Question about Samsung Televison & Video
Samsung la26r71ba factory parameters
All bits of factory settings are abnormal..like sound disply is not highlight..
    Top Expert:
  • Samsung Master
  • 74,118 Answers
Do a factory reset to this set. You have to enter its service mode to do a factory reset. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy Pull up older posts. Surf the site with patience.
Posted on Apr 16, 2014
How do i resetmy galaxy s5 and j1 phone with abnormal factory reset and i forgot my id and password
Go to "Settings" menu. From there, go to the "Personal Tab" menu.. There you will see a "Backup and Reset" menu item. Click on that and follow the phone's information.
Thanks
Sunny
Oct 08, 2016 | Samsung Cell Phones
Samsung la26r71ba model led 5times blinking no set on
for sure you can not fix this problem by your own. this problem could be from your main board of tv or psu
Nov 09, 2014 | Televison & Video
SAMSUNG LA26R71BA FACTORY PARAMETER VALUE
Apr 16, 2014 | Samsung Televison & Video
I want loop mobile wap setting(manual) on GT I5801
*WAP Settings For Samsung:
WAP Settings
1. Open Menu>Fun box>WWW Services>Proxy Settings.
2. Scroll to the desired profile and then press Select.
3. Fill your parameters as shown below:
Proxy name:Loopwap
Home URL:http://atcafe.loopmobile.in
Bearer:GPRS/GSM
4. Select GPRS setting>Gateway.
5. Fill your parameters as shown below:
IP address:010.000.000.010
IP Port:9401
6. Return to GPRS setting.
7. Fill your parameters as shown below:
APN:mizone
Login ID:Mobile No.
Password:mmsc
8. Return to WWW Services and then select Current Proxy.
9. Highlight Loopwap and press Select.
10. To start WAP session select Home.
11. To finish WAP session press NO.
Feb 03, 2011 | Computers & Internet
How to karbonn mobiles factory setting/reset code
disply disply the master reset code on a samsung guru 1081
Dec 09, 2010 | Cell Phones
My touch screen isn't working properly. if i press something, it clicks something else. i can't even get into my phone anymore because i can't put my password in.
my phone did this but its not the same type you may find callibretion an the disply settings just go into that and it should reset it for you :)
Dec 05, 2010 | Samsung Highlight Cell Phone
Screen dim, black has green in it, contrast and brightness = shin
Since you have replaced the Color Wheel, it sounds like you have not adjusted the Index Delay in the service menu. First reset all of the picture settings you have adjusted back to original factory settings. Then on your Samsung TV Remote and with the TV OFF, Press Mute,Power,123. This will turn on the set and put you in the Service menu. Look for the top setting and select or scroll to the OPTION setting and select and look for INDEX DELAY and select that. Once you have the Index Delay selected use the right and left buttons on the remote to adjust for a picture the has no abnormal coloring and while looking at a program adjust for when the blacks look black with no abnormal coloring. Once that is done, turn off the set then turn the set back on. Now the picture should look normal.
Apr 03, 2010 | Samsung Televison & Video
I samsung highlight t749 security passcode reset
easiest way is to open up your dialer and type the following code: *2767*3855#
If you get the unlock password screen at boot up, try hitting the SOS in the bottom left, if it brings up the dial screen then type it in. It will reset the phone to factory settings and reset the password to 0000. You can then confirm this worked by going into menu/settings/reset settings/master reset. Then type in 0000 when prompted and again to verify. If your phone resets again then you know your password has been reset to factory default.
Dec 25, 2009 | Samsung Highlight Cell Phone
No print outcomes from hp laser jet printer.
Restore Your Printer To Factory Default Setting.
To restore the factory-set defaults
1. Press MENU/ENTER.
2. Use the < or the > button to select Service, and then press MENU/ENTER.
3. Use the < or the > button to select Restore defaults, press MENU/ENTER, and then press
MENU/ENTER again to confirm your selection.
The device automatically restarts.
Configure the printer as below :
Network configuration
You might need to configure certain network parameters on the printer. You can configure these
parameters from the printer control panel, the embedded Web server, or for most networks, from the
HP Web Jetadmin software.
NOTE For more information about using the embedded Web server, see Using the embedded
Web server.
For a complete list of supported networks and for instructions on configuring network parameters from
software, see the HP Jetdirect Embedded Print Server Administrator’s Guide. The guide comes with
printers in which an HP Jetdirect embedded print server is installed.
Manually configuring TCP/IP parameters from the printer control
panel
Use manual configuration to set an IP address, subnet mask, and default gateway.
Setting an IP address
1. Press Menu.
2. Press to highlight CONFIGURE DEVICE, and then press .
3. Press to highlight I/O, and then press .
4. Press to highlight EMBEDDED JETDIRECT, and then press .
5. Press to highlight TCP/IP, and then press .
6. Press to select CONFIG METHOD.
7. Press to highlight MANUAL, and then press .
8. Press to highlight MANUAL SETTINGS, and then press .
9. Press to highlight IP Address:, and then press .
10. Press the or arrow to increase or decrease the number for the first byte of the IP address.
11. Press to move to the next set of numbers. (Press to move to the previous set of numbers.)
NOTE To cycle through the numbers faster, hold down the arrow button.
12. Repeat steps 10 and 11 until the correct IP address is entered, and then press to save the
setting.
13. Press Menu to return to the Ready state.
Setting the subnet mask
1. Press Menu.
ENWW Ne.
If problem persist , reinstall the drivers .
Aug 07, 2009 | HP LaserJet 3015 All-In-One Printer
I have sony ericsson mobile phone modle no k300i and i want wap s
1. Open Menu > Settings > Connectivity tab. > Internet Settings > Internet profiles > New profile.
2. Press Add.
3. Open Name and type Loopwap.
4. Open Connect using > New Account > GPRS data.
Name: Loopwap APN: mizone User id: Mobile No. Password: mmsc 6. Press Save.
7. Highlight Loopwap and press Select and press Save.
8. Highlight Loopwap and press More, then open Settings.
9. Fill your parameters as shown below: Connect using: Loopwap Use proxy: Yes Proxy address: 010.000.000.010 Port number: 9401 Username: None Password: None 10. Press Save.
11. Highlight Loopwap and press More, then open Advanced > Change homepage.
12. Select Name and type Loopwap, press OK.
13. Select Address and type http://atcafe.loopmobile.in , press OK.
14. Press Save.
15. Return to Internet profiles.
16. Highlight loopwap and press Select.
17. To start WAP session return to Menu and open Internet services.
18. Press More > Go to and select Loopwap.
19. To finish WAP session press More > Exit WAP.
Jun 15, 2009 | Samsung SGH-D520 Cellular Phone
Televison & Video Logo
96 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
