Question about Fujitsu ScanSnap fi-5110EOX2 Pass-Through Scanner
Power Switch Is Pushed Out of Position
When pressing the power switch, it came loose and moved into the panel so that it no longer operates. How may I open the panel holding the power and start switches? There are no obvious screws or tabs.
  • 75 Answers
Have you tried tape. I would also call tech support.
Posted on Apr 16, 2014
  • Alan Auerbach Apr 17, 2014
    Thank you for the prompt reply, Cletus. Tape is of no use. I have to get the ADF cover open. I did call Tech Support. They refused to tell me how to open the ADF cover to get at the switch but instead offered to repair it $169.00. Since I bought a replacement on ebay for $61.58, that is not a reasonable approach. I would still like to try to fix it if you have any suggestions.
What is the fix to make the carrier weathermaker 8000 run without having to unplug and replug to electric?
These gas furnaces are very simple with few moving parts. Manufacturers added another moving part, and another way for unit to fail, by adding an electrical safety switch, which interrupts electrical command to unit to operate if the switch is in the open position such as when the lower panel is removed. But sometimes the lower panel, even when in place, may not depress switch enough to keep it closed. To see if an open switch is your issue, first verify that key unit components are working -- themostat works properly, gas supply to unit, electricity to unit, gas valve opens, flame ignitor comes on, fan comes on. If yes to all, check to see if the lower panel electrical safety switch works, and is positioned correctly. If the switch, or panel, is out of place or removed, the switch should remain in open position, and the unit will not run. If panel is not pressing against switch sufficiently, switch may not close when panel is in place. Given the coefficient of expansion of the steel plate the panel is made of, the panel may cool and contract enough to hold the switch closed when the unit first turns on. As the inside of the furnace heats up, the panel and frame of the unit expand as the metal parts heat up, and as the panel moves away from the switch due to expansion, the switch opens and the unit cuts off even though the lower panel is in place. This may take several minutes, or longer. If the panel remains far enough away from the switch after the switch opens and unit stops operating, the switch could remain open and prevent power flow/themostat signal prompts from activating the unit even when the unit frame and panels cool and contract. To check to see if an open switch may be your problem, turn off power to unit, remove top panel, remove bottom panel, check switch to see that it physically opens and closes, replace lower panel, replace top panel, turn power back on. Do this repositioning lower panel exactly as you was before you removed it, without pushing the lower panel in toward switch. If unit does not activate, or stops working after several minutes while thermostat is set to command unit to heat, an open switch may be the issue. To test for this, apply light physical pressure to lower panel, toward unit, over switch location. Cycle unit power switch off, then on. If unit activates and runs normally, insufficient panel pressure against switch, causing an open switch, may be source of problem. Possible fixes include putting lower panel back into place repositioned so that it presses more against switch, or taping a very thin shim (such as a square of cardboard cut from a cereal box, but must be done competently as tape and cardboard fluttering loose inside the blower compartment may lead to fan fouling issues) to the inside of the panel so that it depresses the switch more, or bending the panel so that it protrudes slightly toward switch (not recommended as once bent, panel is hard to get back into place properly, and bending may cause other issues), or carefully repositioning or nudging the switch toward panel (its fasteners may have come loose inside the unit frame, or switch may have vibrated out of place over time). If unit still will not cycle on, use a multimeter to see if the switch, when closed, allows current through the line (a continuity test). This might detect a bad switch. If the switch tests good, do a continuity test when the panel is in place, using alligator clip extension wires to test to see if the switch closes when panel is in place. Do this this test with main unit power turned off. If switch tests good when panel is removed while you are physically holding the switch closed, but tests open when panel is in place, manipulate/reposition/shim the lower panel as noted above.
Feb 21, 2015 | Carrier Weathermaker 8000 Gas Furnace 125k...
Tip
2002 Jaguar XType Sun-roof one-touch operations reset
I had this issue and found the solution around, worth sharing and it takes 30 seconds: <br /> <span> <li>Press the sunroof switch forward to move the sliding roof panel into the tilted position.</li> <li>Release the sunroof switch.</li> <li>Press and hold the sunroof switch forward until the sliding roof panel moves slightly. This may take 30 seconds or more.</li> <li>Release the sunroof switch.</li> <li>Immediately press and hold the sunroof switch in the forward position. The sliding roof panel will move down and rearward to the open position, and then forward into the closed position. Do not release the sunroof switch until the sliding roof panel has stopped completely.</i></li> <li>Your sunroof panel should now be aligned.</li></span>
on Jul 11, 2011 | 2002 Jaguar X-Type
Chevrolet impala driver power window switch buzzes windows will not operate
It is the most common problem of all vehicles with power locks or power windows, a wire has folded back and forth for 10 years in the door hinge area until it got stretched and broken. Possibley many wires. In your case only 7 years.
Nov 29, 2013 | 2006 Chevrolet Impala
How to reset driver window motor in 2006 BMW 750
Press the window 'open' switch beyond the second switching position. When the window has reached the lower final position, operate the switch for at least 15 seconds but not longer than 25 seconds. Then let go of the button and immediately pull the switch beyond the 'close window' position. Do not let go of the switch! The window now moves into the top final position, stops, then moves to the lower final position, stops again and then moves back to the upper final position. The switch must be held in the "pulled beyond engaging point" position during the entire procedure. Once the window has reached the upper final position, the initialisation is complete.
Jan 14, 2012 | 2006 BMW 750Li
Where is the rear window relay located on the 2002 Ford Explorer sport trac. Not the rear door windows but the very back window.
  • The power rear window is inoperative (Explorer Sport Trac only)
  • Circuitry.
  • Battery Junction Box (BJB) fuse 3 (30A).
  • Central Junction Box (CJB) fuse 20 (7.5A).
  • Power rear window control switch.
  • Rear window glass motor.
NOTE: The power rear window motor is not on the multiplex link. Any diagnosis and testing carried out on the power rear window will not involve the GEM module. NOTE: The reinitialization procedure must be carried out when repairs are performed on any part of the power rear window system including when the power rear window motor is removed from the window regulator drum housing, a new power rear motor is installed, a new power rear window regulator is installed, a new power rear window module is installed, and any operation in which grease or lubricants are applied to the power rear window system.
Rear Window Motor Initialization s1r~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure that no obstructions are present in the power rear window system when carrying out this procedure.
NOTE: This procedure must be carried out when repairs are performed on any part of the power rear window system including when: the power rear window motor is removed from the window regulator drum housing, a new power rear motor is installed, a new power rear window regulator is installed, a new power rear window module is installed, and any operation in which grease or lubricants are applied to the power rear window system.
NOTE: All power rear window components (window glass module, window regulator, window motor, and glass runs) must be installed and torqued to specification before carrying out this procedure.
NOTE: Steps 1-6 must be completed within 30 seconds. The entire procedure must be completed within five minutes.
NOTE: Once the ignition key is turned to the ON position in Step 6, it must remain on until the entire procedure is completed.
NOTE: Steps 7 and 9 require that the power rear window control switch be held in the closed position until the power rear window motor stalls the window in the upper header seal. Step 8 requires that the window control switch be momentarily turned to the open position.
  1. Start with the ignition in the OFF position.
  1. Turn the ignition to the ON position.
  1. Press the power rear window control switch vent button six times.
  1. Turn the ignition to the OFF position.
  1. Turn the ignition to the ON position. The power rear window will move up-down-up-down approximately 20 mm (0.8 in). This movement indicates that the power rear window motor has entered initialized mode.
  1. Rotate and hold the power rear window control switch to the closed position until the window stalls in the upper header seal.
  1. Momentarily rotate the power rear window control switch to the open position and release. The power rear window will carry out a one-touch down operation until the window stalls at the bottom of the travel stop designed into the window regulator.
  1. Rotate and hold the power rear window control switch to the closed position until the window stalls into the upper header seal. Once this operation is complete, the window will move up-down-up-down approximately 20 mm (0.8 in). This movement indicates that the power rear window motor has been successfully initialized.
  1. Verify correct operation of the power rear window by moving the window to the fully open, vent, then fully closed positions
Nov 16, 2010 | 2001 Ford Explorer Sport Trac
Canon NP6060 error code E210 Press Power Switch to Off then On
This error code, on older machines, means that the lens cannot get to its home position.
Lift up the top cover (or Document feeder) and look under the platen glass as you switch the power on.
Can you see the lens moving, trying to find its home position.?
If not, it is stuck on something, or the drive cables are loose...
Dec 08, 2009 | Canon Office Equipment & Supplies
2003 F250 Power Windows won't work
check fuses 35 & 41 (10 amp, red).
it also shows an accesory delay relay in the fuse panel.
And fuse 601? 30 amp.
make sure you don't have lock-out on driver switch panel activated.
Power Window System
Features and Operation
NOTE: The accessory delay feature will allow power window operation up to 10 minutes after the ignition is off or until a door is opened.
If equipped with power windows, the window control switch (14529):
  • will operate the power windows only when the ignition switch is in the RUN or ACC position.
  • is located on each front door trim panel, and Crew Cab and Excursion rear door trim panel.
  • may be used to raise or lower the driver side, passenger side and rear windows from the LF control on the driver side, or the passenger window from the passenger switch.
  • includes a one-touch down (OTD) feature for the driver door window.
  • can partially lower the driver side window when the LF window control switch is depressed half way (first detent).
  • will completely lower the driver side window when the LF window control switch is fully depressed and then released (second detent).
Power Window System — Modes of Operation
There are two modes of operation for the power window system.
Manual Mode
When the LH window control switch is pressed to the first down position, the window will move down until one of the following conditions are met:
  • The LH window control switch is no longer in the first down position.
  • The LH window control switch is pushed to the OTD position, causing the windows to enter auto mode.
Auto Mode
Auto mode provides the OTD feature. The OTD feature is activated when the LH window control switch, for the LH window, is pressed to the second down position.
Auto mode will be terminated when any of the following conditions are met:
  • The LH window control switch is pushed to the UP position.
  • The LH window control switch is released (OFF position) and then moved to the DOWN position (first detent) or OTD position (second detent).
  • Note: Delayed accessory feature must be active.
The OTD feature is controlled by the window control switch.
Condition Possible Sources Action
  • All power windows are inoperative
  • Fuse(s).
  • Circuitry.
  • LF window control switch.
  • Accessory delay relay.
May 23, 2009 | 2003 Ford F250 Super Duty Crew Cab
Sunroof doesn"t open or close
Section 01-17: Roof Panel, Sliding—Electric 1996 Taurus, Sable Workshop Manual DESCRIPTION AND OPERATION Electric Operation The sliding roof panel (502B98):
  • is available as an option.
  • is electrically operated through the accessory delay relay (controlled by generic electronic module (GEM)).
  • is of self-storing design.
  • requires a specific headliner.
  • utilizes a unique roof console and dome lamp.
  • has an air deflector.
The electrical system operates in the following manner:
  • Two switches control movement of the roof panel.
  • When the SLIDE roof sliding panel switch (15B691) is rocked rearward, the roof sliding outer glass panel (502A82) slides into the storage space between the roof trim panel (51968) and the roof panel, exposing an opening over the front seats.
  • When the SLIDE roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully back in the storage space, the roof sliding outer glass panel moves forward from the storage position.
  • The rear portion of the roof sliding outer glass panel moves upward on two lifter arms near the end of the forward travel, allowing a weather-tight seal when the roof sliding outer glass panel is closed.
  • An AUTO feature allows the SLIDE roof sliding panel switch to be touched momentarily to cause the roof panel to automatically move to the fully open position.
  • When the TILT roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully forward, the rear of the roof sliding outer glass panel pops up to the VENT position.
  • With the roof sliding outer glass panel in the VENT position, rocking the TILT roof sliding panel switch rearward closes the roof sliding outer glass panel.
  • Sliding Roof Panel Does Not Open or Close
  • Open power feed fuse.
  • Circuitry open/shorted.
  • Damaged roof sliding panel switch.
  • Damaged sliding roof panel motor.
VISUAL INSPECTION CHART Mechanical Electrical
  • Damaged roof panel
  • Obstructed roof panel
  • Guide
  • Damaged drive cable(s)
  • Open Power Distribution Box Fuses 1 (40A) or 4 (30A)
Apr 19, 2009 | 1996 Ford Taurus
Printer thinks its out of paper
  1. Open the Document Feeder by placing your fingers under the opening where you feed paper, and lifting upwards.
  2. Locate the black Paper Sensor (the black plastic switch that hangs down).
  3. Make sure the Paper Sensor is not pressed in. It should move up and down freely.
  4. If the Paper Sensor is stuck in the up position, try to gently pull the Paper Sensor back down.
  5. Turn the power off by pressing the Power Switch to the [ O ] position.
  6. Turn the power back on by pressing the Power Switch to the [ | ] position.
  7. Try to make a copy using the Document Feeder.
  • If the Paper Sensor is broken off or pushed in, you will need service on your WorkCentre.
  • If the Paper Sensor is not broken off or pushed in, the Paper Sensor not the cause of the problem
Oct 02, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Fujitsu ScanSnap fi-5110EOX2 Pass-Through Scanner Logo
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
