Question about Mtd Garden
Cub cadet m50s
Replace starter know that large red small red and small blue with slide on connector go but not sure where large blue wire with o type end goes
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 118 Answers
Try going here: http://bit.ly/RpwpAg. It displays components and diagrams for how parts are put together. That said, if it still does not answer your question, then I would advise contacting the manufacturer directly for assistance.
Posted on Apr 16, 2014
I HAVE A CUB CADET 1550 , I HAVE PUT A NEW BATTERY IN IT , NEW STARTER AND NO POWER TO THE INSTRUMENT PANEL AT ALL , COULD YOU POSSIBLY TELL ME WHAT TO CHECK FOR ?
Have you checked the fuse? Check the wiring to look for breaks, check for wires of the switch ends, make sure all wire connected an properly. It's hard to diagnose because we can't see it but most times it's the fuse or connectors.
Jul 19, 2017 | Cub Cadet Garden
Cub cadet gtx 1054 cutting grass and the tractor stop running. Will not start
check wires and connectors--check the inline fuse --seat switch -battery look over the wiring possible wire damaged or disconnected
Aug 14, 2016 | Cub Cadet GTX1054 54 in. 27 HP Kohler...
1500 model. where can I get a wiring diagram?
Hi Rodney,
Here is a link to one of the Cub Cadet 1500 Series with a wiring diagram. Yours may be similar to this. If you are NOT Sure, take the mower to the shop for Repair/Service.
Best of Luck,
JP
Cub Cadet 15HP Force 44 53AA5D2L100 Operator And Service Manual Wiring...
Jun 22, 2015 | Cub Cadet Garden
Replaced starter dont remember how wires go back. the large red small red and the blue with the female slide on wires i know where they go but the larger blue one with the o shaped end i not sure if it...
you will have 3 or 4 wires to the solenoid. it sounds like you know where the 2 small ones go so the other 2 are for the battery and starter. one side of the solenoid will have a wire from the battery and the other side will have a wire to the starter. these 2 wires are larger because they carry the amperage required to turn the starter.
Apr 16, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet LT1045 starter solenoid: can 4 prong replace 3 prong?
Yes you can. The small wire from the key switch goes to the prong closest to the power wire from the battery.
Dec 12, 2012 | Garden
I HAVE A CUB CADET LT1050 LAWN TRACTOR AND WHEN I TURN THE KEY I GET ONE SINGLE CLICK. THE STARTER DOESN'T ENGAGE
Hi camy wils815...
Sounds like you have a faulty solinoid.
Make sure your battery has a full charge, the by-pass the starter solinoid on the engine.
To do this ground one big wire connection to one of the small wire connectors (with the wires still hooked up) and if it starts, then replace the solinoid...if it does nothing, replace the solinoid.
Please take time to rate me
Jul 30, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I have a 16hp v twin in a cub cadet. When I try to start the engine all I get is clicking sounds. I have a new battery so I am wondering if I should try to replace the selinoid next or is there a problem...
I you hear aclicking sound the solinod is fine. I'm not sure about the circuit boars.. Look and see if there isn't a large red? wire coming from the solinoid to the starter.If there is remove the end from the starter. Connect a D>C> volt meter to the cable and the other end of the meter to a metal frame. sit on the mower and attempt to start it . The meter should read 12 volts while cranking. If it does its the starter. If it doesn't have the large wier to the starter I do not know. sorry szm230
Apr 14, 2011 | Briggs & Stratton Garden
I have a cub cadet 7234, shut it off last night now it wont do anything. Everything is in neutral but it won't crank.
Take a jumper cable and attach one end of the red set ends to the positive post on the battery after making sure the battery is fully charged, take the other end of the red cable and attach it to the bolt with the usually red wire on the starter. Take the blackset and attach one end to the negative post on the battery and touch the other black end to the starter hpousing and see if the starter engages, if it does not then you can assume that the starter has died. If on the other hand the starter spins over then either the starter switch or one of the safty switches on the cub cadet has failed. You can test all the switches by removing the wires going to them and using a small piece of wire bypass the connections untill you find the one that is defective, replace that one and you should be back in bussiness. Hope This Helps Don
Dec 08, 2009 | Garden
1977 ford f 100 solenode mounted on starter
so did this problem just happen or did you do some wiring repairs??. on a 1977 the only solenoid should be the fender. I dont have a wiring diagram that old. if it just happened there is a small wire on the solenoid on the fender, unhook this wire, and see if it happens again. if the starter does not engage then you may have a ign switch problem, if it still engages then the solenoid is bad.
Sep 23, 2009 | 1979 Ford F 350
Garden Logo
24 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
