Question about Maytag Washing Machines
My Maytag performa series LAT2500AAE fills to the medium level no matter which setting I use. It does NOT overflow.
    Novelist:
  • 150 Answers
If your infinite water level switch has a reset, perform this before changing the water level setting prior to your next load, this is usually done by rotating the knob to the reset zone, then back to your desired water level setting. If your problem still exists, you will most likely need the water level switch replaced Part# 22001776. Pleazer Appliance...
My Maytag performa series LAT2500AAE fills to the  - 5276c4b0-1078-4f88-b69d-c0912e3bc939.jpg
Posted on Apr 17, 2014
AlmostBob
  • 550 Answers
SOURCE: Kenmore 90 series washing machine
Follow all jsrocks tests,
but Before replacing the pressure switch there are more tests of function
Blow any water out of the air tube, it should be empty when the washer is empty, water remaining in the tube messes up the pressure sensing(usually makes water level lower so doubt this is the fault)
Kenmore pressure switches are adjustable, the adjustment is hidden.
An internal spring stretches over time and does not react properly.
to test whether just the adjustment is required,
  1. remove the water level knob from the front side of console
  2. depress the lock tab at the right side of water level sensor body where it contacts the back side of the console and rotate counter clockwise 45degrees
  3. withdraw water level sensor body
  4. adjacent to shaft for the knob is 1/8inch bolt head, turn clockwise to raise, counter clockwise to lower water level.
  5. washer can be operated with the console open and the level body removed
  6. test, adjust, test adjust.
  7. if no effect replace water level sensor body
Posted on Jun 04, 2008
  • 148 Answers
SOURCE: Maytag Performa water level
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Posted on Jul 13, 2008
eagle338
  • 4889 Answers
SOURCE: the washer overflows with water. help
Overflow is usually caused by a “stuck-open” fill valve, and the cold water half of the valve is usually the culprit.
This can also be caused by the fill system control components: pressure switch, pressure tube, or pressure tube dome/port. So let’s take a look at these.
First of all, determine whether your overflow condition is mechanical or electrical. Start the washer filling, then turn the timer off by pushing the knob in. If the fill continues, pull the washer plug. If filling continues with the washer unplugged, you have a mechanical problem - nearly always a stuck valve ***’y. Replace the fill valve.
If however, the fill stops when you unplug the machine, you are looking at an electrical fill control problem, and it gets a little more complicated.
Here a small piece of rubber or plastic tubing is handy. Unplug the washer and open the console where you’ll see the pressure switch. This is the switch with a small rubber tube, usually clear, sometimes black, attached. Pull this tube off and replace it with your short tubing. Blow a bit of pressure into the switch using your mouth, and listen for a click, then another when you release the pressure. Hear two clicks? Good! The switch is probably OK, but we’re having fun, so let’s continue!
Plug the washer back in (being aware that components in the console are now hot)and start the washer filling again. With it filling, again blow a bit of pressure into the switch. If the switch is good, the fill should stop and the machine should start to agitate.
This verifies that the pressure switch is working, and causes us to suspect the pressure tubing or a clogged port/dome to which it connects. Wipe off the end of the original tube you removed from the switch, and blow into it. You’re blowing air down into the tank now, and you should feel very little restriction. If it is very hard or impossible to blow through this tube, the tank dome or port is clogged.
Older Maytags are known for this, and if you have one, spin out all water, remove the ‘Corbin’ clamp from the pressure tube outside of the tank and pull the tube off. (Pull washer front off – 2 Phillips screws at bottom, then two 3/8 in. hex screws release top, which swings upward) You will probably see ‘gunk’ clogging both the rubber tubing and the ‘spud’ that is a part of the tank. The hose ***'y can be taken to a sink and flushed clean with hot water, and an old toothbrush used to clear the tank spud, which, in the Maytags, is about 3/4 in. ID.
It is best cleaned from the inside, which means pulling the cabinet and tub. Not beyond the reach of the handyman, this job does require a special spanner wrench to remove the tub nut, as well as the removal of some other components. I’d probably recommend this one as a job for the pro. An experienced tech will have seen this before and be in and out in an hour or less.
The tank port on these washers is too small - only about 3/8 in. diameter, and hard to clean, even from the inside. Here’s yet another job for the trusty wetvac. We are hopeful that Whirlpool will soon enlarge or baffle these ports to correct this problem - one of very few ‘glitches’ these excellent machines have.
Whatever your brand, if air can’t be blown back through this tube, the port or dome will need cleaning.
If you have no trouble blowing pressure through it remove the tube completely and inspect it carefully. This tube must not have the smallest hole in it, and we sometimes see them worn through or, more often, chewed through by mice. I mention this last because, while it is the least common cause of overflow I see, it does happen and is easily overlooked. We run into this a couple of times each year, usually in the Fall when the mice are looking for a warm winter home.
Also uncommon, sometimes this tube will swell and loosen a bit, leaking air where it attaches to the tank fitting. If you suspect this, or the tube fits very loosely, simply cut 3/4” or so off the end and push it back on.
One last comment on this concerns some newer Frigidaire 27” (wide) machines. These use a piece of tape (!) to secure the pressure tube to the outside of the tank. This tape has to be there (don’t ask me how I know!) or the tube will pull off while spinning, causing flooding. If it has come off, or was removed for service, be sure to replace it. Duct tape will work well; just be sure to clean the tank before attaching to be sure it stays put. Naptha (lighter fluid) will do this well.
Hope this helps,
Sai.
Posted on Sep 11, 2008
  • 142 Answers
SOURCE: Kenmore 80 series model# 110.28803890
Hello. Yes there is a fill level pressure switch. It is pressure activated by the pressure of water rising in a tube as the water rises in the tub.It's easy to find and easy to replace. Look for the tube and follow it to the switch. Parts for Kenmore are available at 1-800-516-9625 or at http:\www.sears.com.
Good luck.
barneyluc
Posted on Oct 19, 2008
sonicboomele
  • 1557 Answers
SOURCE: I have a maytag performa pav2360aww it
you have a problem with the water level stop valve have it checked it may be blown but this is the fault.
Posted on Feb 13, 2011
Lat2500aae We have a Maytag Performa, Model
it sounds like the shocks on the drum maybe failing. on this model the washing machine mother board is close to the outer drum. the out drum may have made contact with it. and not turning on the pump to let the water out.
Oct 06, 2013 | Washing Machines
I HAVE A MAYTAG PERFORMA WASHER MODEL#pav3240. the washer continues to fill during rinse cycle and overflows the top. If i turn to spin cycle water drains out and machine goes through cycles. it seems like...
Clean out the water-level switch air dome tube AND the the connection to the tub where the tube connects. It may well be full of gunk and not allowing the water level switch to react quickly enough.
Jun 06, 2017 | Maytag Washing Machines
My Maytag Performa washer loves to flood the house!!!!
sounds like pressure switch is bad or pressure hose is plugged or water valve is bad or drain overflowing
Apr 22, 2010 | Maytag Performa PAV2200
I have a maytag performa top loading washer, model # PAV3240AWW, that overflows. It doesn't happen every time and it doesn't matter what size the load is or what cycle I am using.
You have sand and sediment in the sump base of tub. All you di is remove the rubber hose on the water level switch and blow out the tube with your mouth. You will feel it when the **** is out of there. Then reconnect that hose tightly to the switch and pump out any remaining water in the tub. here are some repair photos
Oct 08, 2009 | Maytag Performa PAV3200
Maytag FAV6800AWW - Major overflow right after starting machine
Hi, If you turn the water source valve on and water starts filling the machine even tho the machine is off, change the inlet valve.
If you have to start the machine so water will fill but, the water does not shut off at the desired level, there is a problem with the water level switch.
I hope this helps you. Please let me know if I can assist you further.
Vic.
Jun 13, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water level will not stop at medium
You have a sticking water level switch caused by a blockage in the hose or pressure chamber, or a sticking inlet valve..
If it is a valve, then water would keep on coming in even though the washer is off, if this is the case, then fit new valve..
If it is the level switch you will have to unblock the hose and and chamber.
Hope this helps.
Jan 01, 2009 | Maytag Performa PAV2200
Maytag performa
does the water overflow from the waser. also try and fill the washer up with water and when you feel it should be filled to capacity shut the water off to the washer. and turn off the power. After you have done that turn the water back on and turn the power back on to the washer if the water stops running it could be your water valve and is easily replaced. if the water continues to run it could be the pressure switch (water level switch) or it could be a hole in the pressure switch hose.
Dec 30, 2008 | Maytag Performa PAV2200
Jul 13, 2008 | Maytag Performa PAV2200
Washer does not stop filling and it overflows!
check the pressure switch tube connectiong to the tub for a hole or crack first
Apr 23, 2008 | Maytag Performa LAT2500A
Washing Machines Logo
106 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
