Question about Vizio E421VA 42 in. LCD TV
Vizio picture going black except for very top. can partially see menu at top but like a black sheet covering most of it
When the set powers up the vizio picture shows on screen but then when it fully powers up and I hit my uverse menu, I can see the very top but can't see anything or read anything below as it is all black with sometimes vertical "interference type" lines. The sticker in the back says Mfg date Oct 2010 serial LTNIBCL4200972
2 Suggested Answers
tunde007
  • 2382 Answers
SOURCE: I have a Vizio LCD
Hi, vertical lines when the television is on may be related to issues with the television's screen resolution. Resolutions set higher than 1280 by 720 can create visual disturbances on the screen. You can reset the resolution through the control panel's display settings menu. This should correct the issue immediately, although you may need to power the television off and then on again in some cases..
Posted on Mar 26, 2011
I have a Vizio E320VL with a video problem.
The Tcon boar or the LCD panel is faulty. You have to replace the TCON board to confirm it.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 05, 2016 | Vizio E320VL 32 in. HD Ready LCD TV
I have a Vizio M701d-A3 with single line across the top half of my screen, it appears over top of the menu when displayed. The line is not black but changes color with the picture. What's the problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 07, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Vizio e421va picture going black
POSSIBLY T-con pcb, but check the cables between the T-con & the panel & the cables between the t-con & main pcb.
Try unplugging & reconnecting those same cable links. When disconnected look at the condition of the cables & boards. your looking for signs of arcing or corrosion.
Apr 16, 2014 | Televison & Video
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
Screen is completely black except for about 4 inches on top......
Try a reset of the display device or hit the menu button to get a display on the screen- If you get a full picture that way then you have some setting set wrong. It could also be a PIP- picture in picture mode that you only have one source put into the TV rather than two.
Aug 10, 2012 | Vizio SV320XVT 32 in. TV
I have sound but no picture.
go to the tv menu and disable the text function
May 20, 2012 | Vizio 42 in. LCD TV
My JVC model AV-20F476 has a black-out box that covers most of the bottom half of the screen.
Go into menu and under CLOSED CAPTIONS look to see if TEXT is engaged---if it is set to text 1 turn it off or to text 2,3,4, etc
Text was a feature never really used but it is there, some cable boxes also have this setting/feature.
Let me know if you have questions.
Jan 11, 2012 | JVC Televison & Video
I have a Vizio VW37LHDTV10A LCD t.v. set that was built in august 2007. The power will come on and I can see the back light turn on. However, the screen stays black and there is no picture or sound. Then...
My friend, I recently fixed a vizio vw37l with the same problem but it was the lcd controller.
hope this helps a bit to diagnose your problem
Aug 27, 2010 | Televison & Video
Vizio E421VA 42 in. LCD TV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
