Harman kardon problems I have a avr 7000 the only speakers that I can play are the two front speakers the center speaker and the two rear speakers will not play. What could the problem be?
    New Friend:
  • 87 Answers
Use 5.1 video to test the other speakers.
Posted on Apr 18, 2014
sticky92505
  • 77 Answers
SOURCE: harman kardon avr 7200.1 no volume left front speater
could be a few different things. if you have tried another speaker that you know is in working condition then it might be a connection on the amp itself or the terminal could be bad. does it look coroded or is there anything obstructing its connectivity?
Posted on Feb 18, 2009
welcomejee
  • 10594 Answers
SOURCE: No audio from Harman Kardon AVR 7000
Incorrect polarity between receiver and speaker will not damage receiver however unmatched impedance speakers can damage amplifier section of receiver.
Please check connection cables in receiver and if receiver does not shut off in protection mode then it could be connection cable broken or some dry / cold solder joints on circuit boards in receiver.
Re-soldering of cold solder joints is job of qualified tech.
Posted on Sep 14, 2009
SOURCE: my center speaker does not work with harman kardon avr 40
perform a test from the menu for speaker output.Your op manual will gude you thru this
Posted on Oct 07, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have a Harman/Kardon AVR 325. Left speaker not working with TV
How is TV audio (from the cable box) getting into the Receiver? If digitally, you wouldn't be missing any one channel on a connection malfunction, you'd lose them all. If analog, swap the channels around to isolate the problem (and reconsider using digital).
Posted on Feb 12, 2010
SOURCE: My Harman Kardon AVR 254 is not responding. None
I am having the same problems with my AVR 254, did you find a solution?
Thanks
Posted on Apr 10, 2010
I hope this mail finds you well.i am not getting sound from the surround and center speakers.when i test my speakers i only get sound from the front speakers.
hi,
check ur speaker connection first or may be ur receivers speaker setup have some problem. except frond speaker all the others will be off mode. change the speaker setting.
press osd button on the remote to bring audio setup. select ur speakers large or Small or large according to ur speakers. then test again.
if u connected an analog audio input then press surr (surround mode button) to select the mod you want)
ok
Dec 18, 2010 | Harman Kardon AVR 7000
My center speaker does not work with harman kardon avr 40
Oct 07, 2009 | Harman Kardon AVR 40
Sep 14, 2009 | Harman Kardon AVR 7000
Thanks
Mar 15, 2009 | Harman Kardon AVR 325 Receiver
Right Front and rear speaker do not work proberly.
I ran into the same issue with an AVR 7000 after it had been shipped to me. I took the cover of and found that the left and right amplifiers have a separate power plug into them. when I plugged to "bad" side back in everything worked great.
Dec 30, 2008 | Harman Kardon AVR 7000
Receiver no longer connects to surround speakers
there is a issue with the 10uf capicitors on the dsp.i had to replace abiut 30 of them.
Apr 15, 2008 | Harman Kardon AVR 7000
AVR 7000 audio/video receiver
Harman kardon amplifire are known for that.specially AVR 7000
but sometimes this comes from poor wiring and using a wire that will not conduct better sound. Remember your wiring is very important.you may think your wiring is currect, better to double check. even if your connection is ok and the wire you are using are not better to produce quality sound you will not get sound from every speaker.
good luck
Feb 28, 2008 | Harman Kardon AVR 7000
Avr 7000
WAT BRAND SPEAKER AND RECEIVER?POSSIBLE OHM ISSUE?WAT IS THE IMPEDENCE ON THE AMP AND CENTER SPEAKER,.HAVE YOU TRIED RUNNING A 6?8 CHANNEL CONFIG?FOR EX.USING YOUR SOUND CARD THROUGH THE PREAMP AS A DSP. WHE PLAYED IN SHOP HE USESD CD? U USING SAME CONNECTION FROM THE SAME INPUY? OR IF LISTEN ING TO RADIO. SOMETIMES THE SINGNSAL IS NOT IN A DIGITAL FORMAT SO THE PPR LOGII C CANT PRODUCE IT.IT WOULD BE PLAYED ANALOGICLY.MEAN NO CENTER.
Dec 26, 2007 | Harman Kardon AVR 7000
Right speaker out in all modes
your sound system has a faulty audio circuit have a tech repair your set.good luck
Apr 24, 2007 | Harman Kardon AVR 7000
41 people viewed this question
 Grubhead
Grubhead
