Question about Vacuums
My bissell shampooer wont release water or shampoo
  • 3 Answers
SOURCE: won't release shampoo
If your floor cleaner doesn't spray, chances are the heater unit is clogged. It is easy to fix if you have a few simple tools and are mechanically inclined.
Steps to fix:
- The heater unit is located inside the body of the machine, behind the power/heater switches. Remove 6 screws and split the case open.
- The silver metal "box" inside is the heater unit. Take note of how the hoses and wires are connected. Better yet, take a digital photo for reference.
- Remove the wires and hoses.
- Take the box to a work bench, and unscrew the 6 or 7 screws that hold on the lid. Don't lose the red washers that are found on the inside of the box that keep water from leaking out of the screw holes
- You'll see a "maze" where the water runs around to get heated up. Clear this of all debris. The inlet and/or outlet ports may also be clogged. I used an appropriate sized drill bit mounted on an electric screwdriver to carefully "drill" out the clogs. Make sure all the debris has been removed. I used an electric screwdriver because my 18v DeWalt hammer drill would have been overkill :)
- Reassemble to box
- Rewire and plumb the box according to your notes or reference photo.
- Put the machine back together.
Doing this saved me a $85 repair and took 30 minutes. My machine now works perfectly.
Posted on Dec 14, 2007
reddevil6
  • 1673 Answers
SOURCE: shampooer tank not working
Most times there is a problem with the cap and insert at the bottom of the tank, part #2036675. Either that or the tank isn't sitting flush and down all of the way, leaving a gap. If this is less then 1 year, then it is under warranty.
Posted on Feb 06, 2008
reddevil6
  • 1673 Answers
SOURCE: bissell carpet shampooer
First check that the top cover on the back side hasn't come loose. Sometimes the plastic around the screws break away and the top starts to separate, raising the tank, and no spray. Make sure that the gaket is on the valve at the bottom of the tank and not sitting loose in the hole. Check the pump belt. The pump may be bad.
Posted on Jun 17, 2008
reddevil6
  • 1673 Answers
SOURCE: bissell power washer 1694 shampooer
First off is the gasket on the bottom of the tank vavle or sitting in the hole. It has to be on the bucket. May have a problem with the handle not pushing the valve (in the handle)open when you squeeze the trigger. Check the back end of the top cover to make sure it hasn't broken loose from the base, if it has, that raises the top so water won't dispense from the tank. The draw back is that Bissell has obsoleted some parts for this model.
Posted on Oct 03, 2008
SOURCE: vax carpet shampooer wont release shampoo
if you unscrew a bit on the base that allows you to take off the brush, you will see a black plastic strip with very small holes in it. These are where your shampoo comes out of. Take a needle and re-pierce these holes and it should work again. I have just sorted mine out. good luck .
Posted on Mar 08, 2009
We have a Bissell Pro-Heat 9200 2X Carpet Shampooer. When you start to shampoo the carpet it runs water for a minute and then quits and won't spray any more water.
I can not solve it, but have had the same problem with 3 of their shampooers. I am on my 3rd one. Have taken it back to be repaired and it still does not work. Thank God we bought the extended warrenty and they have replaced them. Now my newest one that I have only used 3 times is having the same problem.
Jan 30, 2011 | Bissell Vacuums
Bissell shampooer 1697-W. Will not dispense water to shampoo carpets....
That means that the pump belt is worn and needs to be replaced. Here is the belt you need and a manual you can view:
Bissell Proheat Belts and Manual
Dec 13, 2009 | Vacuums
Bissell steam cleaner will not spray shampoo
My Bissell stops releasing shampoo when the handle is lacked upright, when there is no water in the tank (the most common cause of this issue), or when water is not flowing through the machine because the sprayers are clogged.
Make sure the shampoo container grommet is releasing properly when you press the trigger. To check this, remove the shampoo tank from the Bissell, stand over a sink, and use a finger to push up inside the grommet on the shampoo container, the part of it that mates with the rest of the Bissell. Shampoo should dribble out when you do this. If it won't, the grommet may be clogged.
May 29, 2009 | Bissell 7950 ProHeat Upright Wet/Dry...
NO WATER COMING OUT FOR SHAMPOOING /DUMPS WATER WHEN UPRIGHT
there is a belt inside that runs the pump to spray the water. I would take it in a have it replaced. Mine did the same exact thing.
May 25, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissel shampooer
yes there is a belt on the side that will need to be changed
Jan 13, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell carpet shampooer wont dispense water
Bad Pump. You pump is where the belt attaches to spin the brushes and also puts water on the floor. Take it to you local Best Buy to be serviced or a local appliance shop which may service it.
Dec 15, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Vax carpet shampooer wont release shampoo
Jun 01, 2008 | VAX Appliances Vacuums
I dont know how to change a shampoo pump on a bissell shampooer. Do you have instructions for me?
I need instructions how to change a shampoo pump on a 8910 bissel floor cleaner
Apr 01, 2008 | Bissell Vacuums
Vacuums Logo
18 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
