Question about Magellan RoadMate 6000T 980874-01 3.5-Inch Bluetooth Portable GPS Navigator
Can not turn on
I ordered the device used from amazon. it did not come with a charger and will not power up, please advise
  • 75 Answers
Have you talked to the seller? Try to work it out with them. Is it Amazon Fulfilled. You can research all this on Amazon so why are you asking for help. Talk to them
Posted on Apr 16, 2014
    Guru:
  • 135 Answers
Please order a charger like this one
HiSense Sero 7 tablet. Why no charge, no power?
About 1,620 results (0.80 seconds) Search Results
    HQRP USB to micro USB Cable / USB Charging Cable for ...
    www.amazon.com > ... > USB Cables
    Amazon.com, Inc.
    Rating: 2.9 - ‎22 reviews
    1A AC Wall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA .... If you try to use the tablet while it is being charged, no charging will take place.
    HQRP AC Adapter / Battery Charger / micro USB Charging ...
    Amazon.com, Inc.
    Rating: 3.7 - ‎6 reviews
    HQRP USB to micro USB Cable / USB Charging Cable for Hisense Sero 7 LT E270BSA / Hisense... ... HQRP Micro-USB AC Adapter rapidly charges your Cell Phone / Tablet PC ... This one does not. ... Yes No Sending feedback. ... $3.91. 1A ACWall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA Tablet.
    HQRP AC Adapter Dual microUSB Charging Cable for ...
    www.amazon.com/HQRP-Adapter-microUSB-Chargin...
    Amazon.com, Inc.HQRP AC Adapter Dual microUSB Charging Cable for Hisense Sero 7 LT E270BSA... Do not wait until charging one of your devices to charge the second.
Feb 09, 2016 | Tablets & eReaders
Ineed a dc5vv2.0a that came with it I get other for it and do'not work and the usb is not work if did not come with the moblenab12-nv7a please help
If using the supplied / original BLACK and WHITE USB cord, the black must be used for charging. The white is for data transfer only and lacks connections for power / charging.
Most USB chargers will output 1 amp or less. Many USB jacks on computers output between .5 and 1 amp - max. Your device calls for a charger with 2 amps output. Connecting to devices such as those mentioned above can overload and damage the charger or computer - don't use them!
USB ports have standard connections or "pinouts". You should obtain a USB charger (5V DC) rated for 2 amps (or more for better performance). Be sure to select one with matching USB connector (compatible with your device) - mini, micro, etc.
Amazon has several from which to choose:
Amazon com nabi2 nv7a charger
Nov 12, 2015 | Nabi 2
Kindle fire will not charge-got a new charger and it still will not charge- does it need anew battery and how do I do that?
The Kindle touch and the Kindle FIre are great devices for your reading needs. However, there are times when it becomes unresponsive and freezes on you. Amazon says it is because the battery isn't charged properly or does not have enough power on it. It is advisable to charge your battery first before trying to reset the Kindle touch/Fire. If theKindle still has issues, then try the steps below on how to reset your Kindle touch/fire. Please note that you may lose your data during the reset process, make sure you have made a backup of your files before proceding.
  • Hard and soft reset
    Make sure the Kindle is turned ON.
  • Press the Power button for 20-30 seconds until it turns OFF.
  • Wait for it to reboot, if it doesn't press the power button to turn it ON.
  • Your kindle should be back to a responsive state.
  • this might help you.
Dec 22, 2014 | Amazon Kindle Fire HD
My screen froze on a page. It will not connect to my computer either
Dear Stephen,
These are the steps used in order to reset your Kindle (taken directly from instructions from Amazon):
"Follow these steps to restart your device. These steps will not remove content from your device.
1. Press or slide and hold the power button for 20 seconds.
2. After 6 to 8 seconds, the screen will go blank. This is normal. Continue to hold the bower button.
3. After another 20 seconds, release the power button. The charge indicator light will turn on after a few moments. For Kindle Fire, press the power button again.
4. Your Kindle will successfully restart.
You can find these steps, with a timer, here:https://www.amazon.com/gp/help/customer/display.html/ref=kindle_help_forum_faq?_encoding=UTF8&nodeId=200829000#restart
Remember that your Kindle must have some charge in order for you to be able to reset it, otherwise, connect the cable to a USB port or power charger for some twenty minutes before attempting to reset it.
Hope you may find this information helpful!
Regards,
Miguel L. Martins
Sep 28, 2013 | Amazon Kindle 1
My kindle won t turn on
Her is a possible solution:
1. Plug into the original charger, hold the power down for a full 30 seconds, release. Let charge in this state for 12 hours.
2. Lease the device plugged into the charger, while you have the device plugged into power, press the power button for a full 40 seconds, release. Wait for 5 seconds and then press and release the power button. Did the device wake up? No, continue to step 3.
3. Plug the device into another charger, if you do not have an charger from another phone go to Staples or Radio Shack pick up a new Kindle or Universal charger, make sure you can return the charger.
4. Plug the Kindle into the new or alternate charger. Hold down the power button for 30 seconds release. Let charge for 12 full hours.
5. Unplug the Kindle from the charger.
6. Press the power button for 40 seconds - time it. Release the power button, wait for 5 seconds, then press and release the power button. The Kindle should wake up. If not, proceed to step 7.
7. If you can not wake up the Kindle from a 'hard reset' the Contact Amazon directly for a replacement.
May 25, 2013 | Amazon Kindle Fire HD
Kindle will not turn on
The Kindle Fire will not turn on, correct? Let's try a hard reset.
Step 1: Unplug the device from the charger
Step 2: Press and hold the power button for 30 seconds
Step 3: Release the power button, then press and release the power button normally, the Kindle should wake up
Step 4: If the Kindle does not wake up, find an alternate charger or go down to Radio Shack or Staples and get a new charger
Step 5: Plug in the new Charger to the Kindle for 12 hours when done leave the Kindle plugged into the charger
Step 6: While the Kindle is plugged into the charger, press and hold the power button for 30 seconds. Let the Kindle charge for another hour.
Step 7: Pickup the Kindle, press and release the power button normally, the Kindle should now wake up.
Step 8: If the Kindle does not respond, contact Amazon for a replacememnt
Apr 21, 2013 | Amazon Kindle Fire HD
My Kindle will not TURN ON!!!!! THE INDICATOR LIGHT WONT EVEN COME ON!!! WHAT DO I DO???
  1. Connect the device to the charger (if you got one, in some countries Amazon does not include a separate charger). Otherwise use the provided USB cable and connect it to a PC.
  2. Does the light come up now? While charging, there should be a constant amber light that turns into green when the device is fully charged.
  3. If there is no light, your Kindle, cable or charger is broken and you should contact Amazon Kindle support for a replacement / repair.
  4. If the light went on, wait until it turns green.
  5. Slide and hold the on switch until after the power light blinks three times. This should happen after about 5 seconds of holding.
  6. Release the switch and wait for the device to boot up.
  7. If there is still no reaction, contact Amazon Kindle support for repair or replacement options.
Jan 04, 2011 | Amazon Kindle 3G
Kindle will not charge from out let or computer
Please clarify: what charger did you use to connect to an outlet? The Kindle 3 comes with an USB cable to charge from a PC or Mac computer and no charger outside for many countries outside the US (for other countries an external charger is available from Amazon as optional accessory). Use of a different charger (e.g. mobile phone charger with USB connector) is not supported, not recommended and may fry your Kindle if a wrong voltage is hooked to it.
Things you can try:
  1. Use a different outlet to charge the Kindle.
  2. If you use the supplied USB cable to connect to a PC, make sure its firmly seated on both ends. Connect to a powered USB port directly on your computer. Some external USB hubs do not come with a separate power supply (external power supply is mandatory for an USB 2.0 hub, some cheap models are sold without one anyway) and are not suited to charge anything. Just to make sure, disconnect any other USB device except mouse / keyboard to check if the USB port in use is not burdened by too much drain.
  3. The Kindle power LED should glow amber while charging and green if the device is fully charged.
  4. Give the Kindle a reset pressing Home --> Menu --> Settings --> Menu and select "Restart." If the charge light is on but the device is still not charging, contact Amazon customer service.
  5. If the charge light does not light, the AC adapter or cable needs to be replaced.
  6. Contact Amazon customer support for any warranty issues.
Jan 01, 2011 | Amazon Kindle 3G
I was having problems with the car charger CA-051, then, I used a T-Mobile charger, at first time worked, after that, the GPS Maagellan was dead. Is it possible that I have to order a new battery? or I...
Using non standard chargers is probably the problem. If the battery has suddenly become sogged since using this charger then it may have done more damage than you want to know about.
Was it the correct polarity +ve Tip? was it the right amperage?
Magellan are specific in recommending you only use their charger and with reason, its correctly made for it.
You can try the new battery angle, but get advice on the charger.
As a small note.. Car chargers do NOT fully recharge batteries in GPS. Use an AC or USB charger. The car charger is a maintenance power supply. Always fully charge the unit prior to use and do not plug to car power until engine has been started.
These are standard rules with all non hard wired GPS and phones, ( but not always in the manual, have to have service and new sales someway!)
Please rate my help++++Thanks for using FIXYA
Aug 11, 2010 | Magellan RoadMate™ 1212 Car GPS Receiver
Hi, my son has an alba dvd player and the charger needs replacing
You can buy universal power supply at electronic stores, put in list this information when buying, Your device is 9Volts and consuming 2.2 amperes of current, so this should be the rating of your powersuply, ask help for the attendant to set the settings that will match your device look for the polarity shown on your device...
This polarity states the voltage orientation, once you neglect this, your device will be permanently destroyed and burn...
Oct 21, 2009 | Televison & Video
Magellan RoadMate 6000T 980874-01 3.5-Inch Bluetooth Portable GPS Navigator Logo
51 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
