Question about Blodgett DFG-100 Gas Single Oven
Dfg100 oven will light , get to temp, shuts off but wont light by itself again
2 Suggested Answers
  • 12 Answers
SOURCE: My company has Blodgett Gas
The serial number is under the left side door behind the cover. Open the doors take out the two phillips head screws which go into the top of the lower cover, one on each end just inside the door hinge, the lower cover will remove to the front.
Posted on Dec 09, 2011
When I turn the oven down the gas goes off and have to start again
read the user manual as the temp should be thermostat controlled were with gas there is always a pilot light burning when the oven is in use and when the set temp is reached the gas burner is shut off and when the temp fall below set point , the gas is turned on again and the pilot light starts the burner
by using the timer , when the time is reached the gas is turned off and of course you will have to relight it
if you do not have a user manual , download one from google or talk with a gas repair shop
Sep 18, 2016 | Belling Ovens
to confirm check the Ohm draw on the temperature probe, i am not sure what is the correct one but you can check online at blodgett if probe okie then you will have an issue with the temp controller there possible the potentionmeter is worn out.....good luck
Apr 16, 2014 | Blodgett DFG-100 Gas Single Oven
GE Built In Wall oven JTP25SOH6SS wont completely shut off
The cooling fan will stay on for a long time after using the oven. It should shut off after a while. If it is running all night for instance there is a great possibility that a relay is stuck on the control board.
Apr 13, 2014 | GE Ovens
Oven wont bake
If this is the design that the oven will click to light they generally will preheat but shut down once they go to standard bake. The oven will try three times to relight but then shuts down and will not try to light again until you reset the oven. If this is the case the oven burner itself is usually the problem. the burner comes with the electrode.
Nov 27, 2013 | Whirlpool Ovens
Oven lights and works fine till it reaches set temp then panel goes blank and oven shuts off
Check the cooling fan inside of your control panel. Most likely the computer board overheats and shuts itself down.
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Jan 25, 2011 | GE JGRS14 Gas Single Oven
Gas oven not keeping temp consistant
Hi. this is a failing oven temp sensor. the sensor probe is not responding to the oven control. this will cause erratic temps in this oven. it will also damage the control board if the sensor isn't replaced soon.
May 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Error code f 03 has come up on our oven
I know what you mean. I was cooking with this appliance tonight and suddenly it displayed an f-3 code. My advantium oven is less than 8 months old. Not sure how this happened or how to fix the problem. In order to sleep tonight (the constant beeping) I had to shut power off at the breaker pannel. Is this representative of the the type of quality that GE stands for???? I am sooo frustrated. I cook with my advantium oven all the time and love the dual abilities of this appliance. Like I said this is brand new and to have the f-3 code which apparently (from what I read) is a failed key pad. I am very dissapointed and am begining to think about pulling my stock from this company!
Nov 05, 2007 | Blodgett DFG-100 Gas Single Oven
Oven shuts off by itself
When your oven reaches the desired temp. it shuts down then turns back on again after it cools down a couple of degrees and cycles like this during the complete baking cycle. If your ignitor or oven valve is getting weak it would cause this symptom.
Oct 31, 2007 | GE JGRP20 Gas Single Oven
Blodgett DFG-100 Gas Single Oven Logo
Top Blodgett Ovens Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
