Question about Dryers
Rhine ceiling fan remote replacement
I have a Kichler Celino ceiling fan. When the lights are switched on they are dim or immediately go off. I have taken it apart and it appears the the problem may be in a little black box from Rhine Electronic Model No PL-190B. How do I test it and where can I get a replacement.
    Genius:
  • 1,617 Answers
Where did you find the little black box?
Posted on Apr 17, 2014
Testimonial: "David. Thanks for thinking and asking! The box is on top of the motor which is inside a housing. It is connected to the remote receiver by a blue and a white wire. The receiver is fine. The white being the common ground. A red wire coming out of the box is connected to a black wire that goes to the lights. A white wire from the lights is connect to the common ground. The box is definitely part of the light wiring harness as it is labeled 'incandescent'. Maybe it is nonessential as the bulbs are 120 V 50Watt Halogens?"
    New Friend:
  • 45 Answers
Kichler sends it's customers to this company for replacement receivers and hand-held transmitters: http://fanmanlighting.com/default.asp
Posted on Sep 16, 2015
3 Suggested Answers
SOURCE: Fan speed control UC7058RY produced by RHINE, need
hi Januszkop,
I have the same ceiling fan. However, I lost the remote control. Do you know where I can buy it? Thanks.
Posted on Oct 03, 2010
SOURCE: I need to replace a
Me too. Pleas let me know if you found it.
My remote controlled Hampton Bay ceiling fan light partially works. The fan works but the light does not. The remote control is a Rhine UC7076. Any ideas in making the light work? Also where can I buy a...
That's a low-end store brand for Home Depot only. Sounds like you need a new receiver. Make sure if you have a pull chain on the light that you pull the chain to the on position.
Dec 07, 2014 | Hampton Bay Dryers
Does a kichler ceiling fan remote model # uc7206t have reverse?
www.kichler.com/customer-service.aspx
Almost all ceiling fans have reverse. The switch is usually on the side of the fan so one must get a ladder to get to it. Air flow to be up in winter and down in summer.
Nov 14, 2014 | Dryers
Kichler ferron 60" why ceiling fan will only move very slowly remote does not appear to be working
If your Kichler ceiling fan appears to have lost touch with the remote, try the usual routine of removing batteries from the remote, pressing all buttons to eliminate a stuck button as the cause, then reinstalling the old batteries (or new batteries) and testing operation. If no luck, disconnect power at the source, not the fan, pause briefly (to "reset" the fan control) and reconnect power to test operation. If still no luck, the remote receiver in the fan or the remote itself may be defective.
Aug 31, 2014 | Kichler Dryers
Yes. If it has dip switches you have to match the receiver & transmitter codes. Didn't the new one come with directions?
Sep 15, 2013 | Dryers
I have a brand new Kichler Ceiling Fan/Light installed in new home. This one for the M-Broom came with Remote UC7206T. The function which controls Fan and Fan speed works fine but I cannot the Light...
Something that may work (based on my experience). Shut off power to the fan (the circuit breaker). Remove the battery from the remote and push all the buttons just in case one is stuck. Reinstall the battery. Turn the CB on. Check operation using the remote.
Dec 29, 2012 | Kichler Lighting 300106OBB Ceiling Fan
How to reverse kichler ceiling fan, UC7206T
Stock Kichler ceiling fan c. 2006, works with replacement remote control 337001WH hand-held unit from Amazon 2013. Started running backwards when two remotes were activated at the same time by accident. Random button pushing on two remotes simultaneously got it to go back to forward. (Apparently original remote hand-held transmitter had forward/reverse setting, but the substitute 337001WH transmitter doesn't. When two transmitters run at the same time, the fwd/rev code may be decoded in the collisions at the receiver. Thank goodness!)
Jun 13, 2012 | Kichler Lighting 300105CTO Ceiling Fan
Fan speed control UC7058RY produced by RHINE, need to order replacement? For St. Regis 60" Hampton Bay Ceiling Fan.
hi Januszkop,
Oct 24, 2009 | Hampton Bay 60 In. St. Regis Fan, Ancient...
Dryers Logo
506 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
