Question about Refrigerators
Top Freezer not freezer, fridge not cooling
I hear something so it appears to be "on" but food in freezer has thawed, water is dripping, and food in fridge is cool but not cold. Vents are clear, temp is turned up... what else should I check for before calling a professional?
  • kathy milano
    kathy milano Apr 16, 2014
    Sorry, meant "Top freezer not freezing".
  • 75 Answers
It is probably the thermostat but i would have someone look at it
Posted on Apr 16, 2014
SOURCE: Fridge and freezer not cooling down
It seems it's the defrost sensor (freezer side). Waiting for it to come, ordered this morning. It appears to be a defrost fault, having read on the web it seems you can check the defrost sensor with a meter across whilst holding the actual sensor in your hand tightly to see if the resistance changes, anyway it didn't. Will post when the new one comes and I change it.
Posted on Sep 13, 2008
  • 306 Answers
SOURCE: Fridge not keeping food cold.
When you open door to freezer do you hear a fan inside that compartment blowing? If you don't the fan motor is shot and will need to be replaced.
Posted on Nov 26, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: water leaks from vents in fridge
This could be your heater has malfuncutioned and what is happening is that when you turn it on the freezer is trying to get cold and frost and the heater is staying on and letting things melt very fast and causing a water problem
Posted on May 21, 2009
Sea Breeze
  • 4654 Answers
SOURCE: refrigerator not cooling
You model if the ARB1950C has a defrost timer inside the fresh food compartment and behind the temperature control panel. Need to see if you can manualy turn the timer clockwise until the compressor stops. During that time of 25 minutes the freezer should be in defrost. I believe your timer needs replaced based on how you explained what is happening. The part number for your timer is 67001036 and can be found at the links below. If it stays longer that 25 minutes then it's sticking in the defrost section of the defrost timer and will need to be replaced. If your refrigerator does not restart after about 25 minutes then slowly turn the timer through the opening in the plastic cover. There may be a plug covering the hole to make the hole not so visible. If you should have problems fell free to let me know, Thanks Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Posted on Aug 17, 2009
  • 942 Answers
SOURCE: fridge & freezer not cooling. Meat thawing
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions: Is the refrigerator completely dead? If so, see “It's stopped completely.” Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help. If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor The Thermostat The overload, relay, or capacitor The defrost timer The condenser fan motor
Posted on Mar 31, 2010
My whirlpool fridge/freezer model ET1FHTXM forms ice in the back of the freezer, and water drips down to the fridge. I can't figure out what is wrong. We do not have the water hose hooked up. Could...
Turn off or unplug the refrigerator.
Open the freezer.
Remove the food.
Remove the back panel inside the freezer.
Thaw the ice and clean out the defrost drain hole.
Re-assemble the freezer parts and turn it back on.
Jul 20, 2011 | Whirlpool ET1FHTXM Top Freezer...
Inside top of the refrigerator, top panel would freeze and then thaw out,dripping water on the shelfs and down into the vegtables trays
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 09, 2011 | Whirlpool Refrigerators
Freezer on top gets iced up and drips into fridge. When thawed it drains easily. Would tilting it back help? This is a GE tbx14satglwh model.
heatman101
Dec 16, 2010 | Refrigerators
Fridge not cooling freezer iceing up???
check the fan in back of freezer check or proper running condition not stuck or frozen also make sure not blocked by food the fan takes the air from freezer and blows it down into fridge area to cool it also check for ice build up in the fan housing and thaw as necessary
Nov 15, 2009 | Avanti Top Freezer 9.9 Cubic Foot Total...
Water dripping from bottom of freezer casing
Your drain line is frozen. Ice thawed by the heater in the freezer normally drains down a tube into a pan on top of the compressor, where it evaporates from compressor heat. If the drain freezes the water runs into the freezer bottom instead of the tube then into your fridge. To solve this remove everything from your freezer and remove the access panel in the back or bottom depending on your model of fridge. Turn off or unplug the appliance. Upon removing the panel(s). you will likely see that the bottom of the freezer is full of ice. Use a hair dryer or heat gun to thaw ice and remove. In the very back bottom you will uncover the drainhole. I usually use very hot water and a shop vac to thaw the drain hole. When you finally clear it you will hear water running into the pan on top of the compressor. Somethimes it takes a lot of hot water to clear the drain. Hope this helps!
Jul 08, 2009 | GE Refrigerators
The freezer fan is running and the freezer is cold, but the fridge is warm
Your defrost systems needs repair.
Set all controls back to mid-range positions.
Open the fresh food door and look up underneath the control panel for a small round hole. About the size of a dime. Insert a flat blade scredriver in the hole and slowly turn clockwise until you hear a click and the compressor shuts off.
Then listen closely for defrosting sounds in the freezer. ie,ice cracking, water dripping,water sizzling.
If you hear these sounds and notice the ice starting to melt, replace the defrost timer in the control panel.If this does not happen replace the defrost thermostat and heater in the freezer.
You will also have to remove the panel from the back wall in the freezer then use a hair dryer to finish thawing the ice in the freezer.
May 03, 2009 | Roper RT14DKX Top Freezer Refrigerator
Water dripping into refrigerator from cooling area
Your defrost drain in the freezer is frozen closed.
Turn the fridge off.
Remove the rear freezer panel.
Remove the visible ice.
Use a hair dryer to thaw the drain hole in the back of the freezer in the center of the drain trough.
Mar 12, 2009 | Refrigerators
Freezer melts then freezes again
hi thanks for the question is this a new fridge . if it is the fridge does shut down to enable the freezer to thaw. if it did not do that do that the freezer would ice up . not cooling the fridge part thanks for the question
Sep 28, 2008 | Kenmore Stainless Steel Compact...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
