Question about GE JRP15 Electric Single Oven
How to test an oven temperature sensor with ohm meter
    Prodigy:
    An expert who has answered 500 questions.
  • GE Expert
  • 650 Answers
I assume you have it out of the oven and a room temperature. They generally should show around 1100 ohms at room temperature and have a negative coefficient - resistance goes down as they warm up.
Posted on May 10, 2014
2 Suggested Answers
  • 87 Answers
SOURCE: F2 Error but Sensor Checks at 1100 ohms
Order a new sensor.
Posted on Jun 08, 2007
Error 27 how to fix this where is a problem
This is telling you have a problem with your oven temperature sensor. You'll need to test it with an ohm meter. You should read 1100 ohms across the two wires from the sensor.
Oct 26, 2015 | Samsung Induction Range FTQ307
Where is thermostat located in Frigidaire wall oven?
Hello Brad,
The thermostat is a small diameter appx. 6 inch long round probe it looks like this
11_4_2011_12_23_15_pm.jpgTo test it for proper functionality ya need to use a multi meter capiable of reading ohms of resistiance...unplug the sensor from the wiring and place the meter leads onto the 2 wire ends of the sensor and at room temperature once the oven has been off check for between 1060-1100 ohms at the sensor if its good,if the ohms value is much higher or lower that 1060-1100 at room temp. the sensor is defective.
GENE
Nov 04, 2011 | Frigidaire 24" Built-in Single Electric...
My maytag oven is showing a f3 code model #che98oobcb
The "F3" fault code is indicating an oven temperature sensor failure or a temperature sensor circuit failure. The oven temperature sensor could be open or shorted. Test the sensor for proper ohm value, frayed or pinch wiring, or connector damage. The oven temperature sensor probe can be found sticking out from the rear wall inside the oven cavity. It will need to be disconnected and tested with an ohm meter. I added a chart in the image below of the resistances of the oven sensor at specific temperatures. At normal ambient room temperature, the oven temperature sensor should have a resistance value of 1050-1100 ohms. See image below. The oven temperature sensor is part #12001655. richroth_137.jpg
Jul 21, 2011 | Maytag Ovens
Receiving a F 10 message
F10 error code means "runaway temperature condition"
If your oven is overheating, unplug the power cord for a few minutes. When plugged back in if the oven is still overheating, you will need to have the temp sensor and control checked.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven. Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven. Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms. The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website.
Hope this helps.
Apr 25, 2011 | Kenmore 47833 Electric Single Oven
Wall oven flashing f3 and beeping
Use a ohm meter to test the sensor, it should read about 1100 ohms at room temperature, if so, then your oven sensor is good.
If your oven sensor tests good, then your control board would need to be replaced.
Apr 10, 2011 | GE Ovens
When I start the self cleaning cycle After about 15 minutes it starts beeping and the display shows F5. The unit is about 10yrs old. What could this be?
This could a bad temperature sensor or a bad clock.(ERC).
Disconnect the power.
Remove the rear panel.
Unhook the temperature sensor wire and test the temp sensor with a volt/ohm meter set for ohms.
A plus/minus reading of 1100 ohms is good.
If temp sensor reads good replace the ERC(clock).
Nov 28, 2010 | Jenn-Air W30400P Stainless Steel Electric...
Oven began beeping F2 for no reason. Oven was off at the time
This indicates an over temperature condition occurred. This could be caused by a failed temperature sensor, failed cooling fan, or problem with the control board.
The temperature sensor can be tested with an ohm-meter (should read 1090 ohms @ 70 F). If the sensor is good, fan is running, may be welded relay contacts on the control board. We rebuild these control boards at www.fixyourboard.com.
Sep 04, 2009 | GE Profile JTP18 Electric Single Oven
My GE oven gives error code of F3 and F5
Thank you for contacting Fixya.
It's possible it could be the senser, just two screws hold it on and the wires unplug with a connector.
As to understand it in details whether the sesor is the bad part you can use a ohm meter to test the sensor, it should read about 1100 ohms at room temperature, if so, then your oven sensor is good.
You can get a cheap ohm meter at Radio Shack or any hardware store. If your oven sensor tests good, then your control board would need to be replaced.
That would help to resolve the issue.
God Bless.
Jul 13, 2009 | GE Ovens
GE JRP15 Electric Single Oven Logo
209 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
