Question about Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Fridgidaire professional series drain smells and won't clean
It has not been cleaning properly for a few cycles, even with rinse agent. now we opened it and it has a foul smell. suspect drain not OK but not sure how to unclog.
  • Electrolux Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
nmsgjh
Posted on Sep 29, 2010
What opens the soap dispenser door
Hello. In most dishwashers, there is a special type of actuator device attached to the detergent dispenser to make the door open and then, during the rinse cycle, initiate the introduction of rinse agent into the tub. A wax motor (see the attached link below) is connected through a small wiring harness to the main control board. The name comes from how the motor operates--it has a slug of wax inside that, when heated, expands and pushes a lever which pops the latch on the dispenser door. Then, a two-position cam attached to the lever sets itself in position for the next actuation--the introduction of rinse agent. When the motor heats up the wax again, the cam allows the lever to push open the small valve on the rinse aid tank briefly so that a small amount of the liquid can drain into the tub and help remove excess water from the clean dishes during the rinse phase of the cycle. I hope I helped you!
wax motor dishwasher image Google Search
Nov 29, 2015 | Dishwashers
Electrolux Dishwasher EWD6505GS0B won't heat water?
Hi - If the unit is not drying nor cleaning properly, there are two main things to check first. Is the incoming water temperature at least 120F (49C)? If not, I strongly suggest that the temperature be adjusted on your water heater. Are you using rinse aid? Use a rinse agent to increase drying performance and using Sanitize or Air Dry Off mode also helps improve drying. If any proves to be ineffective, contact a professional to move forward accurately. Unit may have a faulty heating element a communication problem with the board not responding.
Oct 15, 2012 | Electrolux Dishwashers
Hi, i have an AEG Lavamat 1100. Although the machine runs through the spin cycle, and shows the wash cycle as being finished, when i open the door there is still water in the bottom of the machine and the...
Hi bwileman435,
It may not be draining well, because it is dirty, did you clean the Drain Pump filter?
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | AEG Washing Machines
It does not get dishes clean even after running it few times and pre rinsing before loading into dishwasher.and does not smell clean when open door after cycle done
Hi psycho_child,
Please look at my Tip below, I believe you need to clean the bottom filter, as described in it:
DISHWASHER NOT CLEANING WELL....
Kind Regards
JEDEMEYER1
* If this solution helped you at all, please rate it
Jul 21, 2011 | Dishwashers
Maytag quiet 300 Dishes do not get clean. Tried gel and powder deg. Use rinse agent. Temp. at sink is just over 120 degrees. Dishes appear to get cleaned, but then particles are shot back up and coat...
Sounds like it may just need a good cleannig. The bottom arm is easily removable. Take it off and remove the screen and see if there's any gunk that has accumulated in there. Also make sure the drain hose is positioned in a way that it will create a water trap to keep drainage from re-entering the dishwasher after the drain cycle ends.
Sep 22, 2009 | Dishwashers
The water is not draining after the rinse cycle
try cleaning your airgap. that's usually the problem when a dishwasher will not drain properly. if that doesn't do it, it's probably pump related. good luck :)
Jul 07, 2009 | Dishwashers
Dishwasher smells like fish
There are several possible causes.
First, make sure the machine is properly installed with the drain hose up in a loop or an air gap before going down to the drain. This is to ensure no dirty water or smells from the sour or garbage disposer backs up into the machine.
Sometimes nasty stuff gets trapped inside internal parts of the machine and inside the sprayer arms. It is normally easy to remove the sprayer arms for cleaning, on reasonably modern Bosch machines they can also be opened up for easy access.
There are also special dishwasher cleaning agents that you can use to perform periodic cleaning cycles. Some believe it is important to use rinse agents to minimize the problem, maybe it is worth trying if you don't use it.
If there is warranty left on the machine I would advise you to complain, there is a slight possibility there is something wrong in the machine for instance bad choice of insulation lining that have been known to emit foul smells.
Good luck with tracking down the cause of this!
May 24, 2009 | Bosch Dishwashers
There is a terrible smell in the dishwasher
All DW that I know of will have water sitting at the bottom.. it keeps the seal moist..check your drain line make sure its clean and not clog... when your DW goes into drain listen to see if its drainning like it did when you first used it... I'll check back later..
Jul 20, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Cleaning out dishwasher
Hi I checked the manual on line. Here's what it said.
Dishwasher has an odor
Run dishes being held in the dishwasher through a Rinse Only cycle.
• Many dishwashers have a “new” smell when first installed. This will dissipate with use.
• Dishwasher may not be draining properly. (See “Dishwasher Will Not Drain” section.)
• For a strong odor, place baking soda in both sides of the detergent cup. Select Light
Wash cycle and allow the water to circulate for about 10 minutes. Interrupt the cycle
by unlatching the door and let it stand overnight. Restart the dishwasher by latching
the door and allow it to complete the cycle. Another alternative is to use a dishwasher
cleaning product such as Jet-Dry Dishwasher Cleaner*.
Good Luck
Sep 17, 2007 | Maytag 24 in. MDB5651A Built-in Dishwasher
Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
258 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
