Question about Pioneer TS-WX206A Subwoofer with Built in 150W Mosfet Amplifier
My Pioneer TS-WX206A Subwoofer with Built in 150W Mosfet Amplifier has stopped working but has power
  • 8 Answers
SOURCE: pioneer mosfet DEH p350 clock
Hi ive searched for a manual on this as i was bored and i can tell you you have to.
press function repeatedly until clock appears.
When it does press < or > to select a segment of the time eg hours or minutes.
then press ^ or down to increase or decrease
Hope this helps.
Posted on May 31, 2008
  • 18 Answers
SOURCE: Can't fit subwoofer amp leads to pioneer DEH-2000MP Head unit
pioneer head units only distribute like 200 rms or so to the speakers. you might have to find a blue maybe even blue with white striped wire and nick it just enough to tie your amp wire around it. tape it up and see if it works.
Posted on May 27, 2009
xxchemlight
  • 144 Answers
SOURCE: pioneer ECQ MOSFET 50wx4 DEH-6500 Need manual
here hopes this helps ya click on the onwers manual half way down.
DEH-6500
Posted on Mar 24, 2010
sonicboomele
  • 1557 Answers
SOURCE: what amp should i buy for my pioneer ts-w2501d4
great qweastion it all depends on how many speakers you want to run of it dont make the mistake of just amping your subb amp every speaker in the car thats why amps have gains (vol controls) you can send as much power to witch ever speaker you want and less to what ever you dont like fading and balancing and hey you have gotta get some tweeters they make the world of diffrence but each speaker needs a channel so if you have 4 speakers a 4 channel amp and so on good luck with it have fun
sonic boom electronics australia.
Posted on Apr 21, 2010
MNfisherman
  • 11896 Answers
SOURCE: what size of box in need Pioneer TS-W307D2 12
Length (L) = 31.9 cm = 12.6 inches (approximately 12 1/2 inches)
Width (W) = 51.5 cm = 20.3 inches (approximately 20 1/4 inches)
Depth (D) = 19.7 cm = 7.76 inches (approximately 7 3/4 inches)
Posted on May 04, 2010
I have a pioneer GM-X524 amp connected to a TS-W253C subwoofer and it isn't working. It has 12v power to it and a solid ground, but the power light wont come on and the sub isnt working
there should be 3 power related cables connected to the amplifier:
1-From battery to amp via fuse (positive)
2-From chassis of car to amplifier (negative)
3-From head units (power continuous) (blue or blue/white cable) to the amplifiers remote connection.
this connection enables the amplifier to switch on when the head unit is switched on and off when the headunit is switched off.
I hope this helps and let me know if I can further assist you.
....andy....
Jan 06, 2014 | Pioneer Car Audio & Video
Is my 1200 pioneer amp a good match for my 1200 watt pioneer sub
this is too close, your speaker wattage is alway's higher than your amplifier's wattage alway's to be safe because the hard pounding will make the speaker work harder, and this will cause your speaker burn out easily, though you can adjust your amplifier anyway's
May 08, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Output problem
dude TRUST me what you are using and have setup already is plenty..ONE TIP...of all things anyoine ever needs to worry about is the R...M....S power rating...the PEAK means NOTHING! its safe and fine to use what you got.
Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
Amp connection to pioneer tsw307d4
First of all check impedence of the subwoofer and how many voice coils it is. Go to www.the12volt.com click on subwoofer wiring diagrams then you check the load that your amp is stable at. Then wire it that way. Easiest way is to print out the diagram then take it actually out to the sub and box for reference.
May 30, 2009 | Pioneer TS-W307D4 Car Subwoofer
Which terminals to use
if your amplifier is 2 ohm mono stable - you can wire them in parallel.
Put a piece of wire from one + terminal to the other + terminal on the subwoofer.
Then do the same to the -.
Now pick one pair of teminals from the subwoofer and wire it to the amplifier. (one set of subwoofer terminals will have 2 wires each).
If you reply with your amplifier make/model, I can tell you the best usage.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
I need instructions connecting my car subwoofers
Bridging your amplifier @ 4 ohm will yield the most power.... with the subwoofers you have.
You must wire them in Parallel.
Positive on both subwoofers to + on amplifier.
Negative on both subwoofers to - on amplifier.
The lowest impedence possible with 8 ohm woofers is 4 ohms.
Thank you for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 28, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Sub woofer
Is there a gain control on the sub? If not, are you using a receiver or pre/processor to control volume? There could be a level adjust or on/off control for the subwoofer output.
Jan 20, 2008 | Pioneer VSX-D511 Receiver
Subwoofer
Most AV receivers do not have a built in amplifier block to drive a subwoofer, and merely provide the subwoofer output channel at line voltage. Thus, a powered subwoofer is required. Does the subwoofer require mains power? From your description, I'm guessing it doesn't. If not, it does not have a buit in amplifier, you will need to purchase a monoblock amplifier, which is just a mono amplifier with a volume control, no tone controls or anything else. Make sure that the amplifier power rating is as close as possible to the subwoofer power rating, as it is quite possible to blow a speaker by using an amplifier whose power output is too low, by overdriving the amplifier , and putting DC through the voice coil when the amplifier clips. If it does require mains power, it will have an amplifier built in, but does not have line level inputs.
Sep 14, 2007 | Polk Audio CSi40 Center Speaker
Pioneer TS-WX206A Subwoofer with Built in 150W Mosfet Amplifier Logo
35 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
