Question about Fellowes DM12C Shredder
Oil Used WD-40
How to fix this because the gear don't move and but the motor is heard loud!
    Scholar:
  • 136 Answers
A gear is probably stripped. Fellowes sells gears for some of their shredders, but gear replacement is a messy job! Oiling it will not usually fix the problem; you need to contact Fellowes directly.
Posted on May 01, 2014
Showtime Ronco rotisserie & bbq oven makes loud grinding squeaky noise while rotating. Can I use WD 40 to oil the gears?
No, it is petroleum based and highly inflammable. Use a good quality plant based oil like Sunflower Oil.
Jan 18, 2017 | Ronco Kitchen Appliances - Others
Why does my singer sewing machine model 600 not sew a wide width zig zag stitch
If your small zig zag is off to one side of center, it means the lubrication has dried out and the mechanism is dragging. If you can remove the top (usually held in place by a few screws) you should see some parts that move on zig zag but not straight stitch. Warming the parts with a hair dryer will tend to loosen them, just be careful of any plastic parts. A little penetrating oil (like WD-40) will help get the snap back in your zig zag.
Remove the needle and work the needle bar from side to side while turning the hand wheel with the machine set to the widest stitch.
Oct 11, 2016 | Singer Sewing Machines
WD-40 oil
WD-40 should not have damaged your shredder if you have used it on metal parts, and though certain plastics can be melted with WD-40, probably hasn't done any damage. However WD-40 is not an oil, nor a lubricant (it is a degreasing solvent). If you want to apply a lubricant, use a light machine oil such as this: amazon.com/dp/B00200B22S. Much better.
Apr 16, 2014 | Office Equipment & Supplies
Not starting
If I understand your statement correctly, noise but the engine will not "turn over." This sounds like the starter motor is running but the gear that engages the flywheel gear-teeth is not making contact at all or is moving into too-slight contact, just enough to make a lot of noise. In U.S. cars the device on the stater motor that moves the starter gear forward is called a "Bendix." As the starter motor starts to turn, the Bendix shoves a small gear forward, engaging teeth on the flywheel which spins the flywheel to start the engine. If the Bendix is sticking or has failed the gear will not move forward at all or not far enough.
Sarting with the least cost first, I'd look toward a "sticky" bendix. Try using a light penetrating oil or perhaps, WD-40 to free-up the Bendix.
Apr 06, 2014 | 2001 Jaguar XJ8
How to fix a hood release
hood release is held on by couple bolts. Remove bolts then lubricate
with motor oil WD-40 will not last. Anything that moves gets worked
til it moves freely. Make sure the cable gets lots of attention too.
Mar 10, 2013 | Cars & Trucks
My Intermatic T103 Indoor 120-Volt 40-amp timer emits a constant peeping sound
Intermatic T103 is mechanical timer with moving gears.
Timer makes audible sound when tripper clicks on-off, but it should not make constant noise unless gears are causing noise.
Turn off power and spray WD-40 on gears and see if problem continues.
WD-40 vapor is extremely flammable hydrocarbon when sprayed, and should not be sprayed on live electric circuits.
If problem continues, turn off power, pull mechanism out and spray WD-40 on plastic gears of clock motor.
Open following links for illustrations of clock motor and removing mechanism.
http://waterheatertimer.org/images/WH40-005-gears-350.jpg
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Aug 12, 2011 | Intermatic T103 Indoor 120-Volt 40-amp...
I have a large whirlpool airconditioner in the wall - it colls my living roon and kitcher but within the last few weeks its begun to make a squeeking noise - like a fan that need oil - it doesn't seem...
IT MUST BE THE BLOWER/ ROTTER WHICH IS MAKING THE NOISE. OPEN THE FRONT PANEL AND SPRAY WD-40 TO THE MOVING PARTS. SWITCH OFF THE MAINS FIRST.
REGARDS.
PLZ. DON'T FORGET TO RATE
Jul 05, 2011 | Whirlpool Heating & Cooling
Fedders dehumidifier making high pitched noise
The fam motor bearings are dry and need oil..wd-40 with the long spray nozzle maybe the best way to get oil on the bearings... some motors are sealed and it is very dificult the get them quiet again...spray right where the shaft comes out of the motor and then lean the unit back so the oil runs into the motor and let it set for awhile..then try it...
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
Apr 20, 2010 | Fedders A7DH65B2A Dehumidifier
Bulb lights but blower doesn't; how to fix?
once you get the case apart, you should be able to see the bearing case on both sides of the motor that the shaft goes through (lead colored). the motor mount screws also take the motor apart. once you get the motor bearings off, put some 3-in-1 oil in the star shaped openings in the bearing cases. clean off the shaft with wd-40 on a rag, wiping it clean. also, using a q-tip soaked with wd-40, clean out inside the brass bearings. once they dry, put it all back together. do not get wd-40 or oil on the motor barrel or the windings.
Jan 05, 2010 | Office Equipment & Supplies
Dragging motor and squeak
Absolutely! WD-40 is NOT a lubricant. I've been using Hoppes gun oil, but 3-in-1 oil will work, and you might find oil labeled for use on electric motors at an appliance parts seller.
Jul 26, 2008 | Maytag M6Y18F7A Air Conditioner
Fellowes DM12C Shredder Logo
109 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
