Question about Sony PlayStation 2 (PS2) Console
One PS2 controller doesn't work good and screws my other one
Joystick PS2 . One controller if I plug it in , just does random stuff and moves the character randomly without me touching it and if I plug the second controller (wich works) the second one won't work at all .
    New Friend:
  • 3 Answers
This is usually a matter of cleaning. If the nodes on either your controller end or the system itself are dirty you could have a bad connection that would cause your controller to all kinds of wacky stuff. Use some cleaner like alcohol and a q-tip and clean the ends. If that doesn't work your proabably better off buying a new controler then trying to fix it.
Posted on Apr 16, 2014
lunasea808
  • 30 Answers
SOURCE: PSP joystick messed up
Okay This has happen to me and what it is the joystick is off track. I'm not saying you guys are handling your psp roughly but it does happen. You can try to repair the joystick yourself.
But the best bet is to buy a new one. Doesn't cost much and it is not hard to do. I paid $3 for a replacement. Word of advice if you are buying a generic brand you may want to buy at least three of then just in case one or more of them are doa (dead on arrival) you never know. Will save to time in returning and waiting for a replacement.
If you want please ask and I will post a how to for repair of your OEM joystick. This doesn't always work but what the hell it's worth a shot.
Posted on Feb 17, 2009
Meganerd X
  • 117 Answers
SOURCE: PS froze on start
If it is only one disk, clean the underside ot the disk with cd cleaner and try again if problem persists, the disk may be defective or the unit may have problems.
If all disks do this, there is most likely a problem with the system call 1-800-345-sony for assistance.
This was in the manual which was printed 9 years ago, so if the number has changed or they no longer cover the ps1, i whouldn't know what to do if cleaning the blue lens thingy doesn't fix the problem.
Posted on Mar 14, 2009
  • 4 Answers
SOURCE: Sony PS2 controller left side directional button inop
i know what you mean try pulling the button and then on the game on menu change the controll or buy a new one in game stop for $15.00
Posted on Mar 15, 2009
  • 71 Answers
SOURCE: please help asap!!!!!!!!!!
I would suggest to toggle the "analog" button on and off to see if that fixes the problem. If not then try a different controller. Try it with different games as well(make sure discs are clean!!) If that does not work then your playstation has a malfunction and needs to be repaired if it is worth it to you.
Sorry!! GOOD LUCK!!
Posted on Jun 11, 2009
  • 24 Answers
SOURCE: PSP joystick won´t work
It should work fine without it. Make sure you keep that little clear rubber part safe. It's what fills the gap between the analog stick and the motherboard on the PSP
Posted on Jun 16, 2009
My ps2 joystick L3 button stuck when i derict it to any direction .. it suppose to back into its center position but it doesn't it stuck and still unmoved untill i move it back to its original pos
I would suggest buying a new controller if you want to skip the hassle of trying to fix this one, but if you insist on keeping this controller, then there could be a way to fix it. First try your best to smoothly trace the joystick around in a circle, and see if that unsticks it. If this doesn't work, apart from buying a new controller the only other thing to do would be to open the controller up and put lubricant on the bottom of the joystick, this will most likely work, but you might damage your controller in the process.
Oct 11, 2012 | Sony PS2 Dual Shock 2 Controller...
Hi, I have 2 PS2 controllers, the one was newly bought, the other, has been used for about a year or two. The problem is, the old one's R1 button is unresponsive. Well, it do responds, but only if...
you will need a rubber replacement for your R1 button, if you or a friend have a defective joystick consider that a replacement. if you can't find a defective joystick you can buy a ps2 rubber kit online. below are reference pics.
1. Remove 5 screws with a philip screw at the back of the joystick.
2. Split the two covers with caution.ck
3. Carefully remove the rubber beneath the R1 button and replace it with a new one.
4. Put together the front and back part of the joystick.
5. Test the replaced part and screw if you're satisfied.
Hopefully this information helps.
Thank you for using Fixya..
Aug 03, 2011 | Sony PS2 Dual Shock 2 Controller...
My father has a Jazzy 600 electric wheelchair and it has been working fine, batteries are only a few months old but all of a sudden it will not charge. Should not be able to move the chair while it is...
Sounds like the inhibit function of the chair has been damaged. This function will not let you move the chair while charging. If Dad doesn't have the charger off when plugging in to the chair or removing it it can short out the charger port causing your problem. Unfortunately the only fix is to replace the joystick/controller. If Medicare paid for Dad's chair then they will pay for most of the repair costs. Contact the provider that brought Dad's chair and ask if they can order a new joystick for you Hope this helps
Jun 06, 2011 | Health & Beauty
Ps2 - characters moving on own
I had the same problem before. Its called joystick/button lock. You need new controllers. Happy Dance!
Dec 21, 2009 | Sony PlayStation 2 (PS2) Console
Joystick moves up
same problem with mine, something was stuck inside, i shook it then i throew it against the wall. lol, it worked, but if i were you flip it over and take it apart real carefully and clean out all the hairballs and stuff with q-tips and 99% isopropyl alcohol
Nov 23, 2009 | Sony Dual Shock 3 Controller for...
My ps2 not responded to my joystick my joystick is work what happen my ps2
The Cable could have a break in it, check to make sure none of the pins in the Controller port are bent and if all else fails you will need to buy a new controller port, but try a different controller before you buy a new controller port
Nov 03, 2009 | Sony PlayStation 2 (PS2) Console
PS2 Controller Joystick Problem During Gameplay
If you've had the controller a long time weird things can start happenning. Usually the pads on the joysticks go first.
Try a different joystick(borrow a friends) and if it still happens you'll know its not the controller.Could be a glitch in the software of the game.
Eliminate each area. If a friend has the same game use their disc to try your controller with.
Take your controller to the video game store ask them to try it out on their game display models.If it's "busticated" you can buy a new one right away LOL.
Aug 03, 2009 | Sony PS2 Dual Shock 2 Controller...
Ps2 joystick or ports problem.
Maybe you need a new controller that happend to me one time.
Mar 28, 2009 | Sony PS2 Dual Shock 2 Controller...
Can't get ps2 dual shock 2controller to work
you need to do a special code to take control which is press L1,R1, L2, R2, Start, and Select, for about 30 seconds. if it don't work, unplug the controller, blow on the Female and Male ends. (controller and system) and plug back in and you should be good to go. Please rate my solution.
Jun 10, 2008 | Sony PS2 Dual Shock 2 Controller...
Sony PlayStation 2 (PS2) Console Logo
46 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
