Question about LG 50PS80 50 in. HDTV Plasma TV
Remote not responding
I recently replaced my mainboard and after connecting everything back my tv powered straight on so i tried to turn off by remote but i get nothing. Checked batteries and they were ok plus remote working fine before board replacement. Can i reprogram my original reomte also i went back and check all connections to the board and it doesnt appear i missed one?
    Guru:
  • 135 Answers
Look at this video
you need to shoot a video or take an image using your cellphone
the ccd sensor is sensitive to the transmitter IR Led at the Remote
and can show you whether it emittes photons and works
Posted on Apr 16, 2014
Testimonial: "Thanks i look at the video and used my camera phone and seen the led was not lighting up. Checked batteries on a voltage meter and go a reading of 1.4 when installing batteries back noticed a small amount of corrosion on battery terminals, removed the corrosion with a pencil eraser. Used my phone camera and "Now I have light!""
  • Tech Master Apr 17, 2014
    that's Great i'm so happy to hear that !
    Top Expert:
  • LG Master
  • 36,408 Answers
Your LG remote is not reprogrammable so something else must be wrong.
  • 298 Answers
SOURCE: Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
Posted on Dec 29, 2008
  • 32 Answers
SOURCE: Plasma Screen No VIdeo, pop / flash as well.
main board problem
Posted on Jan 07, 2010
carloslima24
  • 6 Answers
SOURCE: how would i know if my HDMI ports are working or not?
Ps3 has a thing all people must know...
when you plug the hdmi cable, you have to press and keep pressed the power button of the ps3,until the image apears...
bye
Posted on Mar 27, 2010
SOURCE: Lg 42lc7d turns on to blank screen doesnt respond to any request
I need sreen for LG 4LC7D-UB because the screen is damaged
Posted on Mar 21, 2011
SOURCE: lg 42 plasma model 42pc3d-ud: had a really bad picture so
I Have An LG - 42PC3D-UD, When I Turn It On "It Have Sound And A Very Bad Picture.
Posted on Apr 13, 2011
Buttons on the TV nor the remote control don't work
So the power button is the only one that functions? Double check your main board, IR sensor, and key controller connections. You should not need a code at all. The only programming you should have to do is to do a scan for antenna channels you may use as well as setting up any of your personal preferences. Did you order the exact part # as the old one?
Nov 12, 2013 | Vizio SV420M LCD TV
Toshiba 42SL417U doesnt respond to remote and shuts off
you have a bad power supply or mainboard causing the shutdown most likely the mainboard.
Mar 02, 2013 | Toshiba 42sl417 42 1080p Led Tv 42sl417u /...
I have the same issue with my MAGNAVOX 32MF605W/17 when i turn the power on it flashes white then goes black and the amber standby light remains on.... you decribed it as a Mainboard Problem... my issue is...
I had the same problem caused by a power surge. Removed the back cover (kind of a pain in the *** because it's a tight fit) then removed the metal cover over the circuit boards. There were three 1000uf 35vdc capacitors on the Left board capacitors 2074, 2079 and 2080, that had bulged out tops. Replaced those with the same capacitor from radioshack (p/n: 272-1032 stock at most radioshacks)for $3 and the tv works fine. During this I also noted that the plug right next to the power switch down by the face was loose, pressed that in and everything is kosher...good luck
Apr 25, 2010 | Philips 32MF605W Television
Ibm netvista x41 wont power up
measuring 12v at the psu is not enough. the psu have several voltage outputs ranging from 12volts to 3.3 volts and maybe even 2.2 volts.. firstly, check all onboard USB ports, a bent or shorted pin in a USB port will prevent the psu from operating. next, the psu has a safety connection to the mainboard, this is called the power good signal ( pwrgd) and it is a signal from the psu to the mainboard and tells the mainboard that everything in the psu is functioning correctly. If the powergood signal is lost ( drops from 5volts to zero volts) the mainboard will issue an interuppt to the cpu and the cpu will shut down, this will also shut the board down to prevent damage and data loss. mainboards all use pretty much the same connectors so your board will have either a 20 pin power connector or a 24 pin one. It may also have an additional 4 pin connector to power the cpu and northbridge functions. use a known good psu and plug this into your board along with the 4 pin connector and attempt a switch on. If the system begins to boot, replace the psu. if not, try unplugging or removing everything connected to the board, pay special attention to expansion cards and usb ports. remove the ram sticks and video cards if fitted, then attempt to boot again. if the system does not respond, replace the main board. if it now begins to boot, refit everything one item at a time and try starting the machine. turn off before refitting the next item and start the machine up again. when you get to the problem item, the machine will stop starting. If all else fails, replace the mainboard or take the machine to a reputable repairer..
Oct 30, 2009 | IBM NetVista X41 PC Desktop
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
TV does not respond to the remote control
I had this happen on mine after about 3 years. Luckily it was on extended warranty. At first the techs re-soldered the connections to the board for the IR sensor but the problem was still intermittent. The next time they replaced the mainboard and all is well - just like new.
Mar 26, 2008 | Zenith E44W46LCD 44" Rear Projection...
TV remote will not work properly
I have a Mitsubishi WD-52725 TV, too, and have experienced the same problems with it. My solution to the remote not responding is to push the reset button on the front of the TV (to the left of the Power button) with a paper clip and wait for the green light to stop blinking (about 1 minute). Then, turn it back on and try the remote again. Recently, my remote stopped responding when pushing certain buttons on it. I removed the batteries, and all of the little screws including the one inside the battery compartment and gently cleaned the contacts inside the remote and the circuit board with a cotton swab dipped in alcohol. After putting it back together, it works fine now.
Feb 28, 2007 | Mitsubishi WD-52725 52". Rear Projection...
27" MAGNAVOX W/ CHILD LOCK ON- NO REMOTE!
On those particular Magnavox TV's you have to use the original type of remote to power it back on then un-lock the parental lock. It is a bummer that nothing else will work. Here is a link to purchase a replacement remote.. http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod
Feb 06, 2007 | Philips Magnavox 27MS343S 27" TV
LG 50PS80 50 in. HDTV Plasma TV Logo
97 people viewed this question
Computer Repairing
Computer Repairing
