I need a battery pack xbv1925 - Computers & Internet
  • 124 Answers
Any major electronic store that sells laptops will have it.
Posted on Apr 16, 2014
How do i open a kenwood th-234 battery pack? all the manuals i have seen shows a release lever in the battery pack. mine do not have one.
If you are talking the battery pack itself, it is possible you have a NiCd battery instead of the Alkaline battery shell. If your battery does not have the locking tab to press on the battery pack, look for the part number and description on the battery itself and see if it matches what is in the user guide.
http://manual.kenwood.com/files/B62-0790-10.pdf
Best regards.
May 13, 2016 | Kenwood Radio Communications
The system has detected the storage capacity of the battery stated below to be very low.For optimal performance this bsttery may need to be replaced.
you have options other than recondition which may or may not work ,often battery packs die because one or more of the batteries that make up the pack have died the rest are ok ,you can of coarse replace dead batteries in the pack or you can rebuild the battery pack with new batteries of the same type but often of larger ma capacity,with about the same amount of effort ,rebuilding a pack is not hard ,there are plenty of vids on youtube showing how and ebay is a good source of replacement batteries to put into the pack, newer packs are held together with silicon type gue and are easy to pull apart older ones need dremel saw blade sharp knife and need to be reglued when put back together
Feb 17, 2011 | Compaq Techno Earth® SUPER HIGH CAPACITY...
I have a Bushnell Night Vision Stealthview and the battery pack is damaged. (the batteries heated up and melted it partially) I need a new battery pack)
Depending on the configuration of the battery pack, it may be only available from the manufacturer.
If a more common battery pack, you may get one from an alternative supplier. There are a number of fairly common packs made up of individual cells. You might compare the pack to those available on eBay.
Dec 04, 2010 | Bushnell Velocity Speed Gun
Need to change the batteries in a Stanley bar flex light. lost instructions. how do you change the batteries.
I know this thread is old, but I just had to change the battery pack in mine. I could not locate a 4 pin battery pack so here's what I did:
You'll need: 3 NiMH 1.2v AA solder tab batteries, Razor blade, #1 Phillips driver, Kapton tap (standard electrical tape will do), soldering gun/iron, spare 18awg wire
1. Use a razor blade to remove the black sticker from the bottom of the flashlight base, it covers the magnets
2. remove the three outer phillips screws (the inner ones hold the magnets in and can stay installed)
3. Pull off the bottom plate
4. Pull out the battery pack and disconnect it from the flashlight at the 4-pin queeze connector
5. Remove the outer wrap and end protectors from the old pack keeping the end protectors in tact
6. Assemble the 3 new batteries in the same configuration as the old pack using Kapton tape, connecting + to - at the same two spots (use the old pack as a reference)
7. Carefully desolder the 2 wire leads from the old battery pack
8. connect up the 2 power wires to the same two spots as the old pack and insert the temperature probe between two of the batteries as in the old pack
9. Put the end caps on the new pack and wrap the entire thing in Kapton tape to simulate the plastic wrapper you removed
10. Install pack in to base, secure bottom plate and re-adhere black sticker(if needed you can use non-foam double-sided tape or spray adhesive)
The old pack was rated at 1300mAh and I used three 2000mAh each for a total of 6000mAh so theoretically the light should run for about 6 times as long between charges.
Aug 28, 2010 | Garden
My battery pack on my fold n go has a short and
hi, ok now you need to check your wiring within the battery pack ,
If there are two batteries, you need to make sure that negative wire of one battery connects to the positive of the other battery,
now use the postiive and negative battery connections to connect to the scooter , that will give you your 24volts,
battery 1 connects battery 2
== 24Volts
use the + of battery 1 & - of battery 2 to connect to the scooter.
Regards
GeWiz.
Oct 29, 2009 | ElectroVoice EV Rider FTCA020 Caddy Fold N...
We have managed to lose the rechargeable battery pack. Where can I get another one?
Oh my, not good. Well, you do need a battery pack. Contact the MFR for replacement pack via customer support, or check the voltage on the side, if using 9V, get a battery holder that uses 8 batteries[2 Xtra cells are used to disable the shutting off at too high a voltage due to the missing battery pack]go to battery space.com, and go to wires/connectors, and get the laptop connectors to make an external battery pack. Therte is a battery pack charger/I recommend accupower evolution. You have to google and go to other sites to get the rechargeable batteries and battery holder. You can get by with alkaline, but they would go rather fast due to the large screen size. You need that good brand name so they can be evenly charged due to the batteries being able to be run down further. You wont be wasting much voltage with alkaline due to the lower cutoff voltage, but 1st try contacting the mfr or googling to get that battery pack!!!I Hint: if using battery pack and you still want to add more battery life, drop the batteries to 6 on a 9V circuit. with original battery pack on, a 9V circuit would use 6 D cells on an external pack, 8 for a 12 volt.
Aug 17, 2009 | kawasaki PVS-10921 Portable DVD Player
Need battery or pack
Check www.biaf.com
Chances are they will have the battery that you need.
Bill B.
San Antonio
May 03, 2009 | Radio Communications
My battery on my compaq cq50 140 us wont cut on
sir/mam you`re battery pack is need to re-pack or change the Battery pack.if you want to safe and long life Battery Pack if you use the unit inside youre house use only a charger then remove the battery pack from unit do not use both supply,like a battery with charger.if baterry full only battery,if you charge the battery charge only..
This is a only a tips For Long Life Battery Pack and Unit..Thanks
Apr 29, 2009 | Compaq Presario Notebook
Supersonic SC-299TDVD
Battery back needs to be connected to the DVD player when charging. connect the batter pack to player. Run the DC/out from the battery pack to the DC/in in the player. plug the charger into the wall.
if that does not work, you have a bad battery
Dec 27, 2007 | Supersonic SC-299TDVD
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
