Mp252 Audio Codes problem
I reset my router with reset button.When i wont to aces from my browser with http://192.168.2.1 and when i wrote User Name:admin Password (case sensitive):admin i get Login failed, please try again: .Problem is like old password is not reset to default or i dont write good default password.Please help...
    Problem Solver:
  • 13 Answers
Maybe admin/1234 or you did not reset it, hold the reset button longer
Posted on Apr 25, 2014
mattballew
  • 89 Answers
SOURCE: CAN NOT OPEN DEFAULT USER NAME / PASSWORD, ADMIN/ADMIN
On the back of the device, There is a small reset button, Hold that with a pen for 30 Seconds, that will reset everything, Including that password.
Posted on Nov 25, 2008
  • 6 Answers
SOURCE: Reset Password
please post the model name of the router
Posted on Aug 23, 2007
SOURCE: Please help me to save SpeedStream 6300
Maybe try pressing the reset button on the back of the router. It'll reset everything but at least you'll be able to get into your router
Posted on Jul 17, 2008
the q guy
  • 393 Answers
SOURCE: My neighbor uses my wireless. When i try to log in on the motorola sbg900 site by using http://192.168.100.1/index.asp in the URL bar i can not use the default user name and password to get on or find
contact your service provider and they can walk you through it step by step
Posted on Apr 27, 2009
sk8er1707
  • 58 Answers
SOURCE: I have a Westell router through Verizon. My
sometimes the default gateway is not always 192.168.1.1 sometimes it is actualy your ip adress for example 192.168.0.1 but that won't always work so go to command prompt and type 'ipconfig" and press enter first try your ip and then try the default gateway... for any more help please pm me for any more help...
Posted on Jun 06, 2009
Need correct username and password for wrt54g
Reset Button
Note:
Resetting the router to the factory defaults will delete any changes you have made to the router, including any security settings. This should be used as a last resort.
The first method involves simply pressing a button located on the back of the router. The image below (courtesy of Linksys) shows where the button is located.
Linksys WRT54G Reset Button Location
To reset your router, use the following steps:
  1. Press the reset button for 30 seconds.
  2. The settings should now be returned to the factory default settings, meaning any changes you had made would be deleted.
  3. Open up your Web browser and enter "192.168.1.1? in the address bar.
  4. For the login, leave a blank ID and enter "admin" as the password.
Jun 18, 2011 | Linksys Wireless-G WRT54G Router
I'm trying to use my router for my I-pad but I don't remember and can't find where I wrote my password and wep access code
you will need to go to a station that IS connected to the router (preferable wired) and open a browser to HTTP://192.168.1.1
admin should be both the username password.
go into your wireless security setup, and look up or change your WEP key.
Use this WEP key in your I-Pad, and VOILA, you're connected.
If you have any further issues, post a reply to this thread.
Feb 24, 2011 | EnGenius (ESR9850) Router
I forgot my password and cant get on the internet how do i fix
If you can remember your password,reset the linksys router.
To reset the router using the reset button, use these steps:
1.Look for the red reset button at the back of the router.
2.Press and hold the reset button for approximately 5 seconds.
To acces the router configuration panel -open your browser(Internet Explore,Firefox..)
Type http://192.168.1.1 to acces your pages. Enter user name and password,leave user name blank and enter admin as the password.
Good Luck!
Jan 21, 2011 | Linksys WRT160N Wireless Router
What is my WEP key?
open a browser - clear the address bar - type in
192-168.1.1 - then in the password - forget the username unless u set it - in the password type in 'admin' - just admin that's it -
the go to security - - hunt around and you will see your wep numbers - there will be 4 of them most likely - pick one -
Gary
May 08, 2010 | Actiontec GT704WG Wireless Router...
Di624
reset your router
should be a reset button on the back,
hold in till the lights on the front flash then its reset open explorer browser
type in 10.1.1.1
log in as Administrator
add new user
set password while adding new user
save your new settings(write them down too)
test the internet for function
if no function then contact your ISP to assist with connection to internet
all sorted now please rate me MISTERDJ
Apr 11, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
I need pin number for my Belkin router F5D7234-4 v-1000
If you have forgotten your WEP Key and need to start over you will have to reset your router. On the back
The "Reset" button is used in rare cases when the Router may function improperly. Resetting the Router will restore the Router's normal operation while maintaining the programmed settings. You can also restore the factory default setting by using the "Reset" button. Use the restore option in instances where you may have forgotten your login password.
Push and release the "Reset" button. The lights on the Router will momentarily flash. The "router" light will begin to blink. When the "router" light becomse solid again, the reset is complete.
Restoring the Factory Defaults
Press and hold the "Reset" button for at least 10 seconds, then release it. The lights on the Router will momentarily flash, The "router" light will begin to blink. When the "router" light becomes solid again, the reset is complete.
Configure the Router Using the Web-Based
Using your Internet browser, you can access the Router’s Web-Based
Advanced User Interface. In your browser, type “192.168.2.1” (you do not
need to type in anything else such as “http://” or “www”). Then press
the “Enter” key.
Logging into the Router
You will see the Router’s home page in your browser window. The home
page is visible to any user who wants to see it. To make any changes
to the Router’s settings, you have to log in. Clicking the “Login” button
or clicking on any one of the links on the home page will take you to
the login screen. The Router ships with no password entered. In the
login screen, leave the password blank and click the “Submit” button to
log in.
Jan 31, 2010 | Belkin Computers & Internet
How reset passsword.? router
Dear arliwave
It is easy to Reset Router than to locate its User name and password,
To reset your router, first of all switch on your router and press its reset button for 10 seconds. While with pressed reset button switch off power of router than after 5 seconds release the reset button. Now your router is reset to its default position.
At default its user name and password are " admin " .
For browsing to router site type http://192.168.1.1 or http://192.168.2.1 in your browser address bar.Enter by using admin as user name and password.
Thanks for sharing your problem with Fix Ya Family
Jul 29, 2009
Jul 11, 2009 | Zhone (6218-I2-200) Router
Password not working
1. Reset the router.
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
Try other browsers like Internet Explorer, Mozilla Firefox, Netscape, etc.
If you still cannot access the routers page, try another computer and connect it on your router. Then repeat the steps.
2. Access the web-based utility of the router.
a. Open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. For security reasons, the router has its own user name and password. When prompted, enter admin for the user name and password for the password, both in lower case letters.
Jul 02, 2009 | NetGear RP614 Router
I can not aces in my ruter i frogoth my user name end pasword please help me
My name is Armymason, I have the solution to your problem. You need to reset the Router http://office.manualsonline.com/manuals/mfg/dlink_systems/di514_1.html here is the manual in it should explain how to do a hard reset. I believe for that model you need to have it unplugged and use a pin to hold in the reset button, while holding the reset plug in the router and wait 5 seconds before releasing the reset button. Now it should be set back to factory and all you have to do is enter in the default user name and password. Of course doing this you will have to reset all your settings.
If this solution isnt satisfactory, I suggest using our Premium service.
Thanks,
Armymason
Feb 24, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
