Question about Bachmann James The Red Engine Train Set
Train derails off switchers - Bachmann James The Red Engine Train Set
3 Suggested Answers
SOURCE: train or cars derail going thru switches,have
wat
Posted on Jan 03, 2010
residentoccu
  • 161 Answers
SOURCE: Gordon derails
Check your wheels to make certain the are still in gauge.
Posted on Apr 12, 2013
What part of bridge is the alignment track
alignment tracks are the part of a rotating bridge that is where the tracks meet back together , this requires an alignment rail or train might derail , as this joint needs to remain movable so there is a gap there , typically it looks like a third rail spaced just inside the outer rail , this grabs and guides the wheel "toe" and centers the wheel onto outer rail , this feature requires frequent maintence as it does wear , as was evidenced few years ago by a bulk train derail in Louisiana as this was exactly what failed after crossing was hit by barge and train derailed
Jun 10, 2015 | Crafts & Hobbies
The train keeps jumping off the track
Is the track properly and carefully put together? Is one or more sections damaged take one of the cars and gently push it around watching in those places where the train derails. If it only happens at a track joint look at it more carefully.
Nov 30, 2013 | Lionel Trains The Polar Express O Gauge...
Were to put smoke fluid on a lionel 8141
If you are asking about the 2-4-2 scout type, a few drops down the stack.
If you are asking about the diesel switcher, it has no smoke unit.
Feb 24, 2013 | Lionel 8141-50 Smoke Unit
Gordon derails
Jul 19, 2012 | Bachmann Ho 668 Gordon Express Train Set
Lionel Train transformer goes full throttle only
Sounds like the "variable resistor" that allows for a variable speed is either defective, or has become corroded on it's switch contacts. You might get lucky with some electrical contact cleaner spray and spraying it in or around the variable speed switch. Otherwise, I'd just invest in a new transformer.
Dec 16, 2011 | Lionel Cw 80 Transformer
Piolar Express front pivot hangs and causes derailment
There is a design flaw with the spring loaded pivot. If the wheels canter even the slightest, like on a turn, the mechanism slide locks up. I solved this problem with a medium white lubricant used for fishing reels called lubriplate. Make sure you lube both sides of the slide. Other medium consistency lubes should work just as well.
Dec 08, 2011 | Lionel The Polar Express Train Set
We just got the Hogwarts express and it will not complete 1 loop without derailing or the cars becoming uncoupled.
Well you should probably check the radius of your curves. The Hogwarts Express has a minimum curve of O36 and on a tighter radius curve it will derail. I have found that the Hogwarts train runs better on fasttrack than standard O. You should also make sure the track is flat because if it isn't completely flat it derails. The train isn't designed well so it derails but if you run it slow you shouldn't have a lot of problems.
Dec 27, 2010 | Lionel 7-11020 Harry Potter Hogwarts...
Bachmann James The Red Engine Train Set Logo
26 people viewed this question
Top Bachmann Crafts & Hobbies Experts
J.D. Browning
J.D. Browning
Steve
Steve
Are you a Bachmann Craft and Hobby Expert? Answer questions, earn points and help others
