Question about Fujitsu ScanSnap fi-5110EOX2 Pass-Through Scanner
Broken Power Switch
How to open panel to repair power switch pushed through its mount?
    Problem Solver:
  • 8 Answers
Hi Alan
The ADF cover is fixed on the top side (paper -entry) by arresting clamps and on the lower side (paper-exit) by hooks.
Disassembling:
- First remove the paper exit tray.
- On the left and right side of the cover you will find two cross head screws.
- Remove both screws.
- Now you have to release the ADF cover hooks.
- Put your fingers under the ADF cover edge at the paper-exit side or
In case of need you can use a teaspoon handle instead of your fingers.
- Pull out the lower ADF cover edge until the arresting hooks get free.
- Lift-up the lower ADF cover carefully about 1 inch and slide it towards the paper entry side for releasing the arresting clamps on the top.
- REMEMBER IT'S PLASTIC. TOO MUCH FORCE WILL DAMAGE THE COVER.
- Inside the ADF cover you will find a bracket with the power switch knob. Usually the bracket is loosen.
- Fix it in the correct position with plastic glue or heat melting glue.
- Wait until the glue set hard.
Reassembling:
- Reassemble the ADF cover in reverse order.
- Don't forget to screw tight the two cross-head screws before closing the ADF cover.
- Check the switch.
That's all.
Posted on May 13, 2014
The power button is broken how to turn ontv
Hello Andrew
You didn't specify what you mean by "Broken"
Do you mean physically broken or
It just doesn't turn the tv on?
There are separate answers for each.
1:To fix a physically broken switch you could simply open the TV up and attach 2 wires to where the switch contacts are soldered to the PCB.
Run the wires to a new switch. Probably a NO (Normally Open) type. A Round switch could be mounted easily with a drill hole through an unused area of the case. Pressing a NO switch closes the contacts momentarily to trigger the digital turn On.
2:You could remove the old switch & attempt to get an actual replacement or a similar mountable switch from a components supplier.
3:If the switch is actually physically OK and the internal contacts are working (test with multimeter) then the problem is with the digital switch mode power supply that supplies power to the main circuits.
This would probably be caused by leaky Electrolytic Capacitors on the power supply PCB.
In that case, if your up to using a soldering iron and locating the Cap's then this would be an inexpensive way to fix the TV.
Good Luck
Switched mode power supply
Capacitor Replacement Tutorial
How to Replace an Electrolytic Capacitor
Apr 05, 2016 | Televison & Video
Car want shift out of park
Up under the drivers side of the dash you will find the brake light switch mounted on the brake pedal. Take a close look at the wires coming out of the switch. It is very common for them to brake near the switch. If they are broken a repair kit can be purchased from your local NAPA. If there aren't broken wires than there should be power on one of the wires all the time. The other wire should have power when the pedal is pressed down. If there is no power on the other wire with the pedal pushed down than replace the switch. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Jan 30, 2012 | 2002 Ford Taurus
Will not operate. Does have power as the clock works.
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
Since this is posted under R-530BS, I'll assume that's your model number.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
If that's not your model, feel free to contact me directly with your model number.
If you only need a switch, you can order a universal type here for $5 postpaid.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 29, 2010 | Sharp R-530BS Microwave Oven
Will not run when you push start
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases with a one-year guarantee.
May 27, 2010 | Emerson Black Microwave Oven
Power switch is faulty for microwave operation,fan and light. Microwave does not start when door is closed and start button is pushed, stops during operation and same occurs for fan and light. Clock...
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix - see this file) or occasionally a problem on the control panel.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
Jan 30, 2010 | Whirlpool GH7155XHS Microwave Oven
PUSH A BUTTON & PRAY
See these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Jun 06, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave won't operate
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Sep 09, 2008 | Microwave Ovens
I have display, but no lights, no fan, no power!
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Glad you found the "mini-manual". It's very helpful when troubleshooting & testing.
Sep 05, 2008 | GE JE2160 Microwave Oven
Microwave will not turn off
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Kenmore 66312/66319 Microwave Oven
Maytag Microwave MMC5000
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 29, 2008 | Maytag MMC5000 Microwave Oven
Fujitsu ScanSnap fi-5110EOX2 Pass-Through Scanner Logo
127 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tony
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
