Question about Samsung 1.8 Cu. Ft. Over-the-Range Microwave
Microwave starts by itself
Model smh9187st Microwave will start by itself in baked potato setting- only 2 years old. Do you have a fix?
    Prodigy:
    An expert who has answered 500 questions.
  • 547 Answers
Likely a microprocessor/control panel issue. Microwave ovens that sit over ranges often have electronic failures due to heat, humidity, and grease, from the range below, which come into contact with their main circuit boards.
Posted on Apr 17, 2014
5 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave oven built in
If it's less than a year old, you should contact the manufacturer for free warranty repair.
If it's older than that, the magnetron should be covered for anywhere from 5-9 years.
I would certainly contact the manufacturer. If you don't have your owner's manual, please reply back with your brand and model number so we can help you link up with them.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 30, 2008
SOURCE: Microwave turns off after 1-2 seconds
It turned out to be the three door attachments that weren't lined up. It has been fixed. We almost bought a new one because Samsung referred us to a service that would have charged way too much to be worth it even thought the machine is only 3 or so years old. Luckily, we looked further. A local independent appliance fixer came to the house and took care of it within a few hours of my call! Yea!
MicrowaveSvc
  • 9047 Answers
SOURCE: We are getting an error code of 5E. Microwave
"SE " means your membrane keypad is shorting. And it is specifically the baked potato key that's shorting.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking. Better still, unplug it and do not use it.
We would need the model number in order to provide you with free assistance.
It is usually found on a tag located inside the cooking cavity or around the door frame or controller frame.
Since FixYa is still not notifying us when you respond to clarification requests, you will have to post a new help request with your model number and symptoms / questions or contact us here for free assistance.
Posted on Sep 18, 2011
SOURCE: I have a Samsung SMH9187ST microwave, it is about
If you can lift the plastic door latch catches with no resistance, it is most likely the spring/plastic connector. I removed the door by lifting up, pulling the bottom forward, and lowering. I removed the inside black plastic bevel with a jewelers flat screw driver, prying from the latch side's external edge. Once it was started, I could pull it of with a gentle lift. I took out the black plastic latch, drilled a hole near the broken piece and all was good. Samsung is not on my radar for any future purchases. This is the 3rd major purchase that barely made it past warranty or not even thru warranty.
Posted on Nov 27, 2011
While baking a sweet potato, the potato exploded and caught on fire. The microwave no longer works.a fire bro
I haven't heard of such a thing. You must have cooked it until there was no moisture left in the potato. That would also account for the failure of the oven. It would be the same as no load in the oven.
A thermal protect part is your current problem.
Apr 02, 2014 | GE SpaceMaker Microwave Ovens
Where can I repair dawoo microwave
Try contacting Samsung for the SE error. They fixed my SMH9187ST microwave for free even though it was 4 years old. 08/14/2013.
Aug 14, 2013 | Daewoo KOR-1B4H Microwave Oven
Samsung Microwave Mod # SMH9187ST. Starts on its own, "bake potato" on display screen. After shutting down, code SE appears on screen. No response from keypad until unplugged. Reset and problem ret
Contact Samsung, I was having a similar problem with the SE error appearing on my microwave. Apparently its a problem with the control panel and they are going to replace it free of charge under there epidemic warranty
Mar 18, 2013 | Samsung SMH8165W Microwave Oven
Se code
Contact Samsung for the SE error message. They are fixing my microwave for free today even though it is 4 years old. Model #SMH9187ST.
Feb 22, 2013 | Samsung SMH7178STD Microwave Oven
I have an Electrolux High Speed Oven E30SO75FPS that's 3 years old and the Magnetron has failed for the 3rd time. What can be causing this?
Is the internal cooling fan working?
Are the ducts and vents clear?
Problems with any of those can result in overheating, which destroys magnetrons.
I have seen high voltage rectifier diodes interact with magnetron in funny ways. I'd replace the diode, too.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Finally, baking potatoes and making popcorn really give the magnetron a workout.
You should put about 1/2 cup of water in the rear corner of the microwave when cooking those foods.
It helps "preload" the oven to prevent execessive microwave energy reflection back to the magnetron.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Dec 12, 2011 | Microwave Ovens
We are getting an error code of 5E. Microwave automatically turns on to bake a potato.
Sep 18, 2011 | Samsung 1.8 Cu. Ft. Over-the-Range...
I have a 3-year old Amana microwave installed above my stove. Last night I was baking two potatoes in the microwave. I noticed that the microwave sounded "louder" than normal. After about 13...
No! But it will need to be repaired. Did you wrap the potatoes in tin foil? The reason for the smoke needs to be found and repaired. Smoking means a short or a part shorted, failed, or wires touching another wire that did not blow any fuss.That is not good.
Trained technicians can help the mfg improve their products if they find the problem and report it to the Mfg.
LOL
Jan 28, 2011 | Amana MVH210W Microwave Oven
prototech@usa.net
May 12, 2008 | Samsung MW1080STA Microwave Oven
Microwave Dead after burning up potato
Chances are the magnetron overheated and blew the thermostat / thermal cutout that monitors it. The magnetron itself may be bad, too. If Sears Service might consider this still under magnetron warranty, then they may replace the mag with no part costs (or just the thermal cutout part cost), but likely would charge labor. You can contact customer service or repair via http://www.sears.com Otherwise, if you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://www3.sears.com or likely cheaper here: http://tinyurl.com/gv383
Feb 06, 2007 | Kenmore 60659 Microwave Oven
Samsung 1.8 Cu. Ft. Over-the-Range Microwave Logo
149 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
