Question about Garment Steamers & Presses
IS 9100 the joining element (the hose that comes out from the base) has cracked. I am sure I can buy the part but does anyone have experience in doing the work here? I'll bet I have to break this t
Rowenta IS 9100
Shark Super Steamer
The steam generator is defective.
Aug 28, 2016 | Euro-Pro Shark Super Steamer
Quest 2600w steam iron
The heating element may have failed.
Jul 19, 2014 | Garment Steamers & Presses
My steamer is no longer producing steam, how do I fix?
To troubleshoot something like this.
1. make sure it's plugged and the outlet is working.
2. Is it getting hot? If not, either the heating element is burned out or not getting power.
3. If it is getting hot check the steam ports for calcium build up (run straight vinegar through it)
Jul 14, 2014 | Garment Steamers & Presses
Home touch garment steamer model ps-280 wont turn on
If it were left on its possible that the element that heats the water has burned out think blown light bulb have your Mr Test it with a ohm meter to see if the circuit is open
May 02, 2014 | Garment Steamers & Presses
Heating pad is wrinkled so clothes come out wrinkled
I thought my old one was faulty so I bought a new one and still experience the same wrinkling problem!
Dec 22, 2013 | Corby Trouser Press 7700
Doesn't steam
the hoses sometime kink when hot then get hard in the kink part once cooled down.. you may need to fin the area and warm it up to let the steam pass..
Dec 13, 2013 | Haan Complete Multipurpose Steamer MS-30R
My hand held little steamer will not get hot. switch comes on, but that is all it does
If the switch isworking then the only possible fact is that the heating element has failed and it might be too costly for a change.
Jun 10, 2013 | Ingenious Designs, Llc My Little Steamer...
Garment Steamers & Presses Logo
47 people viewed this question
Top Garment Steamers & Presses Experts
Tom Chichester
Bill Boyd
ray gallant
Are you a Garment Steamer and Press Expert? Answer questions, earn points and help others
