Question about HP Photosmart D7360 All-In-One InkJet Printer
How to remove Print head on HP D7360
How to remove the print head to clean it on my HP PhotoSmart D7360
4 Suggested Answers
  • 352 Answers
SOURCE: My HP Photosmart D7360 will
Hi rfillmore, I would suggest you update your printer drivers, try this, follow instructions exactly as written:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Posted on Oct 21, 2008
anantakumarj
  • 330 Answers
SOURCE: Cannot print 5x7 photo on Photosmart D7360,
if you dont hvae 5x7 option you can creat your won setting open printer adn faxes ...>goto file ..>server properties there you can creat it......
Posted on Oct 30, 2009
  • 5186 Answers
SOURCE: How do I clean the print heads on my Photosmart
You can get a download of the manual from HP:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=emea_africa&lang=en&product=57595&
The self-clean cycle of the cartridges can be accessed from the LCD or the software on your computer.
To manually cleaning the cartridges:
Remove the cartridge from the printer. Dip a cotton swab in distilled water and squeeze out any excess water. While holding the cartridge by its top, wipe off the face and edges of the cartridge. Do not wipe the nozzle plate (that could damage the cartridge). Replace the cartridge in the printer. Please note: if the cartridge is out of the printer for more than 30 minutes, the ink could start to dry out and not be usable.
The print heads are part of the cartridge.
I hope this helps.
Posted on Mar 28, 2010
Testimonial: "Clear and succinct advice!"
Photosmart D7360 - message says "ink cartridge empty. To print in color, install the following cartridges: yellow. To print in black ink only, press o.k." I have replaced the cartridge (yellow) and the...
go to hp support>d 7360 >software and drivers. Download (run) latest diagnostic utility 2010-11-09. run test and print test page (only one sentence). worked for me. Took about one minute.
Sep 10, 2010 | HP Photosmart D7360 All-In-One InkJet...
Photosmart D7360 leaks black ink out the bottom of the case, below where printer head parks. Otherwise works fine.
Its a sponge in the drip tray underneath the print head. It tends to fill up, especially if you're cleaning your print head quite often.
Its full of ink, and so needs to be dried out. The easiest way would be take it out, rinse it under the tap and leave it somewhere warm to dry out.
If you can't take it out, try and decant the ink, blotting paper, sponge as best you can and give it a while to dry.
May 08, 2010 | HP Photosmart D7160 InkJet Printer
No I see no solution noted here. again Photosmart D7360 error message 0xc18a0001 ink system failure.
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to usethe Magic Inkjet Flush kit to soak the print head and you should beprinting again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Also this may help...
HP 145 Sequence HP D145 all-in-one printer
http://magicinkjetflush.com/images/PDF/HP_135_Sequence.pdf
or smaller file
http://magicinkjetflush.com/images/HP_135_Sequence.jpg
Good Luck!
Tinteiros (Ebay)
Oct 31, 2009 | HP Photosmart D7360 All-In-One InkJet...
Oct 30, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
How to take apart HP photosmart D7360
My HP D7360 won't print. Its says the "ink system has failed. Unable to print. Refer to printer Doc. Error: 0xc05d1281" Now, I lifted the printer up and it sounds like a screw bouncing around on the inside. How do I take this thing apart to find the screw and put it back in it's place???
Aug 27, 2009 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart D7360
try to align the print cartridge. go to settings -> tools then choose align printer. you may also try to clean the print head.
Nov 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart D7360
HP support decided it could not be repaired on line, agreed to replace it but found it was a few days out of waranty...so it is dead in the water. Probably not cost effective to repair it.
Aug 03, 2008 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart D7360
try cleaning the cartridge contacts with alcohol and cotton swab.
Jan 16, 2008 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart D7360 All-In-One InkJet Printer Logo
76 people viewed this question
Seeker5211
Seeker5211
