Question about Bosch 24 in. SHU43 Built-in Dishwasher
Shu43c diagnostic code retrieval - Bosch 24 in. SHU43 Built-in Dishwasher
  • 1 more comment
  • Dan Zaid
    Dan Zaid Apr 16, 2014
    Sorry folks, looking for diagnostic self test button sequence. TIA
  • Dan Zaid
    NM..http://fixitnow.com/wp/2005/10/12/bosch-...
  • Dan Zaid
    Dan Zaid Apr 25, 2014
    No, and the solution might have been simply cycling circuit breaker. Unit was still in draining limbo when I revisited. I interrupted power during extraction. My initial suspiscion was a stuck float, but it was clean, so was the bottom reservior & float. I exercised the associated switches, repowered and decided to force some feedback, lifting the red arm. It was that or power cycle that fixed it up. Thanks!
  • Bosch Master
  • 3,247 Answers
I believe you have found the code sequence as shown in your additional information post. Please clarify if you are looking for anything additional.
Posted on Apr 25, 2014
Power window wiring diagram for 1998 Lincoln town car
Go to http://bbbind.com/free_tsb.html free wiring diagrams !
  • Power Windows Completely Inoperative
  • Window regulator control switch.
  • Circuits open or shorted.
  • Window regulator electric drive.
  • Driver door module.
  • PERFORM Self Test to retrieve Diagnostic Trouble Codes. If no DTCs retrieved, GO to Pinpoint Test C .
  1. VISUAL INSPECTION CHART
  1. Mechanical
  2. Electrical
  • Front door power window regulator damaged.
  • Front window run damaged.
  • Front door window glass out of window run.
  • Front door window glass broken.
  • Lighting control module.
  • Circuits open/shorted.
  • Loose, corroded connectors.
  • Damaged window regulator control switch.
  • Damaged window regulator electric drive.
  • Power distribution box Fuse D 40 for heated back window concern; Circuit Breaker 14 (20A), Circuit Breaker F (30A) or window regulator safety relay for power window concern.
  • Fuse junction panel Circuit Breaker 14 (20A), Fuses 6 (10A), 9 (5A), 15 (15A), Fuse 13 (10A), Fuse 4 (10A) or Circuit Breaker 12 (18A).
  • Scratched grid.
  1. If the inspection reveals obvious concerns that can be readily serviced, correct the concern before continuing with Inspection and Verification.
  1. If the concern remains after the inspection, connect the Rotunda New Generation Star (NGS) Tester, 007-00500 or equivalent, to the data link connector (DLC) located beneath the instrument panel to perform DATA LINK DIAGNOSTICS test. If the NGS responds with NO RESPONSE/NOT EQUIPPED for the driver door module, go to Pinpoint Test A . If the NGS responds with NO RESPONSE/NOT EQUIPPED for lighting control module, go to Pinpoint Test B . If the DATA LINK DIAGNOSTICS test is passed for the driver door module and lighting control module, retrieve continuous DTCs and execute self test diagnostics for the driver door module and lighting control module to retrieve current DTCs.
  1. If self test is passed and no DTCs are retrieved, go to Symptom Chart to continue diagnosis.
  1. If DTCs are retrieved for the driver door module, go to the Driver Door Module (DDM) Diagnostic Trouble Code (DTC) Index to continue diagnosis. If DTCs are retrieved for the lighting control module, go to the Lighting Control Module (LCM) Diagnostic Trouble Code (DTC) Index to continue diagnostics.
  1. If the driver door module cannot be accessed by the NGS tester, go to Pinpoint Test A . If the lighting control module cannot be accessed by the NGS, go to Pinpoint Test B .
Rotunda Service Bay Diagnostic System (SBDS®) 001-00001 may also be used to diagnose this system.
You'll need more then wiring diagrams ! A good scan tool for starters .
Youl
Aug 08, 2016 | Lincoln Cars & Trucks
2004 ford expedition eddie bauer All the doors won't lock/unlock, just make a buzzing sound repeatedly. Also does this when shutting the vehicle off.
What makes a buzzing sound , the door lock actuators ? Or where do you hear the buzzing coming from if not at the doors ?
Power Lock
The power lock/unlock feature requests all of the vehicle doors, including the liftgate, be locked or unlocked upon a customer request from any interior door lock switch in the vehicle. The power door locking system functions independently of ignition status or vehicle speed. When the vehicle security module receives an unlock/lock command from any door lock control switch, the vehicle security module will activate relays internal to the module to supply the correct power and grounds for the door lock actuators.
Visual Inspection Chart Mechanical Electrical
  • Binding latches
  • Central junction box (CJB) fuse(s):
    • 5 (7.5A)
    • 30 (30A)
  • Circuitry
  • Relays
  • Remote transmitter
  • Keyless entry keypad
  • Vehicle security module
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the diagnostic tool does not power up, refer to the diagnostic tool manual.
    1. Carry out the diagnostic tool data link test. If the diagnostic tool responds with:
      • SCP, UBP or ISO; all elctrconic control unitw, no response/not equipped, refer to Section 418-00 .
      • No response, not equipped for vehicle security module, refer to Section 419-10 .
      • System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs, and carry out the self-test diagnostics for the vehicle security module.
    1. If the DTCs retrieved are related to the concern, go to the Vehicle Security Module Diagnostic Trouble Code (DTC) Index to continue diagnostics.
    1. If DTCs are retrieved that are not found in the following Vehicle Security Module Diagnostic Trouble Code (DTC) Index, refer to the Master Vehicle Security Module Diagnostic Trouble Code (DTC) Index in Section 419-10 .
    1. If no DTCs related to the concern are retrieved, proceed to the Symptom Chart to continue diagnostics.
Jan 13, 2016 | Ford Cars & Trucks
Need to change fuse on remote keyless entry but don't where it's located on fuse box on 2004 explorer
Do any doors lock/unlock with remote keyless entry ?
  • The doors do not lock/unlock using the remote transmitter
  • Remote transmitter battery.
  • Remote transmitter.
  • Remote transmitter programming.
  • Aftermarket system.
  • High power devices.
  • TV/radio transmission towers.
  • Vehicle security module.
  • Go To Pinpoint Test C .
Pinpoint Test C: The Doors Do Not Lock/Unlock Using The Remote Transmitter
Normal Operation
Remote locking and unlocking of the doors is accomplished by the vehicle security module receiving a command message from the remote transmitter. The vehicle security module processes the command and sends a signal directly to the door lock actuators.
All remote transmitters must be present to begin diagnosis of the remote keyless entry (RKE) system.
Aftermarket or dealer-installed systems may adversely effect the RKE system operation. These systems should be disconnected before diagnosing any RKE concerns.
  • Latches
  • Battery junction box (BJB) fuse(s):
    • 2 (30A)
    • 16 (15A)
    • 22 (20A)
    • 29 (60A)
  • Central junction box (CJB) fuse 20 (5A)
  • Circuitry
  • Relays
  1. If the cause is not visually evident, connect the diagnostic tool to the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
  • Check that the program card is correctly installed.
  • Check the connections to the vehicle.
  • Check the ignition switch position.
  1. If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
    • SCP+, SCP- OR UBP circuits fault; all electronic control units no response/not equipped, refer to Section 418-00 .
    • No response/not equipped for vehicle security module, refer to Section 418-00 .
  1. If DTCs are retrieved that are not found in the following Vehicle Security Module Diagnostic Trouble Code (DTC) Index, refer to the Master Vehicle Security Module Diagnostic Trouble Code (DTC) Index in Section 418-00 .
Nov 18, 2015 | Cars & Trucks
1997 Lincoln Town Car anti theft system won't set. parking lights blink off and on when I turn car off.What could be the source of this problem?
Anti-Theft System NOTE: The system immediately monitors the ignition switch lock cylinder (11582) upon removal of the key from the ignition switch lock cylinder. It is not necessary to arm the system for ignition switch lock cylinder monitoring.
VISUAL INSPECTION CHART Mechanical Electrical
  • Damaged luggage compartment door lock cylinder.
  • Damaged hood ajar switch or bracket.
  • Open fuses: Fuse junction panel:
    • Fuse 4 (15A)
    • Fuse 6 (10A)
    • Fuse 9 (5A)
    • Fuse 15 (15A)
    • Circuit Breaker 12 (18A)
  • Loose connections
  • Corroded connections
  • Damaged switches
  • Damaged relay(s)
  1. If inspection reveals an obvious concern that is readily serviced, correct the concern before continuing with Inspection and Verification.
  1. If the concern remains after the inspection, connect the Rotunda New Generation Star (NGS) Tester 007-00500 or equivalent to the data link connector (DLC) located beneath the instrument panel to perform the Data Link Diagnostics Test. If the NGS responds with NO RESPONSE/NOT EQUIPPED for the lighting control module, go to Pinpoint Test A . If the NGS responds with NO RESPONSE/NOT EQUIPPED for the driver door module, go to Pinpoint Test B . If the Data Link Diagnostic test is passed for the lighting control module and driver door module, retrieve continuous DTCs and execute self test diagnostics.
  1. If self test is passed and no DTCs are retrieved, go to the Symptom Chart to continue diagnostics.
  1. If DTCs are retrieved for the driver door module, go to the Driver Door Module Diagnostic Trouble Code (DTC) Index to continue diagnostics.
  1. If DTCs are retrieved for the lighting control module, go to the Lighting Control Module Diagnostic Trouble Code (DTC) Index to continue diagnostics.
  1. If the lighting control module cannot be accessed by the NGS tester, go to Pinpoint Test A . If the driver door module cannot be accessed by the NGS tester, go to Pinpoint Test B .
There are a great deal of components involved here an the best way to tell what's working or not is have a scan tool hooked up to check for DTC'S - diagnostic trouble codes !
There is a lot
Jul 14, 2015 | Lincoln Cars & Trucks
1997 lincoln continental will not show the miles or any data by going through the systems check most data comes incomplete what would cause this to happen?
This is one you should take to a qualified repair shop ! The electronics involved , a factory scan tool needs to be hooked up to the vehicle !
Instrument Cluster-Electronic Inspection and Verification
  1. Verify the customer's concern by operating the instrument cluster (10849) to duplicate the condition and by observing the indicators and gauges to determine if they are operating properly with the ignition switch:
    • in RUN with the engine OFF
    • in START before the ignition switch is released
    • in RUN with the engine running
  1. Inspect to determine if any of the following mechanical or electrical concerns apply:
    • Damaged fuel tank.
    • Engine coolant level.
    • Engine oil level.
    • Washer fluid level.
    • Accessory drive belt.
    • Fuse Junction Panel Fuse:
      26 (10A), 28 (10A), 5 (10A).
    • Circuit wiring.
    • Switches or sensors.
    • Stuck fluid level sensor.
  1. If the inspection reveals an obvious concern that is readily serviced, correct the concern before continuing with inspection and verification.
  1. If the concern remains after inspection, connect the Rotunda New Generation Star (NGS) Tester 007-00500 or equivalent to the data link connector (DLC) located beneath the instrument panel to perform DATA LINK DIAGNOSTICS test. If the NGS responds with NO RESPONSE/NOT EQUIPPED for the virtual image instrument cluster , GO to Pinpoint Test C . If the NGS responds with NO RESPONSE/NOT EQUIPPED for the lighting control module, GO to Pinpoint Test D .
    If the DATA LINK DIAGNOSTICS test is passed for the virtual image instrument cluster and lighting control module(s), retrieve continuous DTCs and execute Self Test Diagnostics for the virtual image instrument cluster and lighting control module(s) to retrieve current DTCs.
  1. If DTCs are retrieved for the virtual image instrument cluster, go to the Virtual Image Cluster (VIC) Diagnostic Trouble Code (DTC) Index to continue diagnostics. If DTCs are retrieved for the lighting control module, go to the Lighting Control Module Diagnostic Trouble Code (DTC) Index to continue diagnostics.
  1. If the virtual image instrument cluster cannot be accessed by the NGS tester, go to Pinpoint Test C . If the Refer Lighting Control Module cannot be accessed by the NGS tester, go to Pinpoint Test D .
It's more then likely you need a new instrument cluster ,but you need to have it checked for any codes stored ! A obd2 code reader won't do it ! factory scan tool !
It's
Apr 29, 2015 | 1997 Lincoln Continental
2008 FLHTCU electrical diagnostic code PSSPt
Hi Anonymous, PSSPT is not a code it is a menu in which to choose a particular area of the electrical system that the ICM/ECM has generated a trouble code in. For more information on how to retrieve these codes please visit the website below and good luck:
Harley Diagnostic Codes 04 to Present
Nov 22, 2013 | Harley Davidson Motorcycles
Does 2000 chevy malibu have trick to pull codes like older cars?
you will need a obd 2 diagnostic code retrieving tool , in order to retrieve the trouble codes in your car, you can purchase the tool at a auto part store.
Jun 24, 2011 | 2000 Chevrolet Malibu
Need to know how to retrieve the diagnostic codes on a 1989 nissan stanza
I have the 87 model,but the procedure should be the same. Its under the passengers seat. Had to remove my seat to access it.Turn the ignition on,with a flat-headed screwdriver turn the screw fully clockwise,and wait until you see several blinks. Two or three.Now turn the screw fully counter-clockwise,and read the blinks.The Red light denotes "!0), the yellow light denotes (1), so if the Red light blinks once,and the green light blinks twice, the code will be 12
May 20, 2010 | 1989 Nissan Stanza
My Isuzu Rodeo 1997 Check engine light is on There is no Isuzu technician in my area''
You have fault codes stored in your vehicles computer. Any local mechanic with a diagnostic machine can retrieve these codes that will diagnose your electrical component issue. To retrieve codes - $50 to $75.
Jun 08, 2009 | 1997 Isuzu Rodeo
How do i get the error codes from a 95 astro van without a diagnostic tool
place a jumper wire between terminals A and B of the diagnostic connector , located just under the steering column,pointing staight out. Turn the key on and after the initial 12 code ( flash ,pause, flash,flash), you can count the flashes to retrieve the error codes. ex. *** ** equals 32. each code will show 3 times . When 12 returns , you have retrieved all the stored codes. Good Luck.
Jul 23, 2008 | Chevrolet Astro Cars & Trucks
Bosch 24 in. SHU43 Built-in Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
