Question about Electrical Supplies
Wire up on switch for clarke ext771 carpet extracter
Unplugged on off switch thought might be broken but is not now dont know which wire goes to prongs on switch
aborcass
  • 2651 Answers
SOURCE: i have a 3 prong
3 prongs, are as follows live wire-- nuetral--- live wire.. the middle terminal is always the nuetral line.. so normal color codes are red(live)-white(nuetral)- black(live), or black(live)--whiite(nuetral)-red(live). so long as you nuetral hooks to center post either live wire can go to either side
Posted on Oct 31, 2008
SOURCE: Broken light switch on a Nutone
The Black 120vac Line In wire goes into "L". The Black wire goes into "2". The Red Wire goes into "3". When you install the switch, the Red and Black wires will be on top of the switch.
Posted on Dec 25, 2008
  • 75 Answers
SOURCE: VCR/DVD prongs broken off in TV
unplug the tv then try to drill a real small hole in the broken off part of the cable that is inthe tv, then take a sharp pointed screw and try to thread it into the hole that you drilled if able to get it started then pull out on the screw to see if it will come out. If not able to do it this way you will have to take the back off and some of and see if you can push the broken part out from the inside. Be sure to unplug your tv from (AC) so you dont get hurt. If that dont work then u probley willhave to take to a shop to get fixed.
Posted on Feb 21, 2009
  • 23 Answers
SOURCE: dont know wich wires go to wich prongs on ignition
You can get a wiring diagram by going to a web site for OMC Motors
Jim OMC Retired Mech
Posted on Jul 07, 2009
canbruce75
  • 1776 Answers
SOURCE: changing dryer plug
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Posted on Oct 07, 2009
I need to find out where a wire come from the electric box connections under the gas tank wire running to the battery area.wire gets unplug or broken
Get a wiring diagram of your bike and you will find out what goes where in minutes, I couldnt help more as i dont know what Kwak you ride, there's quite a few different models out there lol Get the diagram and it will be easy
Jan 07, 2015 | kawasaki Motorcycles
I have a Clarke King 100 hot wash with a wiring problem please can you help with the 3 connections from the pressure switch ?
the pressure switch is so the burner goes off when you stop squeezing the gun, there are only 3 different combinations wire1 and wire 2, wire 1 and wire 3, wire 2 and wire 3, it does not matter which way you connect them. You will know when it is correct as the burner will only work when the gun is squeezed and water is coming out of the lance nozzle at high pressure.
Jul 26, 2011 | Simpson King Brute 3030 Hot Pressure...
I have a Clarke Mig 130EN Fan Cooled Welder that is not feeding wire and I can't find anyone local to work on it, nor do I know where to go about finding parts. The only Clarke phone number I found...
Hi:
If you are in the USA, check WWW.Praxair.com for your nearest welding store they will help you, Praxair has more than 1000 retail stores in the USA.
If you can make the motor to work just by by-passing the switch then your problem relies on the gun switch, that's an easy fix.
Just an advice; stop buying clarks, it is pretty defficult to obtain speare parts. Lincoln, Miller, Hobart or any other american machine are easier to find parts and are pretty good welders.
Jun 22, 2011 | Clarke Power Products Clarke 130EN Mig 110...
I have a Clarke weld 130 en turbo and would like to buy nother wire drive wheel for the it as the wheels goes around but does not drive the wire through .could you help tthanks.
I do not know of a US source for these Clarke EN130 Wire drive wheel parts. I don't know of any interchangeable subs either. Your welder was made in Italy and the wheel drive is metric.
This is probably your best bet in trying to find any parts for it:
http://www.clarkeinternational.com/shop/search/filter/EN130/page/1
Not sure if you knew this:
Clarke Power Products Files in Toledo
Clarke Power Products Inc., a wholesale distributor of power equipment from Perrysburg, Ohio, filed a Chapter 11 petition on Jan. 8, 2009 in Toledo, saying it owes $7.9 million to the secured creditor Key Bank.
Court papers say assets of $13.8 million are comprised of accounts receivable, inventory and cash. Clarke’s products include air compressors and power tools.
The case is In re Clarke Power Products Inc., 09-30071, U.S. Bankruptcy Court, Northern District of Ohio (Toledo).
Thanks for choosing FixYa.
Kelly
Sep 05, 2010 | Clarke Power Products Clarke 130EN...
I dont know how to rewire the back of my dean evo xm? i tried to fix the faulty input so i thought the wires were faulty so i tried to rewire it and i dont know where everything goes now. theres red yellow...
It is rare that wires would be faulty. Soldering can be, but not the wires usually.<br /> <br /> Common problems are broken jacks or pots that are broken or shorting to the paint in the cavity.<br /> <br /> If you have things unwired now, the best thing is to find an appropriate circuit here and wire it like that:<br /> <br /> <a href="http://www.guitarelectronics.com/c=gpIlkL5hB6ISnsWqCfLePUcJa/category/wiring_resources_guitar_wiring_diagrams/">http://www.guitarelectronics.com/c=gpIlkL5hB6ISnsWqCfLePUcJa/category/wiring_resources_guitar_wiring_diagrams/</a>
Aug 28, 2010 | Dean Evo Xm Electric Guitar
Will not **** the water off the carpet.
If the carpet cleaner won't "Extract" water from the carpet, try using the upholstery / hand tool. If you have suction there, your selector switch / knob is either in wrong position, or broken. There may also be a tear in the hose on the inside of the cleaner, or the waste tank is not sealing well.
Jun 13, 2010 | Bissell 1699 ProHeat Clear View Upright...
My dog tore out some wires on lt1000 17.5 hp ridng mower. inow have it wired so it will start and run,but have one wire i dont know where it goes. from the ignition switch the blue is hot the black im not...
If you unplug your harness from the key switch on the back of the key switch you will see by the terminals letters stamped a S for solenoid a L for lights B for battery G ground and a M for magneto. This will tell you were the loose wires should go. Hope this helped.
Mar 17, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
G4 kirby
ensure the safety switches are made properly by making sure the front brush assembly is fitted properly, you will see a tag that enters the machine making the front switch, secondly make sure the bag bottom housing is on properly and fully rotated so that its tag makes the switch on the side.
The only fuse is in the plug (UK).
Common fault is the mains lead broken internally, unplug from the side of the machine after removing the little cover where the wire goes in. You can use a kettle lead to test the hoover.
If this does not cure it most likely the motor brushes are worn.
Jul 24, 2008 | Kirby G4 Bagged Upright Vacuum
Electrical Supplies Logo
16 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
