Question about Pioneer Audio Players & Recorders
Need a head of Pioneer pd-t305.how do i get or where do i get?!?the laser head has been damaged need a new laser head.
    Top Expert:
  • Pioneer Master
  • 73,698 Answers
Www.alibaba.com
Try this site.
google.com/+GopakumarGopalan
Posted on Apr 16, 2014
2 Suggested Answers
  • 122 Answers
SOURCE: Hi, I have an old pioneer CD player and have been
if there was its not gonna be cheap, its better if you buy a new one than have it replaced
Posted on Feb 14, 2010
Pioneer PD-M40 changes through all 6 cds but does not stop to read any of them
The laser pickup assembly is at the end of life, remove top to expose the laser lens, use a Q-Tip and rubbing alcohol and gently clean, allow several minutes to dry, if no change! far cheaper to replace the cd changer.
Jul 02, 2012 | Pioneer PD-M603 6-Disc CD Changer
My pioneer PD-M426 seems to only play disks 3 and 4 even when the magazine is full, sounds like its trying to spin the disk but failing..??
Please remove the magazine and check if there is warping within the magazine which can cause misalignment. In such a case you will need to replace the magazine . Also check all the CD's within for any damage, sometimes some spurious types can warp with heat.If so it will not load and play. Test in another cd player to confirm.Also clean the optical head within the player if this fails to read or else the optical head can be also weak.
Mar 11, 2012 | Pioneer Audio Players & Recorders
I have a Pioneer PD-M550 6-Disc changer. When I try to play a disc, it won't spin... UNLESS I turn the unit upside-down. Then it plays just fine. So the lens is fine, but something is keeping it from...
Hi. You need to replace the opu (optical pickup unt), laser in other words. The laser diode is slowly getting weaker and the lens works in conjuntion with the laser. The reason it works when it's upside down is because gravity is pulling the lens closer to the disc, thus it does not need as much power to focus onto the tracks etched into the disc. Replace opu with type PEA1030 aka PU-23 http://www.donberg.co.uk/catalogue/laser_units_cd_dvd/laser_pu_23.html. Hope this helps you out and good luck.
Mar 08, 2011 | Pioneer PD-M603 6-Disc CD Changer
Pioneer PD-M501 6-CD Player manual and what magazine cartridge
CDs go in the Upside Down position. Your PD M501 will accept PRW 1139, PRW 1141 and 163.
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM
May 15, 2010 | Pioneer PD-M603 6-Disc CD Changer
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
BMW 740 OEM and others.
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
It will pick up the cd's but won't play them. I have taken them out, cleaned them and put them back in. I have tried different cds in different slots and it will only pick them up but will not play any...
The laser head needs a clean with isopropanol. This needs to be stripped down and use a cotton bud on the laser head. You can buy a bottle of isoproponal from your local chemist.
Dec 05, 2009 | Pioneer PD-F407 25-Disc CD Changer
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
Many Magnavox, Denon, JVC,
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
Pioneer PD-F805 can`t read discs.
Few things either cd,s are not compatible
laser has died or laser ribbon cable is broken
Jan 07, 2009 | Pioneer PD-F805 CD Player
Pioneer PD-F505 Cd Player - The player picks up the CD and it starts spinning. A high pitch squeel sound starts as soon as the CD starts to spin. The unit spins the CD for about two to three seconds and...
Sound like laser assy defected in any case you need a Technician from Pioneer or they are trained by Pioneer is very complicated to remove the laser and replace it you need an osilloscope to aligment a new laser and special disc to do that. It might not worth to repair it, the laser itself a bout $110.00 Aus
Nov 30, 2008 | Pioneer Audio Players & Recorders
Pioneer PD-F907 CD wont play most of the time
MOST LIKELY IT SOUNDS LIKE THE MOTOR THAT SPINS THE DISC - NEEDS REPLACING
Jun 26, 2008 | Pioneer PD-F907 CD Player
56 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
