Question about Canon PowerShot S1 IS Digital Camera
When you turn my camera on it has a black screen and you cannot take pictures. You can review pictures and see the different menu modes, but the screen is otherwise black. The camera is otherwise in good condition and is only three years old.
  • Canon Master
  • 4,738 Answers
Gennylou, sorry I didn't see your post sooner.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Jul 04, 2009
    Sergeant:
  • 321 Answers
Belt crack of LCD cost 60$
Posted on Jun 19, 2009
Black screen only when taking pictures
The link below should be helpful to fix your camera issue.
Camera Troubleshooting Link
Regards,
Sean
Jun 08, 2013 | Canon PowerShot S5 IS Digital Camera
Canon s2IS when I turn the camera on in review mode the LCD screen displays pictures one after another. Cannot stop the picture review except to turn off the camera. In camera mode the menu button and...
Please do the followings.
1. Turn off the camera.
2. Remove the memory card.
3. Remove the batteries.
4. Wait at least 3-5 minutes.
5. Place the memory card and batteries.
6. Turn on the camera in any mode except review mode.
7. Take any ordinary picture.
8. Change the camera mode to review.
9. What happened now. Is everything normal. if not please write a comment to explain the situation.
Jun 03, 2010 | Canon PowerShot S2 IS Digital Camera
Our camera when you turn it on has a blank screen and you cannot take pictures. You can review pictures and see the different menu modes, but the screen is otherwise black.
Jul 03, 2009 | Canon PowerShot S1 IS Digital Camera
Same problem. screen is black when turned on. where can i repair?
Jun 21, 2009 | Canon PowerShot S1 IS Digital Camera
Kodak easyshare DX 7630 screen black in take a picture mode but is fine in review etc
Hey Wistra,
You could try resetting your camera to the factory settings by choosing the reset to default setting in the menu. If this doesn't work the sensor on the camera is most likely broken, and you should have the camera looked at by an authorized service technician. If the camera was purchased less than a year ago the repair would most likely be covered under manufacturers’ warranty. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 05, 2008 | Kodak EasyShare DX7630 Digital Camera
Camera will take picture, but the picture is coming out black!!!! Help Please!!!
Dear vera11:
The symptoms you're describing sound like a classic case of having a faiiled CCD image sensor.
First try pressing the display (DISP) button on the back of your camera several times to see if your image returns at any time. One of the three display modes is "off" to preserve battery life. Your problem may be as simple as inadvertently pressing this button into the off mode.
If that doesn't work, try doing a reset and then removing your batteries from the camera for a few minutes, reinstalling them and turning the camera on to test the LCD screen.
If your screen is still black, but you can clearly see pictures taken previous to the problem, and you can clearly see the menu system when you press the MENU button, then you likely have a CCD sensor problem. Contact Canon Tech Support at 1-800-828-4040 to have the camera repaired.
Hope this helps.
Sincerely,
HeavyDLB
Jun 01, 2008 | Canon PowerShot A520 Digital Camera
LCD won't work in shoot mode, but work in playback mode
It's unusual that you can review pictures, but not see the menu. Take a picture with the camera. If this picture shows up black, then it's probably be a defective CCD imager. If so, Canon will fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Nov 01, 2007 | Canon PowerShot A80 Digital Camera
Turn on camera but the lcd sceen is black
Have you checked the display mode you're in? If you have the display set to off (to save power) and also the picture review time set to off, then you'll just see a black screen. Try pressing the 'Disp.' button below the screen when the camera is on - it should cycle through different settings with each press: Off, On, On with picture info. Similarly, in the playback mode this will show you more or less info about the picture you are viewing.
Even if the display is switched off, if you have your 'review' option in the menu set to anything other than Off (i.e. 2 seconds), then you should see the picture you've taken appear on the screen straight after taking it.
If it's not that, then I don't know the answer....
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Pentax Optio 555 LCD screen blank problem
No I don't believe it is your shutter, more than likely it is a LCD Screen problem. I would suggest you take your camera back to the shop where you purchased the camera and have it serviced under warranty. I had a customer with an Optio 550 come in and it looked like every shot was taken through 'venetian blinds' and the problem was with the LCD Screen and the camera was sent back to Pentax and repaired under warranty.
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
195 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
