Question about LG Washing Machines
Maytag dishwasher mdb6100
The dishwasher just stopped working on a Normal Wash cycle leaving water in the bottom of the dishwasher. I followed the advice turning off the switch to the dishwasher and the dishwasher started again but when the water reached a certain height, the dishwasher stopped again. Could the floart switch be the problem? How can we remove it as it appears to have gunk on it? Could this be the problem?
  • 74 Answers
SOURCE: Washing leaves spots
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you're using and adjusting your hot water heater's water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water. First you'll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, you can wash the glass with warm water and concentrated dishwasher detergent or use a high-phosphate detergent (such as Glass Magic) according to label directions. If film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature. See "Doesn't wash well," above. Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn't anything you can do to make it clear again. But you can avoid future etching by taking these steps: 1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don't use extra hot settings, such as "Power Scrub" and use "Energy Saver" dry cycle. 2) Adjust detergent amount. 3) Don't pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
Posted on Jan 18, 2006
Washer_tech
  • 164 Answers
SOURCE: Washing machine problems
it sounds like the lid switch might be misaligned.open and close the lid slowly and listen for the tell-tale click. if you don't hear the click then open the control panel and adjust the position.
Posted on Aug 28, 2007
  • 126 Answers
SOURCE: Dishwasher fills and drains at the same time
your water is syphoning out make sure your drin hose is up
Posted on Dec 13, 2007
  • 3422 Answers
SOURCE: Dishwasher stops mid cycle
Do the foll. things:
1)Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so. 2)if ur dishwasher doesn't starts then: First, check the usual suspects: Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Asko dishwashers have had problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced. You can buy any replacement parts you need right here.
Goodluck,
Dont forget to rate me as fixya..
Posted on Jan 29, 2008
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
Power is to the dishwasher put it wont turn on
hello first check yor breaker make sure not tripped.
next check for lights in your panel.
perform a normal wash if no luck
next perform a service diagnostics cycle.
note sercice diags. works on Maytag MDB7600 series.
press the following keys in less than 6 secs.
HeatedDry > Normal > HeatedDry > Normal
to advance machine cycles press Start/Resume key.
blessings,
e.
May 22, 2014 | Maytag Dishwasher
I have a maytag MDB6100 with 2 problems
If nothing obvious like blocked / obstructed outlet pipe
You need to check if the outlet pump motor in line with the outlet hose is spinning when in the outlet mode. First check if it is spinning by looking at it and see if the small fan is spinning. If it is turnning this means that it has power and the internal "impeler" that pushes the water out has become loose. Remove the pump (easy job) and repair. If it does not spin you need to determine if the 2 push on terminals have power on. If there is voltage and the motor does nut spin this indicates that the pump motor is open circuit and must be replaced.
Mar 26, 2010 | Maytag MDB5100 Dishwasher
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
Feb 25, 2010 | Dishwashers
Dishwasher is draining during the wash cycle, but leaves water in the bottom at the end of the wash. What could be the problem?
Hello Ellsaesser,
Dishwashers typically leave water in the drain system exitting the pan but not a lot of water. If yours does then make sure you clean the drain screen ( normally located in or around the drain tube exitting the pan of the dishwasher..) If after cleaning that and after a normal wash cycle you continue to have significant volumes of water in the pan, the pump, lines leading to and from that pump may be restricting flow or damaged.. Those are a few of the normal culprets for why there is a lot of water in the pan of dishwashers after a cycle.. Hope that helps you identify the problem and resolve it,..,
Regards
Nov 29, 2009 | Frigidaire Dishwashers
Dishes always come out cloudy ... white cloudy stain on inside of door, etc. We use electrosol power ball cubes. We set wash cycle to normal wash.
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 18, 2009 | Maytag MDB7100AWB Dishwasher
My maytag will not clean the dishes. I have cleaned out the water tubes, I have checked the hot water. all it does when you run a cycle it leaves the dishes dry and the detergent is not being used.
Most likely causes are:
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Hope this help. Good luck.
Sep 11, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Have a maytag mdb6100 how do i get accsess to take lower wash arm out i want to clean
You have to remove the screws in the bottom filter where the spray arm is. Before you do that, you can put a cup of Tang Orange Juice Powder in the unit without any dishes and it will clean it out unless it has plastic or glass pieces in it. Or you can use Dishwasher Magic. We have parts and supplies if you'd like to call us. Hope this works out well for you! Ella
Aug 26, 2009 | Dishwashers
Maytag Performa Dishwasher draws water then stops
More than likely you need to replace the washer control panel.
Jul 19, 2017 | Maytag 24 in. MDB5600A Jetclean II...
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Jan 27, 2007 | Maytag MDB9600A Jetclean II Built-in...
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
