Question about Samsung Refrigerators
Refridgerator goes offline
When power goes off and goes back on the control panel malfunctions
    Sergeant:
  • 249 Answers
Do these outages happen regularly? Is electricity supply unreliable in your area?
Do the lights just dip in brightness or do they go completely off? (Brown out instead of black out)
If you are having supply problems in your area, you should talk to your local power utility company.
If this is a new build and there is a fault in your electrical installation, the company who installed it should repair it at their cost.
It's important to know the limitations of power supply in your area. You may discover that something else in your house is drawing too much power and tripping your supply. You will need to pay for any fix in this case.
Your local power utility company may be able to provide advice on how to address this issue.
Posted on Apr 16, 2014
Stopped working
I had the problem with a totally different refrigerator but it was the fuse on the printed circuit panel mounted in the back of the refrig.
Nov 20, 2011 | LG LSC27910 (265 cu ft) Side by Side...
HI everyone i have a panasonic BL-C1 network camera and it keeps flashing red and tells me to update the firmware. i tried downloading the firmware from the product site and everytime i update the camera...
might highly be due to wrong firmware of malfunctioning due to wrong firmware being installed might wanna recheck the firmware your getting is the exact right one for your model camera
Apr 22, 2017 | Panasonic BL-C1 Network Camera
My printer goes offline when I shut it down. How can I get it to go back online when I turn it back on without reinstalling it?
After turning the printer ON,
Go to Start ->Control panel->Printer and faxes
Right click the printer and select "Use printer Online"
Sep 09, 2010 | HP Photosmart C6100 All-In-One Printer
When printer is offline, how do you bring it back online?
First, make sure it's power on, and all the cables are secure. Then, go to the control panel > printers, right click on the printer and choose "use printer online."
Mar 25, 2010 | Epson ACULASER CX11NF All-In-One Printer
I have a 500gb Hitachi sata drive on a gigabyte GA-Ma78gm-s2h mb that ramdomly goes offline. Takes shutting down computer and restarting to bring back on line
well this normaly happen if you have more than one drive on your computer and in order avoid this problem change the power supply settings inthe control panel to always on scheme.
Good Luck.
Jan 07, 2010 | Hitachi 500GB 7200RPM 16MB BUFFER SERIAL...
If my HP C5280 goes "offline" how do I get it back "online"??
1. Check to make sure the connection to the printer is good.
2. Check to make sure the printer is powered on.
Once you are sure of that:
Vista
3. Go to start > control panel > classic view > printers
4. Right click on your printer and click use online.
XP
3. Go to start > control panel > switch to classic view if not already there> Printers and Faxes
4. right click on your listed printer and click on use online.
You should be good at this point, drivers may reload but should not need the disc.
Jul 03, 2009 | HP Photosmart C5280 InkJet Printer
HP deskjet D2300 series printer is showing offline .Power is already given to the printer.
check that the printer is turn on, if on turn it off and on again, secondly check by double clicking the printer icon on your pc start bar i,t will open a pop/dialogue box, click on file and see if the offline is tick if so disable the tick.
May 26, 2009 | HP DeskJet F380 All-In-One Printer
Printer goes shows offline, but it is not offline.
either one of the catridge is malfunction, try remove one of it and vice versa see if it not blink. if not, the catridge that you have removed require replacement..
Mar 05, 2009 | HP DeskJet 3940 InkJet Photo Printer
HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Dec 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
Offline and blinking lights
A couple suggestions. Unplug the usb cable from the pc to the printer, make sure there is no paper jammed in the machine, unplug the machine from the wall and see if you can move the print head left to right freely. If nothing is obstructing it plig the power cord in with out the usb cord plugged in. See if the machine goes to ready. If all of these fail, that means the main board has been damaged by a power surge, and it would be cheaper to replace the machine than repair it. Good luck!
Jun 28, 2007 | Dell 942 All-In-One InkJet Printer
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
