Question about HP PSC 1215 All-In-One InkJet Printer
HP1215 printer says out of paper and won't print
The printer has paper but when i press print nothing happens, no flashing on the printer...just nothing! When i investigate further ie when i check the printing status it says 'out of paper' .....not had this problem before! Help!!!
Reinstall the printer driver again.and hope the problem will be solved. if the problem still persists then visit below mentioned link for a free diagnosis.
http://tinyurl.com/m7ghqz
Posted on Jun 18, 2009
HP Deskjet 5650 - Troubleshooter keeps saying paper is low or out.
How to use the solutions in this document To resolve the issue, try each solution in this document, and then use the steps in this section to print a self-test report. This step determines if the product hardware functions correctly. When you have resolved the issue, and the product successfully prints a self-test report, there is no need to continue troubleshooting. Print a self-test page Follow these steps to print a self-test report.
  1. Load plain paper in the paper tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press and hold the Power button (c01602202.gif ).
  4. Press the Resume button (c01678098.gif ) four times. The self-test page prints.
c01733891.gif IMPORTANT : Try to print a self-test report after every solution even if the solution resolves the issue.
Mar 28, 2013 | HP DeskJet 5650 InkJet Printer
HP1215 All-in-One After switched on, the carriage move left - right (start-up procedure) and then go sits in the corner on its base, with the check paper and check print cartridge lights both flashing....
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Oct 29, 2010 | HP PSC 1215 All-In-One InkJet Printer
Light kee flashing orange/green and says computer is busy when there is nothing in print queue
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 29, 2010 | Canon BubbleJet i320 Printer
Orange light flashing - won't print
have you got a reset button on your printer if so try pressing it down and holding for a few seconds put some paper in and try again
Mar 25, 2010 | HP LaserJet 1100 Printer
Lexmark x2600 printer
Pull the tray out at the bottom of the printer. This is causing the printer to think it has a paper jam. It is simply the paper feed button.
Any other issues email me at derrickfoster3@gmail.com
Feb 21, 2009 | Lexmark X2600 InkJet Printer
Printing troubles
Paper jam:
Clear the paper jam. If the printer does not start printing, press the control panel button.
No paper:
Put paper in the printer. Then press the control panel button.
Misfeed:
Put the paper back in properly, and then press the control panel button. The printer will start printing again.
Mar 24, 2008 | Brother HL 1440 Laser Printer
Lexmark x1270 printer power button blinking won't print
I had the same issue with my Lexmark X1290, I solved it by opening up the device, so the ink cartridges should pop, they didn't so I pressed the power button to switch it off, and then switched it back on (with the device open!) and all the paper flowed out, the flashing stopped and it could print again. Good Luck!
Feb 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
HP PSC 1215 All-In-One InkJet Printer Logo
214 people viewed this question
Seeker5211
Seeker5211
