Sunbeam hot shot - what is the voltage - Heating & Cooling
    New Friend:
  • 84 Answers
Apply an OHMS LAW so that you can make a judgement.look for the power(watts)and ampere specified to any part in it of it`s out door unit.
P= I * E
convert the BTU to horse power to watts then devide it by the specified ampere =electromotive force/voltage
Posted on Apr 23, 2014
Sunbeam heat pad says it requires 120V ac outlet. I plugged it into every outlet right out the box and have only gotten a red blinking light.
what voltage is recommended for the unit
It it says 120 volts but you have different voltage the it may be damaged from the incorrect voltage
if not the case take it back for a warranty exchange as it is faulty from go
Dec 28, 2015 | Sunbeam Heating & Cooling
My sunbeam fry right deep fryer is not getting hot and this red shock light is on,what does this mean?
Sunbeam FryRight 3242 Owner Manual
please check above link or just do a web search for your make and exact model details and the words owner's manusal
Jul 12, 2015 | Sunbeam Kitchen Appliances - Others
Sunbeam em6910 brewing does not stop
Use a bigger glass or cup . easiest fix I can thnik of
Jan 10, 2015 | Sunbeam Cafe EM6910
No water coming out of hot side of dispenser, only cold
Like most coolers that have "hot" works of a "preheat" if you are not pumping out anything there is an obstruction that needs to be cleared.
Oct 23, 2013 | Sunbeam Hot Shot Hot Water Dispenser...
Sunbeam hot shot leaks
Unfortunetly, most modern manufacturers do not supply replacement parts, however if the unit is still under warranty, you could probably have it replaced for free. Contact the manufacturer or retailer.
Nov 16, 2012 | Sunbeam Hot Shot Hot Water Dispenser Black
The water does not cool
the problem is in the compressor cooling unit, if you have no knowledge of electrical this is beyond your ability to service, it is of refrigerator technology, if so contact me and i will try to help you.
May 18, 2012 | Sunbeam Hot Shot Hot Water Dispenser...
Does not seal when water is added. Water drips out
Filled Hot Shot with vinger, let it flow through at 15 minute intervals for a couple of hours.
Apparently the water here had lime and removed the buildup that was causing the leak.
Nov 18, 2009 | Sunbeam Hot Shot Beverage Maker () 2...
The plastic liner that holds the gasket in the water tank area where you place the 5 gal bottle over the spigot and spigot screw down to hold this plastic lid onto plastic gasket is warped and lets water...
you will have to get the parts to be replaxced if the gasket is cracket or the inner plastic is cracked you will have to first check out and order that particular part as this parts are not very costly but its not repairable.many users face the same problem of leak when the gasket gets pushed in the plastic and cracks .this creates leak when water passes through that area. -------------- you can get the required parts from -- http://www.repairclinic.com/SSPartDetail.aspx?s=a12i868872&PartID=868872 ------ just click the link directly. ---------- you can also click this link directly and contact sunbeam service center to replace the parts http://www.householdappliance.com/hot_shot.html ---------------- this will help.thanks.please do rate the solution.thank you for using fixya.keep updated.
Oct 13, 2009 | Sunbeam Hot Shot Hot Water Dispenser...
Sunbeam water cooler SA12587 - no hot water
I have a Sunbeam water coooler YLR2-5 87H
My water cooler is not cooling at all. What should I do?
Nate 901-754-0028 or nstclair1@aol.com
May 11, 2008 | Refrigerators
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
