glass has cracked and has caused the whole oval to slip down. Can the molding be replaced? Can provide picture if needed.
Steel entry oval ring holding in glass has been knocked out by large dog. The glass is still in tact but the oval molding is damaged. Can just the oval molding be ordered and do you have installers to perform the work? Thanks!
May 20, 2011 | Garden
I have a magic chef refrigerator model RB19KN3A serial no. DS37919804 . It was left with the house when I bought it. Wondering what year this model is and the molding around refrigerator is breaking away....
Yes, the molding can be replaced. All you need to do is provide your model number and make to www.repairclinic.com and they'll point you in the right direction.
Mar 09, 2011 | Refrigerators
I need a replacement mold for a Crayola Crayon Maker CODE #04-9020.
Hi, replacement mold can be found easily on amazon, click here and take a look: Amazon com crayola crayon maker mold. Best of luck
Nov 28, 2010 | Crayola Toys
The door seal has mold and mildew. It really
first try to clean it with clorox bleach. or some bathroom mold cleaner scrubing bubbles, ect
and if it still needs to be changed look on the computer and find the part shipped to you.
Jul 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flimsy black plastic ice cube mold has dropped into ice service. Ice maker still works. Does this require service?
The teflon is starting to peel off the icemaker. You will need to replace the mold or the complete icemaker. Usually this happens when you turn the unit off and leave the water sit in the mold. To prevent this you should turn the water supply off and let the unit run for at least another hour to make sure the water is out of the system and mold.
Jun 26, 2009 | Refrigerators
Need to replace calypso washer...sugestions
The mold problem is from too much detergent usage.  Manufacturers recommend only 2 tablespoons of detergent per wash to avoid any mold issues.  It may not say it in the owners manual but it is from the manufacturers themselves.
Jul 18, 2008 | LG WM2688HWM TROMM SteamWasher
Crayola Crayon Maker Logo
228 people viewed this question
Top Crayola Toys Experts
Tom Chichester
Lawrence Oravetz
Cristal  Nash
Cristal Nash
Level 1 Expert
Are you a Crayola Toy Expert? Answer questions, earn points and help others
