Question about Epson Stylus NX300 All-In-One InkJet Printer
The 'EPSON Scan' desktop icon on my computer won't work.
The 'EPSON Scan' desktop icon on my computer won't open my scanner, although if I go through My Computer to the Scanner it will scan through a Wizard. How can I fix this?
Hopefully this is stilll relevant to somebody, but if you run the program as administrator you can get in
Posted on Jul 22, 2010
How to scan documents to computer EPSON stylus sx410/tx410 ?
Hi Susan,
Basic Scanning
You can scan original documents and photos and save them as files on your
computer using the Epson Scan software. You can also launch Epson Scan from
any TWAIN-compliant application, such as Adobe Photoshop
1. Open the document cover and place your original face-down on the scanner
glass, in the front right corner, as shown on page 9.
2. Close the cover gently so you don't move the original.
3. Do one of the following to start Epson Scan:
Windows:
Double-click the EPSON Scan icon on your desktop.
Macintosh:
Double-click EPSON Scan in the Applications folder.
If you are scanning from an application, start your application. Then
open the File menu, choose Import or Acquire, and select your Epson
product
Select Full Auto Mode as the Mode setting
in the upper right corner. (If you are in
Home, Office, or Professional Mode, you see
a different Epson Scan window.)
5. If you want to restore faded color in a photo
or make other corrections, click Customize.
Then follow the instructions in the next
section.
6. Click the Scan button. The image is scanned
and you see its icon in Windows Explorer or
Macintosh Finder.
May 01, 2014 | Epson Stylus CX6600 All-In-One InkJet...
I need an EPson scan icon for my desktop...
Go to your Program files and find Epson. Then go into the folder and find the scan program. You will know which one it is if when you open it your scanner program will run. Once you find it, right click on it and send it to the desktop as a shortcut.
***If you need any technical help on printer then you can reach at here
Feb 15, 2013 | Epson WorkForce Office Equipment &...
Epson scanner cannot communicate
My solution was that Epson Scan was set to connect via network instead of local. (All was working fine, then it quit-something changed this setting) Try this, go to start, choose all programs, choose Epson folder, choose Epson Scan, choose Epson Scan Setting. In the pop up box set the connection to local or network, whichever is appropriate. Close the window and open photoshop and all works fine. It could be that your problem is the opposite of mine- I try switching this to the other setting even if the change is wrong, then switch it back to see if that works too.
Good Luck.
Jan 05, 2013 | Epson WorkForce WF-7520 Wide Format...
My Epson RX650 scan software will not start up. The printer works and the copy feature works. When I double click on the Epson Scan icon on my desktop it appears that it wants to start up but then...
Install another scanning software, if you have photoshop or any imaging software, you can use the scanner by going to the menu, then choose File, Import, TWAIN, Acquire and the scanner control will appear.
Or just go to My Computer and double click the scanner icon (in XP) to start the scanning assistant.
Nov 09, 2010 | Epson Stylus RX650 All-In-One Printer
I don not have a scanner icon on my desktop so can't figure out how to scan . I have an epson printer scanner copier
When you installed the printer there should have been a program installed with it called Epson Scan. See if you can find it in your start menu under all programs. Otherwise, you may simply want to try installing it again, and tell it to place an icon on your desktop. You can find it at http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=107546&prodoid=63076682&infoType=Downloads&platform=Windows. This is the epson support website, and the file you want is named "Scanner Driver and EPSON Scan Utility v3.49."
Hope this helps! Good Luck!
Nov 02, 2010 | Epson Stylus NX300 All-In-One InkJet...
How do I scan on a Epson Stylus DX8400
Go to your computer icon on you desktop or start menu and click on it. It will show you folders, files and drives on your computer, scroll down until you see scanners and cameras and double click on it. If you Epson Printer scanner is installed properly, (which if it's printing, it is) select from the dropdown menu > it will say Microsoft Scanner and camera wizzard, click on that, click OK and it will open up the scanner wizzard. Click Next, place your document you want to scan on the glass facedown and select your option e.g. colour picture and select preview, when you are happy click next and it will scan the document, select the location you want it storing and save.
Lisa
Apr 20, 2010 | Epson Stylus DX8400 All-In-One InkJet...
Does the Epson tx100 actualkly have a scan function? I cannot find a button or way of working it.
Hello how are you.
Yes it have scanner on your printer but to use you need to do from your pc and go to users options and there you can see to use.
Hope this good for you thank you.
Usai
Mar 10, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Help me pleaze
check if it connection issue
check all cables if it is connected directly
check device manager for imaging device see if there is a conflict update the driver
if same hotswap, then try another cable
if connection ok then same issue
trash and reinstall and reinstall the epson scan: follow this
Scanner Driver Removal
If you see a window that says User Account Control at any point, click Continue.
  1. Disconnect the USB cable from the printer and close any open windows.
  2. Click Start, then select Control Panel.
  3. In the window that opens, click Uninstall a Program under the Programs heading.
  4. Select Epson Scan, then click Uninstall/Change.
  5. Follow the on-screen instructions to complete the removal and restart your computer.
Once the removal is complete, please do the following:
Scanner Driver Download
  1. Go to www.epson.com select your contry
  2. Under All-In-Ones, select Flatbed, then select your model from the list.
  3. Click on Windows under Drivers & Downloads.
  4. Download the most current version of the Scanner Driver for your Windows operating system to your Desktop. Make a note of the file name in order to easily retrieve it.
Scanner Driver Install
  1. Double-click the downloaded file on your desktop.
  2. Click OK, Unzip, then OK again.
  3. Follow the on-screen instructions to complete the installation and license agreement. The installer will copy the files to the system.
  4. Click Finish when prompted.
  5. Turn your unit on and reconnect it to the computer after the installation is complete.
  6. Windows should detect new Hardware and complete the installation automatically.
  7. If a New Hardware Wizard appears, allow it to search automatically.
  8. If a message appears indicating The Scanner has not passed Windows Logo testing, click Continue Anyway. Then click Finish.
  9. Restart your computer before testing the scanner software.
Oct 09, 2008 | Epson Office Equipment & Supplies
Scanner Not Recognized
You need to remove the yellow question mark on the device manager. Click on the plus sign of the Question mark icon. Right click on the item that will be displayed under the question mark and then uninstall. You need to uninstall the drivers as well. you can doo it on add/remove programs(winxp) or program features (vista). Unplug the USb cable/ Download drivers from support.epson.com and you just need to choose the right driver for your windows version. After Installing the TWAIN driver and Epson scan utility, you need to restart computer. When computer is ready you can plug in the usb cable and open up Epson Scan on your desktop
Jan 28, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Epson Stylus NX300 All-In-One InkJet Printer Logo
836 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
