Question about Nintendo DS Video Game Consoles & Games
0000fefe display say 0000fefe
    Problem Solver:
  • 23 Answers
HAHAHAHAHAhaHHAHAHAfjeaiajfiu!
No idea what you mean.
Posted on Jun 14, 2014
0000FEFE is the error code i got what happened?
This is from the Nintendo website:
http://www.nintendo.com/consumer/systems/dsi/en_la/0000FEFE.jsp
Feb 09, 2015 | Nintendo DSi Black Console
Stop one mac screen from becoming multiple screens
Mirroring displays the same image on each display.
  1. Make sure your additional display is properly connected and powered on.
  2. From the Apple (?) menu, choose System Preferences.
  3. From the View menu, choose Displays.
  4. Click the Arrangement tab.
  5. Enable (check) "Mirror Displays" in the bottom-left corner.
In the example below. the blue boxes represent each display that is connected. The white bar at the top of both boxes represents your menu bar and is shown on both displays when they are showing the same information.
When mirroring, your Mac attempts to match the closest resolution between the primary (or built-in) and secondary displays.
The usable resolution is the closest matching resolution for both the primary and secondary display. If you choose a resolution that is not supported on both displays, OS X reverts to using the closest matching resolution.
Extended desktop With extended desktop, your displays are treated as one, continuous desktop.
  1. Make sure each display is properly connected and powered on.
  5. Disable (uncheck) "Mirror Displays".
In the Displays pane of System Preferences, each blue box represents a display that is currently connected. The size of each box is relative to the current resolution of the display it represents. In the example pictured below, the larger box on the left represents an Apple 27" Thunderbolt Display, while the smaller box on the right is the built-in display of a 13" MacBook Air (Color LCD).
The white bar at the top of the left blue box represents the menu bar you see at the top of your display. Menu bar placement determines which display is treated as the primary display in OS X. To change your primary display, click and drag the white bar from one blue box to another.
You can also drag any of the blue boxes to change a display's represented location. Use this feature to make sure the connected displays match their real world location when navigating your desktop.
As shown below, each display retains its maximum resolution setting as they are operating as individual displays showing a continuous desktop.
lion_choose_max_resolution_.pngPress Command-F1 to toggle between video mirroring and extended desktop
Press Command-F2 to detect displays
May 01, 2014 | Apple 24" iMac Desktop
How do I fix the nintendo dsi error code 0000FEFE?
tengo el mismo problema estaba haciendo fotoshop. se enciendo el flash. y luego apagamos el d.s y al volverlo a predender. sale error 0000fefe si tienen otra solucion se lo agradezco este aparato es de mi nieto.
Dec 18, 2011 | Nintendo Dsi Pink Console
My dsi got the 0000fe error code how do i fix it
Message 0000FEFE received at startup
If both screens on your Nintendo DSi or Nintendo DSi XL go blank except for the message 0000FEFE when you turn on your system, then your system will need to be repaired.
May 31, 2011 | Nintendo DSi White Console
Yellow letters on top of upper screen ooofeoo when i turn on the ds
As I could not find anything about error "ooofeoo", I will post for an error "0000FEFE".
If both screens on your Nintendo DSi or Nintendo DSi XL go blank except for the message 0000FEFE when you turn on your system, then your system will need to be repaired. Please click here to determine your repair options.
If this does not help, please comment with more information about your problem.
Feb 05, 2011 | Nintendo DSi XL Burgundy
Error code 0000FE00
This error is a fatal hardware error. Unfortunately there is nothing user side that you can do to repair the unit. You will need to go to Nintendo's website to get technical help. More specifically, follow this link: http://www.nintendo.com/consumer/systems/dsi/en_na/0000FEFE.jsp to get help.
You should not return the unit to the store you bought it from, unless it is under warranty. And even then, the store may not be able to do much. They will most likely tell you to return the unit to Nintendo for repair. Nintendo can determine if your DSi is under warranty, and can work with you to replace your DSi if it is under warranty. If not, there are repair options still available.
Jan 11, 2011 | Nintendo DSi White Console
What does 0000fefe mean on the dsi
0000fefe means it had a bootsector integrity failure. You're kinda screwed over unless you manage to get the flash memory de and re-soldered to another DSi. Send it in to Nintendo.I know that this is an old question, but a lot of people look at it and I thought I might help.
Jan 24, 2010 | Nintendo DSi Black Console
Menu display intermitent
display is disclosed which produces multiple visual displays in an intermittent manner which includes a display housing having a perimeter wall which is transparent during visual display and is an opaque mirror between visual displays. The perimeter wall of the display housing is a composite structure which preferably includes a transparent cylindrical substrate which is coated with an optical film and an opaque mask which defines display windows. Multiple visual displays are produced by a rotating display base which carries rows of rotating display elements. Preferably, the display elements are elongated triangular elements having three image faces which bear images which create the visual displays. The triangular display elements are arranged in a triangular configuration wherein the rows intersect one another at acute angles and are carried by the rotating base. The rotating base includes three display positions and each of the triangular elements includes three display positions. A stationary observer would see nine different visual displays and may see themselves mirrored in between and during the changes of visual displays. The perimeter wall of the display housing becomes transparent as the triangular display elements are backlit along their entire length by elongated fluorescent or neon light tubes. When the light tubes are off, the cylindrical display housing is an opaque mirror, preferably, about its entire periphery and height. Other embodiments of the invention include a single row of triangular display elements, and a rotating display base which includes display faces consisting of only a single display element.
Feb 25, 2008 | Solarism LM-1730 (Black) 17 in. Flat Panel...
Video Game Consoles & Games Logo
26 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
