Question about Maytag Kitchen Ranges
Oven displays loc code
When I press the bake button the loc displays and nothing happens. Any idea what's wrong and how to fix it. Thanks
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the model number?
Posted on Apr 16, 2014
  • 126 Answers
SOURCE: Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Posted on Dec 10, 2007
SOURCE: Oven trouble
Do Not try to perform the below if: Oven is under warranty,You are not handy with a soldering gun, or Are afraid to do this.
The below solution applies only to my in-wall oven with F2 and F3 codes randomly, but presumably will work with other GE models.
I had the same trouble with a GE in-wall oven. The problem was on the electrical board behind the keypad. A pin that was soldered to the board, that was the input for the oven temp sensor, had cracked solder. So I re-soldered the pin and hopefully it will continue working.
If this fixes your oven please post back!
Posted on Dec 21, 2007
SOURCE: my oven says LOC and it is not locked
Today the "Loc" light came on and I can not use
the oven... the oven door does open and the
cook top works ok?
I see two others have the same problem.
I tried to un-plug the electric plug but this did
not re-set it?
This unit is about 7 years old. I can not find
the manual. There is no re-set button anywhere
and I also can not find a model number on back?
Posted on Mar 09, 2008
docjohn174
  • 943 Answers
SOURCE: Oven or broil does not work
hi thanks for the question . the control board seems to be defective the clicking noise is the relay .but not letting power to the elements thanks the appliance doc
Posted on Sep 28, 2008
SOURCE: whirlpool gold range E1 F5 now says LOC in display
try sething the oven for cleaning for about 3 hours.
Posted on Dec 08, 2008
I tried to press bake which turns the oven on usually and got LOC in white letters instead of a temperature
Perhaps indicating the oven door is locked.
Look for an unlock button.
my Fridgaire oven has a led to indicate door lock
Nov 13, 2016 | Ovens
Replaced the LCD pad computer. getting a LOC rEF code. What does it mean or how do I clear it?
If this is a GE oven:
1. Make sure power to the wall oven is turned off_
2. Completely close the wall oven control panel and return the wall oven to its normal installation_
3. Apply power to the wall oven. Accessing the control panel area but not replacing the control:
4. Enter Special Functions mode by pressing the BAKE and BROIL keys at the same time.
5. Reset the control by pressing the 9 and 0 or the HOUR DOWN and MINUTE DOWN keys for 3 seconds at the same time.
6. Approximately 20 seconds after the time of day is displayed. press the 1 and 5 or the TEMP LIP and MINUTE UP keys. The control should briefly go blank, briefly display all segments. briefly 'display "LOC FIEF," display all segments for 30 seconds, and then display "LOC REF:"
7. Acknowledge the "LOC REF" command by pressing the 6 and 8 or the HOUR DOWN and MINUTE UP keys at the same time. The control should then display the time of day,
8. The oven should be ready for normal operation.
9. Test the functionality of the glass touch contra especially the CLEAR/OFF and/or CANCEL key(s)..
Nov 26, 2015 | Kitchen Ranges
Oven doesn't heat
Hi Sharon Knight - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
Sep 17, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
The oven is stuck at LOC.
The locking motor has gone bad on the range. Common for this to happen after self clean. You will have to replace or have the lock assembly replaced for the stove to work again
Mar 06, 2010 | GE JKP45 Electric Double Oven
Start button not working.
probably your button is dirty had carbon inside. do you hear a click sound when press it? if so , the IC did not received the signal, it need to be check by a technician.
Jun 30, 2009 | GE Profile JT910SASS Electric Single Oven
Touch pad does not work and flashed FO
FO- the touch pad is faulty. replace the eoc(electronic oven control)
May 17, 2009 | Kenmore Ovens
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Whirlpool accubake oven problem
Hi All,
I tired the delayed bake work around and it didn't help me.
So, being a trained scientist... I know just enough to be dangerous! Here's what I learned. (imitate me at your own risk. This thing is on a 220V circuit at 30A... you or someone else in your house could get badly killed if you do something wrong. You definitely want to send small children to the movies, or at least to bed before trying this!)
First, I turned the self-clean on for 60 seconds to see if both elemets were working. The broiler got bright red but the bake element didn't. The door unlocked as soon as I shut it off, so I could I touched an ice cube to a few insided parts to see how hot they were. The bottom of the oven was barely warm, but the baking element instantly melted and sizzled my ice cube.
Good enough for me: Both heating elements are working, so it must be a controller problem.
Next I turned the power off at circuit breaker, and double checked that the oven was dead. I pulled it out of the wall and removed the top sheet metal cover. Inside I found a red plastic envelope containing a "Tech Sheet". It has a schematic diagram, plus a table that explains the error codes and what to do about them. Be sure to read all the dire warnings and the bit about "For Service Technician's use only" before deciding that you are foolish enough to do anything with it. :-)
I undid and inspected the connector for the printed ribbon cable from the keypad to the controler circuit board. (I happen to know, being a scientist, that 90% of all problems in the universe are caused by bad contact) I didn't see anything obviously wrong, so I reassebled it carefully, making sure the ribbon was fully seated.
I then powered the thing up. It said PF for power failure. I pressed cancel for 5 seconds and it said F0E0 which means no pre-existing fault was detected.
I then pressed bake, and lo and behold the damn thing baked! :-)
I'm not certain it was bad contact, since the other 90% of the world's problems are caused by software. It's entirely possible that power cycling was this thing's idea of CTRL-ALT-DEL. Maybe someone can try flipping the breaker off for 10 minutes without taking anything apart, to see if that clears the problem?
I also have no idea how long this will stay fixed....
Has anyone tried calling Whirlpool? 1-866-698-2538, M-F, 8 am - 8 pm Local Market Time, Sat. 8:30 am - 5 pm Local Market Time, according to their website.
Stay tuned... if I'm not back, the thing is still baking... :-)
Apr 09, 2008 | Whirlpool RBS275PD Electric Single Oven
"loc" display
This just happened to me. I have whirlpool double oven accubake. The display went blank and i had to turn the breaker off. I left it off for several hours. When I turned the breaker back on my oven display read "Loc" in big letters to the right of the time. I held the start button down for 5 secs. The display went away and the oven started to work as if nothing had happened. I hope that is stays that way.
Dec 08, 2007 | Whirlpool Ovens
Self clean light blinks when you turn oven on (oven does not work)
I had this same problem with mine (still posted under unsolved) This is the simpler model with the old turn style knob and the lever you slide over to lock the door for cleaning What I think (keep in mind I know little about ovens, more about cars) is that the switch that tells the oven the door is latched is staying engaged, and this is part of the lever mechanism. I cleaned and lubed this mechanism (obviously I would guess you want to use a food safe lubricant) and then moved the lever several times with the oven on so I could see if it turned on. After a few tries the cleaning light went off and the oven light came on. No, its not really a technical answer, all indications to me where that the problem was in the switch which is part of the latch mechanism. Good luck
Nov 26, 2006 | GE JGBP26 Gas Kitchen Range
Kitchen Ranges Logo
149 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
