Question about Sony PlayStation Portable (PSP) Console
It won't play any games and it makes a funny sound when I turn it on. Kind of like gears "grinding"
I don't know about the game thing but the gear noise is normal.
Posted on Jun 18, 2009
Drum turns but sounds like a small metal object, possibly a screw, banging around inside . Continued to use and now sound is much louder and sounds like a bigger object.
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
The glides on drum worn and making metal to metal contact.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
Jun 27, 2014 | General Electric Profile DPSR610EGWT 7.0...
What kind of oil is needed in the rearend
If it did not have oil it would make the noise going straight. Check your brakes and the wheel bearings for play. Oil should be a GL5 70-90 wt gear oil.
Jun 22, 2014 | 1998 Ford Expedition
Hp 4L printer won't pickup paper from tray. Sequence- green led light- motor running but with grinding- no movement from pickup roller or foot- finally a misfeed led light.
That is a very common problem with the Laserjet 4L and 4P printers. The sound you hear is caused by a broken motor drive gear. This is a small plastic gear on the drive motor shaft. They can develop a small crack which prevents the motor from turning the gears for paper pickup and toner movement. When the motor tries to turn the broken gear can not turn the other gears and makes the popping or grinding sound when the gear teeth slip. You will need to replace the motor gear, it is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_49&products_id=61
I hope this helps,
BuddyMc
Jul 16, 2012 | HP Office Equipment & Supplies
TAPPING NOISE, NOW IT WON'T GO INTO GEAR WITHOUT LOUD GRINDING NOISE AND ACTS LIKE TRANSMISSION WON'T ENGAGE TO DRIVE
If it is an automatic transmission, first check the fluid level. If it is low, fill it up and try it again. If the level is fine, then there is a bigger issue and you should seek a professional's help.
Jun 18, 2017 | 1996 Buick Century
Car won't start but makes a grinding noise like when the car is started already
This sounds like a damaged starter drive gear and engine flywheel gear.
Feb 25, 2012 | 2001 Pontiac Grand Am SE
Makes funny noise when I try to grind coffee and no ground coffee comes down into the handle. Seems like something is stuck in the grinder.
if you hear it trying to grind, but is not, or hear it spinning and is not grinding, more than likely it is blocked, or so oily that bean will not drop. Coffee beans, have so much oils in them, that after a while it gets caked up, and beans either get jammed, or stuck. If you hear grinder low humming, then it is probably stuck or clogged, if it is on but hear like a spinning sound, beans are not dropping, because they are stuck because of oil build up. If you can get to the grinder, turn machine off, unplug, get all beans out, take like a wooden chop stick and put it in area where beans go and move the chop stick around the gears. you like your reaming it out kind of. turn machine back on, try this procedure a few times. ( MAKE SURE MACHINE IS UNPLUGGED WHEN DOING THIS) As said early if it is a low humming, like motor turning but jammed, do not use until jam is fixed, you will burn up motor, then have more expensive fix. Let me know if this helped and solved problem. Mr Bean Man from Fixya
Jun 12, 2011 | Breville BES860XL
Motor is makeing a funny sound went started.
Grinding is the starter is to close to the ring gear. What type sound?
Nov 07, 2010 | Chevrolet Impala Cars & Trucks
When i try to start the car it makes a funny sound and wont start it sounds like something is not catching
Good indication of a bad starter. Is it just clicking or is it a grinding ugly noise?. The second is definately the starter.
Nov 01, 2009 | 1997 Chevrolet Cavalier
This morning the car was making a funny grinding sound when i changed up gears put not when changing back down????
Sounds like the clutch is not engaging or the syncros in the transmission are failing.
Jul 27, 2009 | Fiat 124 Cars & Trucks
PS2 dic read help!!!
Hi Anishpp,
You have a great console, it just needs some tuning. The arm that moves the laser up and down the rails may have become clogged with lint. I usually clean it out and flex it to apply more pressure down on the worm gear.
Nov 04, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation Portable (PSP) Console Logo
35 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
