Question about Humminbird 595c GPS Receiver
Connecting cable Where do I connect the cable from the Sonar Stig
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
Got a HDS 5 and im getting bad or false on my sonar when traveling showing fish and structure.When trying to hold ground and im backing up it doesn't even read?i have it on auto sensitivity
Check the mounting and cable connection of the transducer on the stern. If loose will tilt during movement, in reverse wakes from the prop. CAREFULLY check unit during these conditions. The transducer needs to be completely submerged. Good Luck.
Jan 13, 2012 | Lowrance HDS 5 X Sonar ()
When i turn the fish finder on,sonar failure is coming up,what does that mean?
This indicactes the sonar sensor unit is malfunctioning or it's disconnected (or the cable connecting it is damaged). You will have to check it - ideally using another central unit. If the unit is damaged then you will have to either attempt at fixing it yourself by cutting the cable and the housing open, locating the fault and fixing it or just by replacing the entire system since you can't replace the sensor alone- it's not sold separately or available as a replacement part.
BTW sending it to be fixed is not an option, it would cost you over $150 which is well above what this unit sells for when new
Jul 29, 2011 | Garmin Fishfinder 90
1TB Hard drive is making a beeping noise like a sonar beep. and wont read on the computer. anyone know why?
There could be an issue with the enclosure hardware, but more than likely your drive itself has a hardware problem. If you don't care about the warranty just the data you should remove the drive from the enclosure and try connecting it to another desktop.
Let me know what happens and I can help.
Mar 23, 2011 | Computers & Internet
Need to connect to a sound blaster live sound card for recording using sonar as recording program. hace had it in storage for sometime and can't remember what went where
This particular mixer offers a usb (2 channel connection) that can be simply plugged into the computer usb 2.0. These channels should be available in Sonar from the channel Input/output drop boxes. You may need to restart Sonar, the mixer or both for them to be recognized. You may also need to run the Wav Profiler in Sonar. Typically the Wave Profiler is found in the Options>Audio menu but may be different on each edition of Sonar. The above info is for Sonar 7.
If you are wanting to record several channels at once then I would recommend connecting your Mixer's Direct Outputs from each channel to a corresponding input of the soundblaster if your soundblaster supports multiple channels. And then use the usb outbut from the Sonar to monitor the computer playback of your master stereo channel. Or, you may connect the soundblaster outputs to unused channels of the mixer or to the tape return or auxilary inputs to monitor the computer playback on the mixer.
Alternately you can send the signal to your soundblaster via the buss outputs. This will limit the number of simaltanious output channels to the number of busses on the mixer, but you can send any mixer channel to any buss without unplugging the instruments or mics.
Here's the link to the page where you can download the free pdf manual for this mixer. Page 14 explains the output connections and has diagrams.
http://www.behringer.com/EN/Products/2442FX.aspx
Oct 09, 2010 | Behringer XENYX 2442FX Mixer
Computer stops responding or sound just stops on Sonar 7 with Vista. Confused whether to set Sonar to use ASIO driver or MME or the other one I can't think of now. Dan
Hi
The most compatible driver would be the one detected by Vista in Windows Update. Give that a try and see if it can find a hardware device driver for the Sonar. Ensure the Sonar is connected and on before you check for updates (Start > All Programs > Windows/Microsoft Update).
Oct 11, 2009 | Tascam US-144 Sound Card
Sonar inop at most times . onec in a while it works fine
(1) bad transducer. (2) bad ground from unit to battery. The cable next to the battery will have no effect.
Sep 05, 2009 | Lowrance Lms 522c Sonar Gps Chartplotter...
I have a lowrance LMS 332C GPS. After 5 years I
The LGC-2000 is bad would be the most likely cause, but if this started right after you changed the cables, Try connecting the NMEA 2000 network to a different power source than the main power. If you still have the original cables, and you didn't have the problem before, try using those again to make sure there isn't anything wrong with any of the new cables.
But most likely, the LGC-2000 is toast and you will want to contact Lowrance support to see about getting it repaired/replaced.
Jul 04, 2009 | Lowrance LMS-332C GPS Receiver
Minn Kota lower unit leaking. Have brush replacement kit. How do I insure a good seal upon reassembly?
Man, you have a job ahead of you. First, if the unbreakable shaft is cracked or broken, you will have to replace it, for it will leak into the motor too. If your unit has the sonar sensor in the front and it has had water in it, the unit can corrode severely and need a lot of parts besides seals. The wiring to the sonar runs in a protective shield bonded to the magnet housing and one of the long screws holds it in there. Remember to take the wiring to the sonar out AFTER you remove the big motor feed wires, and replace it BEFORE you reinstall the red and black cables. Some grease seems to ensure the o'rings slide on metal parts during reassembly rather than tear. It's quite a job.
Jul 07, 2008 | Minn Kota 55 AutoPilot Universal Sonar...
Sonar Producer 6 - Audio/midi devices/controller-surfaces..Which settings??
o always run at 0 on play back recording -3 with drums use anlog cables then select anlog 48000 24 bit if u can if its digital cable might use 96000 bit rate ok spdif watch it close on digital for digital clips never go in red keep steady balence cheak your sorse tape how loud is that adjust your stuff to sound good at peaks never hit red in digital mode does this help sum
Mar 13, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Humminbird 595c GPS Receiver Logo
27 people viewed this question
Top Humminbird GPS Experts
Jerry Greenberg
Jerry Greenberg
Steve
Steve
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
