Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
I can not find the new brewing unit of Delonghi magnifica ECAM22110SB
Where i can buy brew unit delonghi macnifica S
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 51 Answers
It sits behind the front panel
Posted on Jun 21, 2014
5 Suggested Answers
EwingElect
  • 276 Answers
SOURCE: Delonghi Magnifica After heating up, Unit kicks
Husband suggests that could be coming broken off the brewing unit as it should be activating, He suggests you should get in contact with your local De'Longhi Service Centre (should be info on how to contact in your User Manual, or google De'Longhi for your country).
Posted on May 19, 2010
SOURCE: where do I buy spare parts I need a brewing kit
http://www.appliancefactoryparts.com has all the parts, including the O-rings, valves, etc.
Posted on Jan 23, 2011
mnwarfield10
  • 452 Answers
SOURCE: Delonghi Magnifica door comes open after grind and
try changing the defusser..... bsc appliances 07779933829 postal service too.
Posted on Feb 26, 2011
SOURCE: My Delonghi Magnifica 3400 has a problme with the
My Delonghi Magnifica door was popping open too when the machine would cycle on or off. I found that the shoot on the inside of the door was stuck. This chute is spring loaded. The chute guides the coffee from the diffuser to the dispenser ports. I think it must have been coffee build up on the back side of the chute making it stick. So when the diffuser passed by during cycling the chute would not move out of the way. This makes the door pop open. I cleaned the chute so that it moves freely and no more trouble.
Posted on Sep 18, 2011
When i turn on my delonghi magnifica pronto on its says insert brewing unit but its already in plus it makes a really loud noise when i turn it on
Sounds like the brewing unit, or infuser, has not been properly seated into its holder. Are you sure that the two red retainer fittings are in their snapped out positions? See page 16 of your owner's manual.
If the infuser has not been properly seated it could cause a loud noise when the servo drive tries to raise the unit into its brewing position.
Sep 04, 2014 | DeLonghi Coffee Makers & Espresso Machines
I think I put in too much ground coffee how can I pull out the brewing unit
Behind the front panel with the unit switched off.. you can then gently pull the brewing unit out and clean it
Apr 15, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
Sometimes the pucks do not fall into removable container. How do I fix this?
Make sure the swinging arm at the top of the brew unit moves easily. Check nothing on the brew unit is damaged. Servicing the brew unit might help.
Brew Unit
The transmission can wear out prematurely due to the brew unit becoming stiff. The piston in the brew unit should move smoothly and fairly easily. Keep the brew unit in good service by occasionally removing the piston to clean and re-grease the two big red o-rings using a food-safe grease. To pop the piston out the top, gently remove the plastic u-clip from the base of the shaft underneath, paying attention to which way up it goes for reassembly.
Jan 22, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Magnifica After heating up, Unit kicks off and readout says "insert brewing unit", Tried cleaning no result
May 18, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Magnifica "insert brewing unit"
I just figured this out on my machine, I should have taken pictures but i didnt :( this problem seams to pop up whent the elevator that moves the brewing unit up and down gets its starting position mis aligned, since the machine does not have sensors to re adjust the alignment the motor will pull the elevater down even if it cant go further and that seams to cause the nasty noise we were hearing.
1. unplug machine
2. remove the side and back covers
3. remove tray and brewing unit from inside (2 red buttens you press together)
4. remove the bracket that holds the brewing unit (2 hex screws)
5. below the brewing unit bracket is one more screw, it holds the motor unit and elevator on the back of machine, remove this screw.
6. on the back pull out the motor unit with elevator.
7. realign elevator starting position by turning the bottom wheel that is connected to motor via belt, it might feel a bit stuck first as motor has ower tightened the elevator.
The back of the elevator looks like a step ladder with screw going up the middle, for me it worked best to align the bottom of the traveling bracket with the bottom step on the ladder i recomend trying that position and then adjusting if nessesary.
8. reasemble the machine and continue to enjoy exelent coffie
Aug 08, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Delonghi Magnifica Makes creaking noise when preparing brew unit
These machines do need to be lubricated every so often. First, buy some food safe lubricant, e.g. here. Then, turn the machine off, open the front door, and remove the infuser. There is a holder connected to the machine by two hex screws. You may remove this (or even just leave it on). Now attach a long tube to the lubricant (should come with the can) and spray lubricant on both sides of the vertical screw that moves the infuser up and down. Give it a few good sprays on both sides of the screw, up and down, and that should solve your problem.
May 19, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
76 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
