Question about Whirlpool Refrigerators
Whirlpool filter cant find filter on model gx2fhdxvy09
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,554 Answers
Here is your owner's manual:
http://www.whirlpool.com/digitalassets/MLPDF/User%20Instructions%20-%20W10366204.pdf
On page 13 it states, "The water filter is located in the upper right-hand corner of the refrigerator compartment."
Posted on Apr 16, 2014
I HAVE A WHIRLPOOL FRONT LOADER MODEL 3LSR6253E01 MY WASHING COMES OUT COVERED IN LINT. I CANT FIND A FILTER ON THE MACHINE IS THERE ONE? PLEASE HELP THANKS KATE
No, there is no filter- but you should check the drain pump trap for a mass of fibers/lint. Usually, there is a service door on the lower front of the machine that leads to the pump... Have some towels ready for residual water, but I would check there first...
May 26, 2016 | Whirlpool Washing Machines
Where is the water filter on my whirlpool model gx2fhdxvy09
Water Filtration System
Do not use with water that is microbiologically unsafe or
of unknown quality without adequate disinfection before
or after the system. Systems certified for cyst reduction
may be used on disinfected waters that may contain
filterable cysts.
IMPORTANT: The disposable water filter should be replaced at
least every 6 months. If the water flow to the water dispenser or
ice maker decreases noticeably before 6 months have passed,
replace the water filter more often.
Replacing the Water Filter
To purchase replacement water filters, model UKF8001AXX-750
or model UKF8001AXX-200, contact your dealer or call
1-800-253-1301 U.S.A. or 1-800-807-6777 Canada.
IMPORTANT: Air trapped in the water system may cause water
and filter to eject. Always dispense water for at least 2 minutes
before removing the filter or blue bypass cap.
1. Turn filter counterclockwise to remove.
2. Remove sealing label from replacement filter and insert the
filter end into the filter head.
3. Turn the filter clockwise until it stops. Snap the filter cover
closed.
4. Flush the water system. See "Water and Ice Dispenser(s)."
NOTE: The dispenser feature may be used without a water filter
installed. Your water will not be filtered. If this option is chosen,
replace the filter with the blue bypass cap.
User Manual=> HERE I am here should you need me, Thanks John Tripp Appliance 911
Apr 16, 2014 | Admiral 26 cu. ft. Side-By-Side...
WHERE CAN I FIND AN AIR FILTER FOR Whirlpool Air Conditioner Model ACQ062MM0
It depends where you are. This company has them
http://www.repairclinic.com/Shop-For-Parts/a16b5d619658/Model-ACQ062MM0-Whirlpool-Air-Conditioner-Parts?z=100
Mar 10, 2014 | Whirlpool ACQ158XP Wall/Window Air...
New filter installed. how to turn off "change filter" light
There is usually a reset button near the change filter light. Without the model number I cant tell you exactly where.Please comment me back so I can further assist.
Jul 30, 2011 | Refrigerators
Cant get filter off
I may not have the same model, but mine is located in the bottom grill. I use pliers to turn 1/4 turn clockwise and pull straight out, then remove the piece on the end that will fit on the end of the new filter, insert new filter all the way in, the turn 1/4 turn clockwise.
Jan 12, 2011 | Whirlpool ED2FHEXN Side by Side...
Whirlpool ref model #ED5PVEXVS00, need filter for this model. We don't know the part number needed or where on the refrigerator that the filter is located. Please help with both
The original part number is 4396841; cartridge T2RFWG2. The filter fits into the grill at the bottom of the refrigerator (nearly centered on the left hand side of the grill). There is a cap covering the filter.
The fridge can be used without a filter if the cap is taken off the old filter and put back into place. For a diagram that includes the filter and grill location see: http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0812046-00001.png . The filter is part 30 in the diagram. The entire set of parts diagrams, leading to parts list and prices are available here: http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Refrigerator-Parts/Model-ED5PVEXVS00/1198/0165000 .
Another on-line source for the filter is: http://www.partstore.com/Part/Whirlpool/Whirlpool/ED5PVEXVS00/Whirlpool/Whirlpool/4396841/New.aspx .
I hope this helps.
Nov 20, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Water filter for ed0gtqxkq00
I looked up your frig and I did not see a filter. If you want to use one, you can install what is called an inline filter. This is simply a filter you install behind the frig attached to the water line going to the frig.
All you have to is unhook the water line from the frig, attach it to your newly bought inline filter, and install another water line on the other side of the filter and hook that back up to the frig!
So now you have a filter and two water lines :) Just make sure to point the filter the right way, the usually have an arrow on them. The water is supposed to flow through them in a certain direction.
May 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Cant locate walter filter on whirlpool model ed20tk and eckmf94.
does not have one. you have to install a filter called an in line filter behing the refrigerator
Jun 21, 2009 | Refrigerators
Cant find the filter
check your hoses first. they have sediment filters in them, then check your water inlet valve, that is where the hoses hook to you machine.
Feb 06, 2009 | Whirlpool Washing Machines
Refrigerators Logo
107 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
