Question about ElectroVoice SbA760 15" Powered Subwoofer
How to reset the protection on a electro voice sba 760 active subwoofer ?
  • 45 Answers
Most of this protection are parmanent you cannot adjust any settings.
Posted on Apr 17, 2014
I need Behringer TRUTH B2092A Subwoofer service manual(circuit diagram). Please help...
You should contact Behringer customer service directly for the sevrice manual.
Sep 09, 2015 | Behringer Truth B2092A Studio Subwoofer...
How can i have dual voice on x5d korg? I lke piano and strings
Just go to COMBI mode.
Press PAGE+. The display may look like this :dual-voice-x5d-korg-lke-piano-strings-v3bkdlfzxxldunukh1pdnvp1-3-1.jpg
In the example above, A03 and A49 is a sound PROGRAM number.
OFF and OFF is a Layer 3 and 4, were not activated.
So in our example, we only activate two voices (two layers).
X5D can combine up to 8 voice. To view the Layer 5-8, press PAGE +.
To change the sound of your choice, move the cursor to the corresponding layer, use this button:
then change the value with the slider / value key (YES and NO):
You can also set the level of each layer.
Press PAGE + until a menu appears LEVEL.
Move the cursor and sets its value
May 30, 2013 | Music
My peavy 118 subs dont play as loud anymore what could be the problem.
Circuit resistance from corrosion, or broken strands int he flex wire connections between voice coil and the terminals. It is also possible the voice coil form is distorted. It is also possible a capacitor in the amplifier is in the early stages of failure.
Jun 11, 2012 | Peavey Pv118 1x18" Subwoofer Speaker...
Eaker seemed to glow around the edges whilst in use is this normal/
Edges of what? The cabinet? The woofer? The center of the woofer? If you have certain lighting, the flexure at the edge of the cone may go through a point that it reflects light.
Sep 14, 2011 | ElectroVoice Ev Zx4 15" 2way Electro-voice...
Our sound system runs two separate xl 5000 crowns individually to 2 srx728 subs(2241hpl speakers). Amps are run bridged and have been connected to "discrete" inputs on cabinets (I think this is...
More than likely you have lost the speakers... You sent TOO much power to them and likely the voice coils have heated and distorted and are rubbing the pole pieces and hanging up on them. If the voice coils now short some of the windings, next you will lose your amps as well. If you can access the cones, you can try gently moving them in and out with your fingers and you can feel the voice coils rubbing sometimes. REMEMBER ALWAYS check the RMS rating of the speakers against the RMS ratings of the amps... DO NOT fall for the "advertising" things of "peak power" and "program power" ratings... these numbers are to sell equipment... Use RMS continuous ratings when sizing amps to speakers. Typically the RMS continuous ratings are 1/3 of the peak or 1/2 of the program ratings. You will find amplifiers rated either way so you have to dig out the real ratings. In bridged mode the full output of both halves of the amp work together. Your speakers are rated at 1600 Watts continuous... I am not sure I believe that number even... you would be deaf in front of that quickly... Your amps appear to deliver 5000 Watts RMS in bridged mode... over three times what the speaker is rated at. Since you have the amps, set one aside and run each speaker from one side of a single amp NOT using full gain AFTER you get the speakers re-coned. I would recommend putting a fuse in the speaker lead to HELP protect the speakers when repaired.
Aug 12, 2011 | Jbl Srx728s Dual 18" High Power Subwoofer
I have a electro-harmonix , voice box , harmony machine and vocoder! I need to know what kind of power supply to use , as I have lost mine !
Takes a 9 volt DC 1 amp (1000 ma) center positive adapter. Not too common, search online and at Ebay.
Jul 28, 2011 | Music
My Peavey PV-118 18" subwoofer
Peavey uses a protection network and sometimes it gets blown when too much power is sent to the speaker. The speaker may be blown however. Peak power for this is 800 Watts and 400 Program... That is NOT RMS power. Make sure your amp is no bigger than 300 Watts RMS driving this. If you are REAL lucky, maybe a lead has fallen off the speaker... Open the unit inspect and test the components.
May 15, 2011 | Peavey Pv118 1x18" Subwoofer Speaker...
How much is the driver and where can i get it from asap
if you hurry this one is $60 http://www.bracesinfo.com/store/Electro-Voice-woofer--EVS-15SF-220697631956.html
or you could go the re-cone route which usually run $70 for that particular driver.
or just run a search on google for EVS15SF the exact driver for the Zx4 cabinet
they are in abundance, a lot of DIYers use them in floor monitors.
Dec 17, 2010 | ElectroVoice Electro-Voice Zx4 15" Passive...
Where do I find a replacement compression driver EV DH2010A
http://www.directproaudio.com/shop/shop.cfm?section=1475
http://www.speakercity.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=SC&Category_Code=SeleniumCD
Mar 30, 2010 | Music
How to send at same time main mix and alt 3-4 outputs signals
The subwoofer MAY only have a single channel. If so, you would just use either 3 or 4 to the subwoofer.
Normally you would just tap off the main mix. The only reason I can see for using the alts is to have seperate sliders for level control.
Oct 10, 2009 | Behringer Music
ElectroVoice SbA760 15" Powered Subwoofer Logo
167 people viewed this question
Top ElectroVoice Music Experts
Michial Gueffroy
Are you an ElectroVoice Music Expert? Answer questions, earn points and help others
