Question about Samsung Refrigerators
Control panel will not respond
After a power outage
    New Friend:
  • 81 Answers
Power outage could have fried the main board.too much electronics on every thing.plug every thing into a surge outlet.if you do have a bad board go to core centric solutions store.com and find the return for repair page,find your part #and see how much to fix.very good site.have used them to fix several boards!!! hope this helps.
Posted on Apr 17, 2014
3 Suggested Answers
  • 184 Answers
SOURCE: Kenmore 596 - temp control panel not responding
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Okay, hope this will help in solving problem
Posted on Aug 08, 2011
  • 489 Answers
SOURCE: After a power outage, the control panel on front
The control board went into self diagnosis when the power was applied. It found an error in one or more of the systems. You will need a qualified technician to come out and see what the problems is. To bypass this problem for now, press the "Super Freeze" button and the "Super Cool" button together for 6 seconds simultaneously. This operation will put the refrigerator back to normal operation till the power is interrupted again. Good luck.
Posted on Jun 19, 2011
Our dryer does not function after a slight power outage due to an electrical storm. The number 88 blinks for a minute then goes to 18 . There is no response to the control panel , no buttons work!
brand and model numbers would be very helpful. without this info, I would try unplugging, wait about a minute, then plug back in. sometimes units can be reset by just cycling the power. Good luck.
Aug 05, 2017 | Dryers
Control panel is not responding
Most likely, if power *is getting to the unit*, (there are lights lit on the washer), then the culprit will be a shorted user interface board(control panel). This is a fairly common type of issue with dishwashers. The soft-touch buttons or the touch panel has a shorted button or area(depending on the type you have) and nothing else will function because the unit thinks you're still pressing a control button. Also, a VERY common cause of this issue, aside from moisture or bugs, is a power outage damaging the console when power is restored due to a surge. After an outage where damage occurs, the symptoms don't usually start for about 3-4 weeks after due to damaged chips on the board starting to fail.
Aug 20, 2015 | Dishwashers
After a power outage my Samsung SRS580DHLS is displaying and flashing SE? What does this code mean and how do I fix it? Rirht now the control panel only displays SE and does not respond to any presses
Your control board is reacting to a surge in power. Unplug the unit for 5 minutes then replug and follow normal starting procedures. If that does not work think about buying a new unit.
Oct 11, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Hi. We had a power outage and now the control panel will not reset. Any tips?
Hi and welcome to FixYa, I am Kelly,
Press power cool and power freeze at the same time for 8 seconds.. The control panel should reset. If pressing pwr cool and pwr freeze shuts off the compressor it can be 10 mins of more before it restarts. If it does not reset... respond here and I will dig through the service manual and get back to you.
Kelly
Apr 28, 2011 | Samsung RF267AB (25.5 cu. ft.)...
We had a power outage and the display is blinking and there is no response to pressing any button
First, try unplugging the microwave for 2 to 5 minutes and then plugging it back in. Sometimes, a very brief power outage will be sensed by the control as an internal error and the control will lock itself out.
If it continues to blink and does not respond to key presses after this "hard reset", it is likely a portion of the control board could have been damaged from the power outage.
FYI ... the touch panel for this model is no longer available. I mention that because no response from any key press can also denote a shorted key pad.
Apr 15, 2011 | Frigidaire FMT116E1W Microwave Oven
I have an Amana AOES3030 - we had a power outage and now the only button on the control panel that responds is "oven cancel". The clock is running and where the temperature shows when cooking...
Before doing anything else, turn off the power at the circuit breaker and leave it off for a few minutes... then turn the power back on and it should start up again and be okay...
If this does not fix it then the control board is fried...from the power surge when the power went out...
heatman101
Nov 23, 2010 | Amana AOES3030 Electric Single Oven
Green light on front rapidly blinks after power outage. No picture, or can't turn on
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
Apr 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Vulcan CX Central ducted heating. RE: Following a power outage the control panel does not respond, I have checked the pilot light and it is still on. I need to know how to reset the time and get it to...
The control panel gets its power from the central heating unit's power point. Try turning the power off outside at the powerpoint next to the ducted heating unit and try turning it on again after a few seconds, see if it resets
Jul 06, 2008 | Heating & Cooling
Refrigerators Logo
101 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
