Question about Dryers
When u turn on my gas whirlpool dryer it runs as normal. when u check on it a little later (on automatic dry) the timer has not moved, and the dryer has quit producing heat
  • 1 more comment
  • jguenther331 Jun 19, 2009
    if you put it on timed dry...20, 30 min. etc the timer works, but the heat doesnt' work the whole time
  • jguenther331 Jun 20, 2009
    is there a way to check the gas valve coils? once the thermostat tells the dryer to kick off heat momentarily the heat never comes back on....u can hear the ignitor clicking like it keeps trying to start the gas. if you open the door and close it back then it will ignite
  • 6,784 Answers
Hi, the timer control the heating commands and, if its not moving(rotating), this will confirm timer failuer. replace it asap.
Posted on Jun 18, 2009
  • Michael Masters
    Michael Masters Jun 19, 2009
    Ok, i still think the timer is bad in this case. there may be certain sector of the timer that may still be operational but, the affected sectors are certainly damaged. its best to replace the timer in this case.
    I would also check the gas valve coils. they are black and cylindrical in design. the can be found on the actual valve assembly. these coils are responsible for the opening and closing of the gas valves and, if defective, they can cause this interruption in the heating process.
  • Michael Masters
    Michael Masters Jun 20, 2009
    You can check the coils by using a Multimeter or ohm. these coils should be replaced. they are definitely faulty.
Gas dryer dries sporadically. dial for automatic dry doesn't move
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ...Replaced outlet, cord, and moved the outlet so we don't have the same ... Whirlpool LER4634EQ0 110 v timer motor, when timer contacts TM .... David Villa 7 months ago ... 3 years and now thedryer won't heat and the timer doesn't advance, ...Missing: cu
Nov 17, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 13, 2009 | Estate TGDX640JQ Gas Dryer
Whirlpool Gas Dryer keeps running on auto dry setting
When you moved the sensor wire on the moisture sensor may have fallen off.
Remove the front panel and locate the wire and the connection. It will be on the right side near the lint filter vent. If it is still connected your timer has gone bad.
Mar 26, 2009 | Whirlpool Dryers
Gas Dryer runs non-stop.
Repairing a dryer that won't shut off many seem daunting, but fixing your own appliance is actually pretty easy. The toughest part is figuring out what dryer part is the problem. We've created a list of the most common parts that can cause a dryer to not shut off. Use this list to diagnose the problem you're having and then enter your model number into the search box to find the right part for you. You'll also be able to access even more detailed repair help and tips about your dryer.https://www.youtube.com/watch?v=rXs6cL_prAQ
Mar 16, 2017 | Whirlpool Dryers
Whirlpool Gas Dryer, LGR5636EQ2, timer not moving on Auto (DryMis
If that is a 3 wire gas assembly then the timer is screwed.The orange wire when removed from the mix will make the thing advance. The trouble is in the timer. If that is a 2 wire gas operator you need to change the high limit and open up the outside vent. My opinion.
Nov 14, 2008 | Whirlpool GGQ8831L Gas Dryer
KITCH AID DRYER
It sounds like the timer motor isn't advancing. You will have to replace the timer.
Oct 15, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool dryer: supreme Not heating up
Hi thanks for the question. the problem could be the thermal fuse located at the back . remove back panel. on the air duct . a small piece of plastic with 2 blue wires to it . replace the thermal fuse thanks .the appliance doc
Oct 05, 2008 | Whirlpool LGR7646E Dryer
Whirlpool gas dryer is not hot .burner ignights but it is not hot enough
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
if this helps please give me a fix ya vote
Jul 14, 2008 | Whirlpool Dryers
Dryers Logo
144 people viewed this question
Top Dryers Experts
