Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
Craftsman mwer cuts moreso on the right side than left side.
It starts digging up dirt when i go over certain parts if land even if i jack it up to #4.
  • 376 Answers
Take a look at your blades. Sound like one of the is bent.
Posted on Jun 19, 2009
My riding lawnmower not cutting even, craftsman 46"
first check that the blade or mandrel is not bent or damaged --and check the air pressure in tires on right side --lower deck towards ground on a level surface until left makes contact now adjust the level arms they are on either side of cutter till right side is level with left on some of the older decks can adjust the front deck wheels also
Aug 25, 2016 | Craftsman Garden
Can I put a 18" bar on my Poulan 35 CC, If not why.
yes you can put an 18 inch bar on this saw. you could even go with a 20 or 24 inch bar as long as it will fit the saw. I wouldn't go much bigger though because it really doesn't have enough power to handle a much bigger bar. And, getting into the dirt makes the saw chain really dull really quickly. Dig around those roots if you don't want to be stuck sharpening your chain every 10 seconds. Take it to your local saw shop and they can fix you right up! Hope this helps...
Jun 26, 2013 | Poulan Pro PP3516AVX 16" 35CC Gas Chain...
I have a John Deere LA105 Riding Mower and when I mow it leaves a strip of grass in the middle. Left and right sides are cutting fine. I have taken the blades off and shaarpened them and have leveled...
jack the tractor (using a tractor jack) or remove the deck, measure the blade tips against each other where they meet in the center of the deck and see if they are the same tip to tip. Bearing wear, a bent deck or blade can make them cut at different heights in the center.
Sep 25, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman LT1000 mower deck cutting uneven. How
try biger wheels on the low side???? ha ha?
no you hit and bent the bed hight ajusters you may need to take the mower bed off to fix this part,,,,,
look as were the morer hight ajuster is,,, is it in the same place on both sides,,, my gess is its not
the bed has a tilt on it,,,they dont cut down trees very well do they?
Jun 11, 2010 | Garden
Craftsman Lawn Tractor, 18 HP, 44" Cut; No SWtart!
Check the by pass switches on the seat, clutch pedal, and check the fuses.
May 15, 2010 | Craftsman Garden
2003 DLT3000 Craftsman riding mower. Air in tires correct, deck level front/back & side/side, new blades.. Still cuts uneven. Does this deck flex when cutting tall grass & how do I fix this...
when you put the new blades on did you notice if they were even with each other? the 42" decks have a tendency to "warp" inward on the left side. this causes the left blade to ride at an angle to the right blade - there is a tool to correct this, but not all shops have it - sometimes you can remove the deck, flip it over and wallop the inside edge of the left mandrel until the blades are even - a 2 lb. sledge works well for this
Aug 26, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
One blade on deck gives an uneven cut
Sounds like a bent shaft, or the mounting is not flush.
Jul 04, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Mowing blades on 42 inch deck are not cutting evenly.
go to sears.com
find parts direct at the top click on it
a place will come up where you can enter you mod#
click on search aftermod # entered and everything part wise will come up for that tractor
on the left hand side
Jun 15, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
RIGHT SIDE BLADES CUTS LEVEL, LEFT SIDE DIGS INTO THE GROUND
the right side cuts level but left side doesn't well the answer i have would be that someone stepped on the deck which will cause the adjustment arms to bend & deck will not be level or the only other thing it could be is the blades could be bent as well if i can further help e-mail me @ wadembly@aol.com thanks ,wade
Jun 08, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
108 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
