Question about Watches
Remove back from narmi watch
Cannot get under rim to pop off
2 Suggested Answers
watchmacher
  • 302 Answers
SOURCE: how to change the battery replacement on a narmi watch
back pries off, remove old battery, install new, snap caseback on.
Posted on Oct 08, 2012
How to change the battery replacement on a narmi watch
Sep 21, 2012 | Darice Narmi Square Frame Two Tone Watch...
How do I change battery on my gametime watch? how do I remove back casing?
My GAMETIME watch has a back which just pops off. Once in the battery compartment, you will see plastic disk, with a molded frame. This just simply pulls off, and is not secured in place. You should not have to pry it.
Once this is removed, the battery is revealed. My model takes a SR626SW. To remove the cell, use something small to get under the exposed side. You should be able to pop the cell out without much force.
Before you replace the battery take this opportunity to clean the rim where the backing was. Carefully install the new cell, and replace the cover.
Sep 21, 2010 | Gametime Watches
Dont know how to change the battery in my callaway golf warbird watch
Thank you for contacting Fixya.
Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal. You can find this sometimes by running your fingernail around the back rim, as this tab or indentation can be hard to see.
  • Pull out the stem, which releases the back on some watches.
  • Get a small flathead screwdriver it needs to be a thin inflexible tip. Use a kitchen knife as a last resort. Wrap the hand you are holding the watch with in a towel or protect your hand in some manner so you don't injure yourself if the screwdriver/knife slips.
  • Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
  • Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
  • When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch.
  • Best regards. Jewel
    Aug 27, 2010 | Callaway Quartz Golf Watch
    I have a cat watch and i dont know how to get the back of so i can change the battery.
    Thank you for contacting FixYa.
    I am not familiar with Cat watches, but here are instructions for basic watch backs:
  • 2Pull out the stem, which releases the back on some watches.
  • 3Get a small flathead screwdriver it needs to be a thin inflexible tip. Use a kitchen knife as a last resort. Wrap the hand you are holding the watch with in a towel or protect your hand in some manner so you don't injure yourself if the screwdriver/knife slips.
  • 4Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
  • 5Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
  • 6When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch.
  • Aug 24, 2010 | Caterpillar (UB141344020) Wrist Watch
    How do I open the battery cover to insert the batteries
  • Aug 23, 2010 | Fossil Metal Dress Silver Dial ES1053...
    How do I take the back off of my Relic watch to replace the battery
  • Aug 20, 2010 | Relic watch
    How do i get the back off
  • Aug 17, 2010 | Cosmopolitan Wittnauer Men's Goldtone...
    How do you remove a watch back
    Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal. You can find this sometimes by running your fingernail around the back rim, as this tab or indentation can be hard to see. Pull out the stem, which releases the back on some watches.
    Or take to a local jewelry store/watchmaker!!
    Aug 16, 2010 | Ben Sherman Strap Watch
    How do I get the back of my watch off so that I can change the battery? Womens watch model NY-3196
    If you have a watch with a dead battery, you can replace the battery yourself. However, it is often difficult to remove the back cover of the watch case. Every watch is different, some may unscrew, while others will pry off, particularly common in less expensive watches.
    Pull out the stem, which releases the back on some watches.Get a small flathead screwdriver it needs to be a thin inflexible tip. Use a kitchen knife as a last resort. Wrap the hand you are holding the watch with in a towel or protect your hand in some manner so you don't injure yourself if the screwdriver/knife slips.
    Or you can take to local jeweler to have them professionally do it with professional tools for between $8-15. My best advice there.
    Jul 26, 2010 | Watches
    Watches Logo
    47 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
