Question about Indesit W 123 Front Load Washer
My spin cycle on my ariston aib 16 is locked as OFF, how do i turn it on
  • rogo_vik
    rogo_vik Apr 18, 2014
    You have given little information. Check is not littered filter of the pump adown washer machine. Needs information that works? It Is Flooded and meets water? Works die out? Works the pump?
  • 43 Answers
Works the pump?
Posted on Apr 18, 2014
Ariston A1637 delay wash and key lock flashing won't complete a cycle
Most likely the problem is a clogged or jammed drain pump impeller. First shut off power to the washer by unplugging it or turning off the breaker. Then remove the screen in the bottom of the washer,clean it out reinstall then run washer
Jul 28, 2013 | Washing Machines
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston washer dial starts turning and won't stop -no wash/spin..
CHECK THE PIPE TO THE DRAIN HOSE AND FILTER TRAP IF ONE FITTED IF BLOCKED CAN CAUSE THE SAME THING ESPECALY IF YOU HAVE A NON RETURN VALVE FITTED
Jan 05, 2010 | Ariston Technologies Washing Machines
My ariston margarita dosent want to take a wash load
Most likely the EPROM is gone, or more commonly known as the PCB (Programm Control board) and it needs replacement. Costs about £80 for the board plus installation.
Dec 14, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Soon as i set cycle and swich on door light flashes open
hi,
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Thanks for your question.
Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
F-05 on Ariston Margherita AIB 16
i had the same problem. try emptying the little chamber at the bottome front of maching. there might be something in there. then have a look at the little grey fan thing. give it a push. if it springs back it is working if not it is broke. tip the machine on its side and undown the filter part. ordr this section online. it is easy to replace. i done it myself. Lu
Sep 09, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Washing machine not working
Before switching the "on" switch select your programme, ie whether you want spin, wash, etc. Then put the "on" switch on.
Mar 02, 2007 | Ariston Technologies AW 129 NA Washer With...
Indesit W 123 Front Load Washer Logo
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
