Vizio e421va picture going black
Vizio picture shows on screen at power up but then screen goes to mostly black with sometimes vertical lines (like interference or something. Mfg date Oct 2010. serial LTLNIBCL4200972. I can see the uverse menu at the very top behind the black but it is like someone holding a black sheet across it so I can't read the menu. Have the back off, only 3 boards. Nothing obvious to me on the boards, but that is not my area of expertise.
  • 2 more comments
  • Sandy Guenther
    Sandy Guenther Apr 18, 2014
    I think I got it working, at least temporarily. I do think something is going out but it looks like it is going to be intermitent. This is the 2nd time it happened when I turned the set on in the last couple months. I finally plugged in a dvd player and messed with it until I could get enough picture to be able to see the menu and reset factory defaults. so far I have picture. but question now is, if it goes out again, which board is the likely culpret?
  • Sandy Guenther
    Sandy Guenther Apr 28, 2014
    It was a temporary fix. I still need to figure out what board is going out. Looks like if the tv is off for a long weekend....it happens. I get black screen (Except for at the top) and I have to mess with it. Once warmed up I can sometimes get the picture back. but it is struggles with horizontal split screens etc. But when it comes back it stays on.
  • Sandy Guenther
    I included 2 pictures. One is with the menu on, it drags white lines down. The other is when I almost got the picture back. there was a horizontal break which was moving at different speeds it seemed. sometimes freezing. it eventually works itself out. But something is definately going out.
  • Sandy Guenther
    photos of issue
    Master:
  • 687 Answers
POSSIBLY T-con pcb, but check the cables between the T-con & the panel & the cables between the t-con & main pcb.
Try unplugging & reconnecting those same cable links. When disconnected look at the condition of the cables & boards. your looking for signs of arcing or corrosion.
Posted on May 09, 2014
  • 3422 Answers
SOURCE: Vertical Black Line
HI,
First thing to do is the reset and the whacking test. I give this a 50/50 chance of clearing it up.
ONE: Disconnect the power cord for 4 hours. Then when you power it back up the internal soft codes will automatically reset to factory defaults.
TWO: The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
If these two procedures do nothing then:
The manual always knows the best.Go through the manual carefully and u will find the solution to ur problem..
Goodluck and Kind Regards
Please Don't forget to rate me as fixya..
Posted on Feb 02, 2008
budmrtn
  • 11361 Answers
SOURCE: I have a Vizio VW46LFHDTV10A - the problem is the
It can be main board, T-CON, or LCD panel. I would try reseating the ribbon cables between the T-CON and the LCD panel first.Unless you have service manual and scope to look at the signals it will be difficult to be 100% for sure as to which board is bad, the repair guy will more likely to do board swapping, starting with the T-CON board.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you fin
Posted on Oct 29, 2010
tunde007
  • 2382 Answers
SOURCE: I have a Vizio LCD
Hi, vertical lines when the television is on may be related to issues with the television's screen resolution. Resolutions set higher than 1280 by 720 can create visual disturbances on the screen. You can reset the resolution through the control panel's display settings menu. This should correct the issue immediately, although you may need to power the television off and then on again in some cases..
Posted on Mar 26, 2011
budmrtn
  • 11361 Answers
SOURCE: We recieved a 46" LCD
You will have get to the T-CON board assembly which can be difficult and reset the ribbon cables between the T-CON board and the LCD panel, if you have never work or repair LCD TV before, you can really do bad damage to the TV. The T-CON board itself can be bad. You should go here and learn about it first.
http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
http://www.mediafire.com/?zzjygannjty PDF download
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on May 21, 2011
  • 11800 Answers
SOURCE: I have a Samsung LN46A650 LCD TV and recently I
Yes, it's the t-con board, a well know problem in this tv. Here it is
http://www.partstore.com/Part/Samsung/Samsung/LN46A650/Samsung/Samsung/BN8101697A/New.aspx
Posted on Sep 13, 2011
Vizio Model# E3D42OVX. Black vertical lines on start up except for top 2"s of screen.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Feb 18, 2017 | Vizio Televison & Video
How do I fix my Vizio TV model E421VA? Details are below. It has a black screen and no audio.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Nov 01, 2016 | Vizio Televison & Video
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
Black line or crack
Most likely LCD Panel & not economical to repair: See this site for part#, price & availability:
http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+E421VA&restrictBy[master+part+type]=Panel
Nov 24, 2013 | Vizio E421VA 42-Inch 1080p LCD HDTV, Black
Vizio vertical line
http://electro-medical.blogspot.com/
Apr 03, 2017 | Televison & Video
VIZIO E550VL
Replace the main board the eprom has an issue. You can get the replacement main board from www.tvcircuitboards.com
Dec 14, 2012 | Vizio E550VL 55 in. LCD HDTV
No picture on intermittent basis -
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 27, 2012 | Vizio GV47LF Television
I just bought a Vizio E421VA last week. When trying to change the picture settings (brightness/contrast) using the Vizio remote, sometimes it just turns off all of a sudden. This also happened while I...
Hello, my name is Dan Busa with DISH Network. I happen to have seen this with other Vizio TV sets and would be very interested in taking a look into this. Even if you have resolved this please e-mail me at: daniel.busa@dishnetwork.com
Daniel Busa
DISH Network
Customer Service
Mar 21, 2011 | Vizio E421VA 42 in. LCD TV
I have a vertical black line on the middle of the
You have A buffer board out if the line goes up and down then its the long board going left from right look were the line is and see what board the line lines up on the screen and replace that one
these boards are the closet to the edge of the tv
same process if the line goes across the screen
look for the part number on the board and search with google or go to shopjimmys.com and seach there or call them
Oct 19, 2009 | Vizio Televison & Video
Sony kv35s66: No picture, just sound and red blinking
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
