Question about Acer AL Computers & Internet
No display my model no is al1511.first time is working.but after some seconds the monitor no disply.that time the power light is green
  • Acer Master
  • 3,320 Answers
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Posted on Apr 25, 2014
  • 26 Answers
SOURCE: Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Posted on Feb 25, 2008
SOURCE: IBM ThinkVision 17" Monitor displays for 1 second then black
This seems to be a common problem with these monitors. Have a look very closely and see if you can still see something there. From there, either send it to get repaired, or, if you are handy with a soldering iron, open it up and replace the 4 main capacitors (at least one of them will be "popped", but it is handy to replace them all.
In order to open the monitor, you will need to remove the stand, and make sure you get all of the screws out before attacking it with a screwdriver.
I have 5 IBM monitors at work with the same problem, and opening them up has shown the popped capacitors.
Again, only recommended if you know what you are doing. Screwing it up will leave you with nothing.
Posted on Feb 03, 2009
SOURCE: Monitor black screen with blinking amber/green light
You need to reset the display. The display is in a safe mode. Resetting the display is a simple procedure and Planar has the instructions on their website in their online customer support section.
Posted on Feb 26, 2009
  • 1684 Answers
SOURCE: MAG 700P monitor display goes black after 60 seconds
Can you send pictures of the power board to me at tech@ccl-la.com I will check our service manuals for the model and get back with you about a solution.
Buddy
Corporate Computer
Posted on Jul 29, 2009
paulbtorrent
  • 34 Answers
SOURCE: ACER AL1914 LCD Monitor goes black but green light stays on
The monitor is doing a self test a finding an error.
The lcd has three parts, the screen plate(windows)/the logic(vga)/the inverter(power plug). Parts that go are the backlight ccfl's, behind the plate, and parts of the inverter, ie capacitors, all three take a bit of power from the inverter. The self test check that all the lights are ok and the inverter is ok, else it switchs off, ie if 3/4 light work it will switch off(my own case), hence the on chech error then off, However sometime there are stages of on/off ie on/ but no screen display, if that is the case the following may be of help...if you put bright light at an angle close to lcd can you see a windows shadow, text icons etc, ie still logic power passing,then .... (from a.n. other) after two weeks searching I finally find doctor living stone http://www.aplusperfect.com/articles/lcd_capacitor_repair more fun with paulbtorrent
the takening the case bit off is like opening your wallet a second time after buying a new LCD, but you must! smallest two screw driver's flat headed, practice using two pennies stuck together()with your fingers after, one little () move and inch and {} again, with the case , it does not break, just need to lever open
[once open you realize they somehow put that old briefcase clip inside!] also note the bright light test to do first to see if can see a windows screen , and that capacitors are one for a number of things that a make a inverter work! there a transistors as well, given that however, to replace all the capacitors on my inverter, was 11 capacitors, cost me $11 (uk ebay) and already had the iron and solder. So only cost me me $11 to try and see but no luck , still fun and I still can see the screen for 2 sec' at a time plus I have a spare set of caps now in the event that the new one do go burst! you have to laugh really, what next , a new on/off button, as you work though the whole inverter mmmMMMMmmmMMMMmmmMMMMTim Berners-leeMMMMMmmmmMMMMMmmmmcome back all is not wellMMMMMMMMMMnnnnnnweek later land sight mmmmmMMMMMMMMMmmmmgggggggg(from
another a.n other)Generally, if the screen went out quickly, it was the inverter. If it went out over a slow period of time (flickering etc..) I would bet it is the lamp.replaceing the lamp should be pretty challenging. as that requires complete breakdown of your LCD, extraction of your dead lamp, and soldering in your new lamp... but I would like to say that I it did this after realizing it's 2 x kitchen strips inside [========] with wires that can connect back to the inverter with out any desoldering(ie kit assembly/dis) with the outter case remove (glass plate safe away) I could reconnect and see that 3/4 were working (i!i hardcard ) cause the inverter to switch off after a secound ! order bult and replace and going
to cheap and see if I can get away with fitting a 15" in my 19' as it a 1/3 of the price ! the market as drop out there, hope the inverter does not miss the length, or the screen out put.http://www.lcdparts.net/howto/troubleshooting/LaptopCCFL1.aspx OR MONITOR
Posted on Feb 08, 2010
When I start my computer, the monitor can take up to a 1/2 hr to display. I have dual monitors; the 'Acer' will eventually blink/show 'Acer', then fade. It repeats every 3 seconds. The...
your problem sounds like you have bad capacitors on your monitors power board. once you start it, they do not have enough capacitance to give to start the monitor, but after letting it for some 10ish minutes or so, they capacitate enough to start. even then, after some time, they will lose the capacitance because they are feeding the monitor in constant power when the power from the outlet drops a bit, but being bad - they will shut off your monitor. some repair shops can change capacitors only, others would make you change the all power board
Aug 04, 2017 | Acer AL1511 15" LCD Monitor
Hi I am using the Acer AL1511 15 moniter from last 2years, now its not working properly. It is giving lines on the display (fully covered the display) and unable to see the actual display. Can you tell me...
look you have to either change or take it to the service centre.this problem is related to the pixcel of your monitor.this occur due to the fluctuation in the voltage signal.this cant be removed easliy.
Oct 19, 2010 | Acer AL1511 15" LCD Monitor
My acer al1511 monitor started shutting down after 2 or 3 minutes, the green power led turns orange(like no signal). if i turn the monitor power button off and back on the monitor works for 30 sec to 1...
Here are the service manual (not usre which model you have, downloads are limit to two per day):
http://elektrotanya.com/?q=showresult&megnev=acer&megnev2=al1511&kategoria=&kat2=all
You need to do some voltage checking make sure you do have 5 and 12v. The caps the secondary DC side should all be replaced at the same time, it may look OK but they can have high ESR, and they also should be low ESR type such as FM or FC series by PANASONIC. You can send me pictures if you want more help, budmrtn@aol.com
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 23, 2010 | Acer AL1511 15" LCD Monitor
I left monitor power on for about 2 months .when i finally noticed, it was off and wont turn on
rixwar, How many more hours of on time in addition to the approximate 1500 hrs (60 days) does this monitor have? I should guess that any monitor that fails before 4000 or 5000 hrs should be still covered by warranty. Maybe I'm lucky. My 16 yr old 32' tv is still operating after 20K -25K hrs on it. But then again it's a crt not a CCFL backlit lcd display.
You may need to repair AL1511 "switch-mode-power-supply"/"inverter circuit" in this one. Read more of my and other tech's FIXYA profiles on what to do about black or black and blank lcd monitors and for other options open to you. 12fixlouie.
Jan 31, 2010 | Acer AL1511 15" LCD Monitor
Acer AL1511 LED light keep blinking
Check the Data card which connect from monitor to CPU Video adoptor
Aug 21, 2009 | Acer AL1511 15" LCD Monitor
Buddy
Corporate Computer
Jun 29, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
Monitor display problem..
Change yor keyboard. If any one key remains pressd or if any pin is bent then evrything seems to work but there is no Display and no beeps or error messages either!......i too suffered the same once................sodeep
Mar 18, 2009 | Computers & Internet
Green led light flashing on 700p proview flat panel and no picture
I have a similar problem.
Switching the screen off (front panel button) and on again after waiting a few seconds fixes it.
This is a recent problem, so I'm expecting it to get worse and worse until one day!!!!!!
Oct 03, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Horizontal display size adjustment
Make sure the video resolution is set to 1024x768.
Right click on a blank area on your desktop. click properties>settings.
Oct 03, 2008 | Acer AL1511 15" LCD Monitor
Computers & Internet Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
