Question about Samsung Televison & Video
SAMSUNG LA26R71BA FACTORY PARAMETER VALUE - Samsung Televison & Video
    Top Expert:
  • Samsung Master
  • 75,311 Answers
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy Pull up older posts. Surf the site with patience.
Posted on Apr 16, 2014
Resor factury shdls router ct524(hardwair)??????No reset button on the back of the modem!!!!!!!!!!!!
The factory reset is completed via the configuration page. Enter the IP address of the router in your browser and then login. For
example, if the IP address is 192.168.1.1, enter http:// 192.168.1.1 Look for Erase and Reboot and click to reset to factory defaults. Caution! If you reset your device to the factory default, any changes to
parameters will be lost and all parameters will revert to their default values.
Try root at the default username and password unless it was changed. (or root and 12345). I am not aware of a hardware factory reset i.e. pin hole.
Dec 17, 2014 | Computers & Internet
Samsung la26r71ba model led 5times blinking no set on
for sure you can not fix this problem by your own. this problem could be from your main board of tv or psu
Nov 09, 2014 | Televison & Video
Samsung la26r71ba factory parameters
Do a factory reset to this set. You have to enter its service mode to do a factory reset. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy Pull up older posts. Surf the site with patience.
Apr 16, 2014 | Samsung Televison & Video
Hi, We have KEB F5 inverter on our machine model
If you are connected to the inverter with COMBIVIS, go to parameter FR.01 and enter a value of -4. This will set all parameters back to factory default.
You may be having an issue with the inverters software verison. As long as the inverters are the same part number, you should be able to download the parameters without any issue. There may be some unknown parameters but you should be able to hit ignore and keep on downloading.
Oct 26, 2013 | Inverter KEB COMBIVERT F5
Hi, I have KEB 07.f5.c1b-3b0a inverter. I just got
Via Combivis, write a value of -4 to Fr.01. This will set all parameters back to the factory default values.
Then download your backup parameter file.
Sep 24, 2013 | Inverter KEB COMBIVERT F5
Calibration Settings for JVC TV Model AV32D501
no u will need the factory values of that model of tv to be able to balance them check with jvc for the values u will have to access the ez menu where u will balance the offset as given in the factory values do not do anything u did not go for cos u will distort other parameters u will need a tech
Jul 14, 2013 | JVC AV-32D501 32" TV
TEC SX4 Label printer received data and does not print.
How do you communicate with the printer?
If by serial check the speed parity etc frma the parameter menu
Else check that the character selecter for esc sequence is correctly programed els choose Auto.
TO en ter parameter settings
Switch on with feed and puase key pressed. When (1) diag V XX displayed press feed
(2) parameter is displayed.
With the pause button you can navigate in the menu and feed and restart allows you to change the value.
Else do a parameter clear to put everythig to factory defaults
Jul 26, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
Hi i need to reset my rvx 1000 to factory
Page 42 or 69:
"To reset all of the parameters to the factory-set values
Use "9 PARAM.INI" on the SET MENU to reset all of the parameter values of all DSP programs within the selected group to the factory-set values (see page 42)..."
Feb 09, 2010 | Yamaha RX-V1000 Receiver
Factory settings
I only found this on the manual
if the power is cut for more
than one week, the parameter value you edited will
return to the factory setting."
May 13, 2009 | Yamaha HTR-5540 Receiver
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
